MF01 Mini / MT07- Mod/Upgrade - Copper Heatsink Cover Plate - 1st batch shipped - 2nd in production
288 posts / 0 new
man of light
man of light's picture
Last seen: 3 hours 39 min ago
In this thread I will provide some informations on my MF01 Mini / MT07 mod/upgrade. This mod is basically solve the thermal bottleneck of the MF01 Mini / MT07 and help to unleash its full potential.
For more and detailed information to this design issue please read this thread from Dr.Phillip: http://budgetlightforum.com/node/69962
In the post No.#25 I explained and introduced this modification and the idea behind it.
I used the results and findings of this first mod to design a further improved heatsink cover plate out of copper.
These copper heatsink cover plates are CNC machined and I am planning some production runs for them.
A first batch of 100 pcs. is already completed and shipped, the production of the second batch is currently on running.
For the latest news and status, see the comment at the end of this post #1.
In this thread i will share the information and everybody who is interested in getting one of these heatsink covers can mention his interest.
For those who have already expressed their interest, I will provide a overview in post #2.
Price per piece will be $15,00 USD or 13,50€ (2nd batch), Payment will be handled via PayPal (sending money to family and friends).
Installation description
Here is a quick step by step summary of this modification:
This plastic cover will be replaced:
by one out of copper that looks like this:
Additional stickers for isolation will be added, these are included, you don’t need to make them yourself.
Thermal compound paste have to be applied on the green marked surfaces. Basically you can use any kind of electronic/CPU thermal compound paste. For my tests I used Arctic MX-4, other types which costs less will work also fine. (If your not sure how to do this proper, search and watch Youtube videos how to put thermal compound paste on a CPU for example.)
Alternatively it is possible to use thermal conductive pads, that will work also fine with this heatsink cover plate. For information how to use these proper, please take a look in the post of ZozzV6 by following this LINK.
The Design was very accurately defined, so after fixing this heat sinking cover plate, the gap to the AMCs is 0,1 mm, this gap should be closed with thermal compound paste, so put a thin layer on the marked surfaces as shown above. There is no mechanically contact to the parts of the driver board except the big outer GND-Surface.
Important Note: Please pay attention to the right alignment of the heatsink plate to the driver pcb. Wrong alignment does not fit mechanically anyway, but in case of wrong mounting, a damage on the driver pcb is possible.
After mounting it sits like this on the driver pcb (Sorry for this bad pic, but it gives an idea of):
I will deliver it with a set of isolation stickers, it’s up to you whether you want to use this ones or something different for isolation:
After mounting.
After this mod, the AMCs and the GND surface of the driver pcb is very well contacted to transfer the heat to the flashlight body. The Battery tube is now also directly connected to this heatsink cover plate if it’s screwed together with the head, this was not the case with the plastic cover.
So there will be no throtteling down any more in any ramp level (also top ramp) till the host (body) of the light reaches the setted max. temperatur. On max ramp (in default config.) it takes about 5 Minutes till it reach the max temp (60°C) and begin slowly to step down.
A level around 1200lm can be maintained constantly (@amb temperature of 20°C), which makes the light very useble, see here.
Here are some results before and after the mod. I’ve done three runs before and after the mod, turbo mode, top ramp (in default configuration) and a run at an output level of around 1000 Lumen in ramping mode. I used a fully charged Shockli 26650 IMR 5500mah cell for the three runs. Thermal calibration of the MF01m was done accurately and the configuration was set to max 60°C (30 clicks in addition). The SST-20 4000K version, which I was using for testing delivers less output and more heat (at same brightness level) then the 6500K or the 5000K version.
Turbo Mode, before and after:
Top Ramp, before and after:
Ramping mode, output around ~1000 Lumen, before and after:
Lexel has done a thermal test of this heatsink cover plates, follow this LINK to see the results.
Here is the currently valid drawing for the production version:
Current status Jan.15.2020: 1st batch is done/shipped. 2nd batch is in production, 60 pieces, these will be available at the end of January, maybe earlier.
I will update this #1st. Post regularly with fresh informations.
Edited by: man of light on 01/15/2020 - 10:08
man of light
2nd batch in production:
The confirmed delivery date from the supplier is the end of January 2020.
I will inform everybody on this list via PM as soon as the payment can be done, a few days before possible shipping date.
Interested for the second batch 60 pcs.
No. BLF-Name Pcs.
1 panagis =1
2 Duke =1
3 sleasys14 =1
4 Dep668 =3
5 giorgoskok =1
6 olles =2
7 80T =1
8 dude3003 =1
9 maxiormchw =1
10 Kombatt =1
11 MoreLumens =1
12 Coscar =1
13 Nicko69 =1
14 YogibearAl =2
15 light_man89 =1
16 Quad-XXX =1
17 Smoothynobutt =1
18 Wieselflinkpro =1
19 psmbfuer =1
20 repeatog =1
21 LiteintheNite =3
22 Captain_Joe =2
23 quvantage =2
24 Helmut.A =1
25 gchart =1
26 Felurian =1
27 bexamous =1
28 Jasper Jones =1
29 Aspxhp702 =1
30 RS.Freak (TLF) =1
31 Hannes C (TLF)=1
32 Michael D (TLF)=2
33 mukenukem =2
34 PBWilson =1
35 Micha (TLF) =1
36 moonstone4 =2
37 deus1ex =1
38 Alvaro52021 =1
39 gecco =2
40 mihlit =1
41 gman7228 =2
42 Malenurse84 =2
43 freshnight =1
44 Chinaheart =1
45 AmericanDissent =1
46 Day_Light =2
2nd batch is full now, but I will continue to collect interests for the case somebody jumps off or the supplier will be able to deliver a few more pcs etc.
Further interests
1 Tarvos =1
2 elwood =1
3 dr.peyote =1
4 omegathai =1
5
6
7
Everyone, please check if it’s correct that you’re on the list, your name is written correctly and the number of pieces you’re interested to bye is right. Just PM me if something is to change.
id30209
id30209's picture
Last seen: 22 min 8 sec ago
 Interested!
WTB Titanium 4sevens Quarks & Jetbeam TCR1
oweban
oweban's picture
Last seen: 10 hours 4 min ago
Interested, but cautious of shipping costs.
gerasalex
gerasalex's picture
Last seen: 13 hours 7 min ago
A level of around 1200lm can be maintained constantly (@amb t20 ° C), which makes the light very useful – it sounds very tempting! $ 13.50 is the price without delivery?
"... God is light, and in him is no darkness at all..." 1 John 1:5 (KJV)
Skylight
Skylight's picture
Last seen: 3 hours 7 min ago
Why not use registered post instead of DHL? That is maybe cheaper to ship outside Germany.
alk007
Last seen: 5 days 3 hours ago
Interested!
Di_Joker
Di_Joker's picture
Last seen: 55 min 32 sec ago
Interested, but cautious of shipping costs (Russia).
Sorry for my poor english.
Flying Luminosity
Flying Luminosity's picture
Last seen: 1 week 5 days ago
Ich bin auf jeden Fall interessiert, hoffentlich ist der Versand nach England nicht zu teuer!
Miguel_79
Last seen: 1 hour 13 min ago
Interested.
Gerrit
Last seen: 1 hour 10 min ago
Interested.
man of light
Yes, shipping costs in addition,
I’m definitely checking this and will provide an overview of shipping options and prices later in the first post.[/quote]
ZozzV6
ZozzV6's picture
Last seen: 2 days 1 hour ago
Interested if shipping cost reasonable to Hungary
shirnask
shirnask's picture
Last seen: 1 hour 48 min ago
Still in – PM when ready
Vincent7
Last seen: 1 week 1 day ago
Interested
lamppu
Last seen: 4 hours 47 min ago
Interested!
man of light
Just updated the first post with shipping options and costs.
aginthelaw
aginthelaw's picture
Last seen: 7 hours 38 min ago
I’ll take one
never fear shadows…it means a light shines nearby
id30209
id30209's picture
Ready to send € but i’m a bit confused with shipping options... registered in EU is (should be) tracked.
man of light
id30209 wrote:
Ready to send € but i’m a bit confused with shipping options… registered in EU is (should be) tracked.
I’ve just call to the hotline of the postal service, and you are right, there will be a tracking number for registered postal. But my overview in the first post is wrong, the compact letter 50g ist not allowed to use for such shippings. I will update the overview now.
gerasalex
gerasalex's picture
1. How much heat loss or increase will there be due to differences in the materials of the part?
2. What is the price ratio between copper and other materials?.
Future Lights
Future Lights's picture
Interested for 1.
man of light
1. Aluminum will also works good enough, but copper had way more density, weight and better thermal conductivity, so the heat transfer is quicker. After some time the temperature on the Body will be the same with both materials.
2.The price ratio is not to big, 1-2 $ to aluminum. Most of the costs is caused by the manufacturing, machining, handling, supplier and so on. But I will anyway not offer another option than copper and maybe only this one batch at all.
christoph
Last seen: 1 hour 8 min ago
Cant wait to get one they look very good.No issues with shipping costs
C Big Smile
Chris
gman7228
Last seen: 1 day 14 hours ago
I’m interested in one (1). Nice work and thanks!
gman7228
There are 10 kinds of people in the world. Those that understand binary notation and those that do not.
gerasalex
gerasalex's picture
If this mod really solves the problem of overheating, I think many will want to buy it, we just need graphs and measurements in the maximum modes of the device.
SKV89
Last seen: 8 hours 26 min ago
Interested in 2
TexasToasted
TexasToasted's picture
Last seen: 27 min 47 sec ago
in for 2, please.
Skylight
Skylight's picture
I’m interested in one or two. This will make the copper MF01 mini even heavier! Shocked
man of light
Yes, I’m absolutely with you, such a test with temperature analysis, runtime graphs and so on would be very nice in addition to my testings so far. Unfortunately such analysis are not my expertise, so I would appreciate if someone of us who’s got the skills, tools and possibilities would do this and post the results here. I would send one of the first pre-production samples for testing if someone with the appropriate reputation agrees to do it.
So feel free to suggest yourself or someone.
Dr.Phillip
Dr.Phillip's picture
Last seen: 4 hours 16 min ago
Nice, so far they look great. Hope this works out and I get to play with them :). Will it be a straight plastic for copper swap or will we need to add washers and/or a bit of cpu thermal compound on those AMCs?
