Then you’d have to go with incan lights. LED produces one color of the spectrum (monochromatic), while incan emits all colors, making them better to pierce through smoke and fog.
Uh, no.
Monochromatic means one wavelength… that’s what a Red LED does for example, at maybe 635nm.
Or a laser, for example 532nm for a green one…
But a white LED emits all visible wavelengths… in a different way than an incan bulb of course, or even the sun
He’s sorta right. The LED is very much just blue light. Only after it’s put under a yellow phosphor with a broad spectrum does it emit what looks like white light.
I have taken photos from behind the beam as well as far off to the side. The beam shots proved to me that a more neutral white (and I do mean an absence of color) shows best. This is, of course, what works for me, in my settings and usages. I throw away any emitter under about 4750 and over 6000K.
(And I use the best cameras and lenses I can afford. The shots posted of the water tower are using about $7000 worth of camera and lens)
Anyway, I get also very disturbed of the backscatter of cooler white emitters. My limit is around 4800K - and then, it HAS to be high CRI, because with lower CRI, there is more ‘angry blue’ in the LED output, which will increase backscattering noticeably. This is why I raised word for the 4500K 90 CRI variant of XHP35 HI (and of course 2700K and 3500K XHP35 HI 90 CRI would be also very welcomed).
And if someone would happen to make an E21A 2000K 95CRI thrower with over 150k candela, I would buy it in the same microsecond
These beamshots are very good, but they were not taken the same day, so temperature and humidity could have been very different. To really compare backscatter, we would need beamshots taken within minutes of each other.
Exactly, I would actually like those photos to be removed from this topic as putting them next to each other in this context might cause some strange opinions to form. I’m sure if pics were taken on the same day difference would not be as great.
Quoted my message above for reference. If a light were shining in actually clear air with no particles in it then cool light will scatter more. But my guess is that there is usually a significant particle density in the air whether it be fog particles or dust. Even if it doesn’t look very hazy there are a lot of particles. Scattering off of these relatively large particles is probably going to be dominant, and this type of scattering is not wavelength dependent.
Below are some pictures I just took. On the left is a convoy S2+ with smooth reflector and 2mm^2 white flat. On the right is another S2+ with smooth reflector but with a warm dedomed XPL. I adjusted their powers so their beam intensities were equal. The second photo is just meant to show the color difference. I lowered the powers to arbitrary values for the second photo.
It was not foggy out, but in the beam you can easily see very small water particles floating around. It is a 5s exposure. I think the amount of scattered light looks the same. So, again, if the air is actually very very clear the cool light will scatter more, but with any particles in the air the light will scatter a lot more, and it will be the same for warm or cool light.
We have a lot of road construction in the area so there are always dust particles in the air, sometimes so much as to almost look like snow. Which beam tint cuts dirt best?
And I guess my high quality high resolution back to back GT pictures were a waste of my time. Another one of many reasons I seldom bother to log in anymore.
While your GT pictures were valuable to show the beam was not diminished too much, they were not directly addressing the issue being discussed which was how much the scattered light from the beam diminishes the users eyesight.
Regarding the best light for dirt: if the dirt is, for example, very red, a light with less red in it might scatter a bit less.
