【convoy】H4 and B35AM options are updated
yes ,after China spring festival
Simon, will the upcoming biscotti in 22 mm driver work with nichia? I have the S12, nichia-5700k. It’d be great if this will work with it.
yes, suitable
The differences between 30, 50, 70 and 100 are too small.
Especially 50 - 70 - 100.
Even from 50 to 100% is a very small step to the eye.
Or did you mean ideal for people who like to pointlessly cycle through modes? :stuck_out_tongue:
Our brightness perception is not linear with the current, but heat and runtime are. So it is useful to have more modes in the upper brightness region in order to maximize the sustainable brightness for your particular ride duration. For example, for my 1.5 hour night rides I might want the max brightness for my S2+ with 8x7135 driven XPL, which would be about a 70% mode. Of course it will still be difficult to have a mode set that works for everyone and every light.
Oh okay. Thank for explaining.
The LD25 driver would be good for cyclists then, since you can set all 3 modes individually.
…but it’s only 3 modes though… (plus strobe).
By the way, i’m currently running an 18650 10 Watt light on my bike, with an LD25 driver, which is not adjusted (yet).
But i think the middle mode is 50% and it’s just not worth it i.m.o. to have a mode in between.
What i can do though, is switch to 100% when needed, because i normally run it on 50%.
But it’s not a big difference to the eye.
(To me it would seem sensible to have 25 - 50 - 100 % for a bike, or maybe 18 - 35 - 70 %)
Hey Simon when will the new biscotti drivers be for sale?
Know what? In Italian language biscotti is the plural form of biscotto, which means cookie/biscuit. Thus…
Biscotti!
https://www.bbcgoodfood.com/recipes/1580654/millies-cookies-recipe
several days later
In Biscotti, the default 5 levels are 0.1, 1, 10, 35 and 100%
On a 7135x8 = 2.8 Amps, this results in approximately: 0.003A, 0.028A, 0.280A, 0.98A and 2.8A.
For the SST40 version, what is the 100% Amps value? 5 Amps or 6 Amps?
Also, from what I understand, the original “Biscotti” driver does not have temperature protection (unlike “Bistro” firmware), so my question is this “Biscotti” for SST40 an adaptation of the original “Biscotti” driver — what I mean is, it tries to follow the similar brightness levels of the original Biscotti driver, but is not the same “Biscotti” driver?
Sorry if my question sounds confusing.
The firmware called biscotti is just flashed into that driver, so same functionality, other current output.
The max output differs from the 17 mm and 22mm, the 22 standard delivers upto 6A, where the 17mm maxes out on 5A. Also a 6A might be available.
Playing with sense resistors might help allowing to change the max desired output current (up to 8A)
I’m also wondering how it’ll go re: reflashing - I wouldn’t mind making some custom levels for it.
All the links to item pages are broken.
Edit: Never mind, it is an aliexpress problem. All item pages are broken.
Simon’s shop is closed for about a month.
Iirc he did this before, taking down everything.
(not this time though)
Happy holidays, Simon. :+1:
max 5A, it still has temperature protection
There were some C8+ on neals briefly with white flat 1 and I’d assume 5A driver - missed them, damn! Would be good to make one with either WF1 or WF2 (WF2 can handle more current IIRC, could do a resistor mod…)
Owen
It really depends what you’re looking after, a larger diameter head will give you a lot more throw, i have used a white flat in a C8 and placed it in a L21A later on, but the L21A gives a lot more throw with the same emitter (it is also driven harder now)
I really should make a mock-up of how big those lights are…
Question and suggestions (for Simon and/or anyone else).-
What are the actual (modder and tinkerer) differences between the classic 26650 L2 and the 21700 L21A? As far as I know, the L2 fits all 26650s, including the slightly wider, market leading Power Long Battery cells. However, I heard somewhere that the L21A has problems with some 21700 cells, i.e. the tube is too tight. If this is so, I would ask the machine shop to slightly widen the internal diameter of the L21A tubes (to ∅21.8 - 21.9 mm), modifying the drawings in the process, this way the L21A would be more appealing and trouble-free. Tip: Lishen cells are the widest I believe, at ∅21.7 mm with a single wrap, see just below:
Both fit ∅22 mm drivers with a little bit of filing, ∅21.5 - 21.6 mm driver bay. Don't know how deep is it but I guess very powerful buck or boost drivers can be used. 21700 extension tubes may appeal to someone.
