Other than the last few weeks it didn’t take all that much time to be honest. But now I can spend more time looking for additional flashlights to buy :money_mouth_face:
So I’ve been traveling overseas and just got back and received my message and code from 10/15. Is the group buy over already? I’ve been waiting forever for this thing and can’t find it on amazon.
Sofirn has said that everyone on the list will get the lantern at the group price. Once production ramps up and the ordering process finalized then people will be able to buy again.
Ok, here is the video explaining the accessories i been testing & using with the LT1 test lantern, (and original 2 prototypes)
The accessories i show in the video are listed below.
-Top hat reflector shade (for directing light down for overhead hanging, reading at a table, etc in the same manner as Coleman Lanterns shades do.
-Side directional shade ( for directing & increasing light in one direction to the side, (for creating a wider directional flood.
-paracord lanyard (for easier carrying, hanging from lines, branches, over head loops, tent loops, etc.
-charging cable (6 foot USB-C ( a heavy-duty longer charging & power cord for more remote charging & powering.
-Charging cable 12 volt direct Cig-socket ( for charging the lantern from 12-volt DC sources, like large power units, banks, car, RVs, etc.
-USB-C to 2.1x5mm adapter for 12 volt charging (adapter for connecting any of the common 2.1mm DC cord plugs to the lantern
-padded storage bag (for storage, packing in duffles, camp bags, etc. to protect the lantern from scratches, dings, etc.
-plastic wide base (To add stability & grip for uneven or angled surfaces
-Cap base for the lantern head when used without battery tube. ( to protect the driver contacts when using the lantern without the battery tube powered from USB-C sources.
-Accessory storage bag (for storing all the accessories.
I need to practice to record better videos, so bear with me in the video, also turn your volume up a bit, as my phone camera mic is not the best, and need to invest in a better video camera setup for these videos, and slow my talking down a bit.
Turns out this is a solar panel I purchased also from ebay, not the LT1. It took the seller a day to upload shipping info, so I will continue patiently waiting . . . .
The first product batch was no more than 500 allocated as 1 LT1 per person starting at the first entry. If you were not one of the first 500 people on the list, you were not notified of anything.
Batch #2 is expected to cover all remaining lantern requests.
I will want at least 3 of the full kits with cases if not more. Let us know when or if you start an interest list for kits.
The collapsible shade seems to be the most versatile and storage/carry friendly. If it allows the LT1 to be stored in the same case as the accessories, this is a plus as well. It also seems to grip onto the LT1 making it stable.
Does the collapsible shade work in conjunction with the side deflector? This would be my preferred combo.
I agree that the bottom cap should be screw on with O-ring for waterproofing and stability when used with base. It would be great if it could have a 1/4 x 20 threaded insert as well.
You might try to remove the foam from the center of the base to give the foam more grip per less surface area and make it more stable on uneven surfaces and less likely to wobble on high center. A ring resting on uneven surfaces is more stable then a flat disc.
We have approached Sofirn to see if they want to take on building the accessories kit for the LT1, and will certainly post updates to everyone as we get them. :+1:
