This titanium spare cell/ pocket charger, being modular can carry and charge 10180, 10280 and 10440 cells.
It has a 100mA charge rate.
Made from a DQG titanium pill capsule & extension pieces plus a charger unit from a 10180 rechargeable flashlight.
The section with the brass rings can be removed & used to extend the laser to use a 10440 cell and the remaining sections will still house the other 10280 cell that the laser normally uses.
And it easily hits a hay barn at 1.02 miles distant…
I tested it with Samsung 18650’s, both 35E and 25S, it makes from 4300 to 4800 lumens and a quick 5M test (too close I know but it was still daylight) shows 1.71Mcd!
Edit: Worth mentioning that the beamshots here and on the write up were done using the 35E cells at lower output. I have new 25S cells arriving today… the ones I tested with have been, well, Ham’red!
Today I put a Oslon HX Boost HL in my GT Micro. I had bad luck getting a good focus, but it still more than doubled in throw compared to the XPL-HI NW.
It out-throws the FT03 with 50.2.
Another Jet II MK. Ladies and Gentlemen, this is my very first reflow
Some time ago I modded my C8 (SMO to OPR and XP-L Hi to XHP50.2, A6 driver) and was left with a very nice XP-L Hi U6-4C MCPCB. Now this LED resides on the original board of the Jetbeam. I’m really proud .
Added a bleeder resistor (stock tailcap works ok without one, but not my custom tailcap - it needs a dependable current path). Used a 0603 footprint 750 Ohm resistor stacked across the main capacitor (see the yellow circle in the picture).
Swapped the black tailcap for a very light green GITD one (link). The only problem with these is that they don’t have a “nub” inside, so you really need to press in order to activate the switch. To address this, I put a dab of clear silicone caulk in it and let it cure. Works great now. This lets a TON more light through than the stock black tailcap.
Stripped the stock illuminated switch board, which is a similar set up to the Convoy add-on illuminated tailcap that utilizes a clear plastic washer to let the light get to the tailcap (albeit, somewhat inefficiently).
Attempted to strip the gold clip, but failed. After a 30 minute bath in a strong lye solution, the coating didn’t budge at all. It probably is real gold plating. It’ll stay for now. I’ll probably either just remove the clip or grab a stainless one from another light.
