Checkpoint
The CAD model is in no way nearing completion, but I need to check fit and function before going too far. Making changes to the foundation of the design at a later date can totally break the models. Ask me how I know.
It fits a bit loose, so I will be adjusting some measurements by feel. But overall it’s quite good. Onward!
The average voltage coming out of a 30Q cell when discharged at 15A is more like ≈3.35V, this means the average continuous power delivery rating from such pack is ≈500W, no more.
Interesting to see such an odd project, I like oddities. :-)
Good work i like it a lot. 20 in parallel could give you 10-12kw. Nearly enough to fire my brewery until the genset can take over.
It is a bad-ass little pack
Do you have a pic of your brewery somewhere? It sounds interesting.
World First!
I decided I wanted individual cell monitoring to alarm me if one cell in the pack reached empty before the rest. And I have some small pins that are perfect. To my knowledge, no hobbyist has ever made a fully functional 8 pin Dewalt-compatible dock. Until now. It wasn’t easy cramming all that geometry into such a tight space while leaving room for the .4mm print nozzle on the printer. But I did. Booya!
That sounds huge! Don’t get in trouble posting pics.
That’s some pro grade stuff there Grin
It was just a quick sanity check. I am planning a 200w build.
So, to clarify… This is compatible with the 20V MAX line of battery tools?
“individual cell monitoring” I’ll be interested in seeing this
I own genuine Dewalt 20v MAX batteries and genuine Dewalt FlexVolt batteries, and it fits them all perfect.
If anyone has trouble seeing images, please let me know. PM is good too. I’m doing it the most convenient way possible, but there are other options.
What is that?
That’s goals being met. The inside-out design is great. It’s light weight, has excellent passive cooling, and takes minimum print time and labor to assemble. There will be a “headlight” mounted to the left and right side. You may have seen or heard in my other threads that what I call a headlight is a ring I designed that mounts a CPU cooler to a tripod. In this case, 2 will thread on to the sides.
ooh, shiny!
Here are the headlight rings! The sanded/painted one sure looks more impressive than the unpainted one! This paint job meets goal #2. To “Outperform expectations on 3D prints”. It doesn’t look cheap now, does it?
Shiny
It doesn’t.
That paint job looks amazing.
Nice design chops JoshK. I like where this is going.
Intrigued subscribed
Ready for takeoff
After a break I am back on the project today. I will start wiring things up. This metallic paint sure is hard to photograph. Notice how different it looks in this pic compared to the last one on a sunny day.
