I have a little problem with FW Narsilm v1.3 on Lumintop GT Mini. Although my GT Mini has set down the brightness step when the temperature is reached and it works fine until I remove the battery, when I insert the battery, the light automatically returns to lower the light after 15s - 16s, it does not Remember my previous temperature setting. Would you please help me, I do not know if the problem I encountered was an error, a good feature because I installed it incorrectly. Look forward to the help from you!
Yeah, I’ve noticed that on a few lights running Narsil as well. I just figured that was the way it was supposed to work, or at least never implemented to remember the thermal calibration after battery changes. It’s a bit of a pain, but given that the thermal controls are s**t anyway, I prefer to just turn it off entirely, or set to a fixed time like 2 or 3 minutes. A fixed time seems to work well, as it only steps down once, and doesn’t waaaaaay overshoot the temperature on the downside.
If you use the calibration method, even if you set the light to be sizzling hot before it steps down, once it starts the step-down it continues until you’re left with about 100 lumens and never goes back up.
I have a lot of Narsil lights and they all remember the settings after a battery change. The thermal stepdown is really good as well. You must have had bad luck.
I’ve heard that on a rare occasion there will be a driver that has trouble maintaining the settings. I think TK said it was a bug.
This sounds familiar - must have been reported/discussed before. I don't recall ever testing it out, so yes, probably still there. Oh boy... I'll have to take a look.
Are you asking me if its driver specific? As far as I know, no, it’s not. It seems like one in out of every 500 drivers will have this issue. I remember at least a couple people have this issue on every Narsil light.
Specific to a specific driver, or a driver design -- I was just saying in general, either/or.
For the particular flashlight this doesn't work in, wonder if any config setting changes are sticking after a battery disconnect. Only issue I see is maybe not disabling interrupts while writing the value to EEPROM. I'll have to check what others (TK) is using for EEPROM writes and reads, and if interrupts are always being disabled. To do the read I'm using the AVR library routine, but for writes, I use our own routine.
I have two Astrolux S43’s that have the issue. I doubt they are both suffering from a random bug, so it must be on all S43’s. I haven’t checked the FT03… I think it runs Narsil if I remember. BLF Q8 runs an older version of Narsil, but it has a timed step-down, so probably doesn’t have the issue. I could check my FT02 as well, I don’t remember if it runs Narsil or not.
Anyway, it’s not a big deal. I much prefer the timed step-downs in Narsil, since they don’t overshoot.
It may be running an old version of the code, because there was a bug where it could sometimes forget config settings. If I understand correctly, that was fixed in Tom E’s upstream NarsilM, but several lights used older versions or derivatives of older versions, where the bug still exists.
I’m not sure which versions are used on which lights.
According to my shared NarsilM builds/releases here on a google drive share, S43 and the original FT03 is using v1.1. Dunno - the new blue FT03 XHP50.2 I have right now in my hand blinks out v1.3.
I'm pretty sure the GT Mini went out with a "good" v1.3 that originated from me.
This doesnt sound like the bug that doesnt remember settings, not if it’s just the one thermal setting that it can’t remember. The memory bug I’ve heard people talk about basically didn’t remember any changes.
Did it actually remember the temperature setting and only loose it after disconnecting power or did it not remember at all?
(The S43 is a bit unique because it can heat up so darn fast. The key is make sure it’s not already warm on the inside when you go to set the thermal limit. I make sure it’s not been used for an hour at least, then I use a fully charged cell and run the thermal test. This works everytime on my Narsil lights. Some people use the light previously and it gets warm inside and they don’t think about it, then they set the temp limit and it ends up being off.)
I can’t say for sure what the issue is, but it sounds exactly like the old memory bug. It would forget things at random… even just one or two things. The reason it was initially found was because Hank of Emisar noticed that the D4 prototypes would sometimes forget their thermal configuration. Then later it was discovered that a different old Narsil light would sometimes forget things too.
So I rewrote that part of the code for Emisar, and sent Tom info about the issue including a patch. He fixed NarsilM, and since then, the issue hasn’t come up much.
It was really easy to miss since it usually worked, it was only noticeable after a battery change, and it generally only forgot a little bit at a time when it failed. If I recall correctly, lots of people used it happily for more than a year before anyone noticed.
Yes, it remembers the temperature setting as long as I don’t disconnect the battery. If I use the micro-USB to recharge, then no problem. If I take the battery out to recharge it, then it reverts back to the default temperature setting (which is too low, IMO).
All other settings are remembered across battery changes, at least the ones I’ve reprogrammed (maybe half-a-dozen of them).
I thought maybe it was a safety thing or something. But since I can turn off temperature step-down entirely, and it is remembered, I presume not.
Oh boy, I forget more than I can remember (I was born in '57...) - but I do recall something of this, just not exactly what the change/bug was? TK - do you recall? Thought it had to do with interrupts maybe?
I changed two things. I’m not sure which one actually fixed it, or if it was both together. Those two things were: Turning interrupts off during eeprom access, and using the library functions.
Sorry, I haven't been keeping up with this thread for a long time. I just updated the OP. Over the last couple weeks I'm getting bombarded with emails from the google drive service to grant individuals permission to access various Narsil and NarsilM files, mostly the manuals. Apparently google has updated their links to increase security and made the old links broken/obsolete, but they allow the requestor to get an updated link from the publisher individually.
So, I updated all the link in the OP. Unfortunately I don't know where people are clicking on my google drive share links, but if they are coming from here on joechina's thread cheat thread, I can't update those links - only joechina can and he hasn't been on for 2 1/2 months I'll post there and pm him. When I get a chance, I'll look around further. Thought there was a NarsilM V1.3 manual somewhere - can't find it, but really there was no changes effecting the manual in v1.3 or v1.2 (probably v1.1 as well).
