6000mAH has unconventional size
Barkuti:Question and suggestions (for Simon and/or anyone else).-
What are the actual (modder and tinkerer) differences between the classic 26650 L2 and the 21700 L21A? As far as I know, the L2 fits all 26650s, including the slightly wider, market leading Power Long Battery cells. However, I heard somewhere that the L21A has problems with some 21700 cells, i.e. the tube is too tight. If this is so, I would ask the machine shop to slightly widen the internal diameter of the L21A tubes (to ∅21.8 - 21.9 mm), modifying the drawings in the process, this way the L21A would be more appealing and trouble-free. Tip: Lishen cells are the widest I believe, at ∅21.7 mm with a single wrap, see just below:
Both fit ∅22 mm drivers with a little bit of filing, ∅21.5 - 21.6 mm driver bay. Don’t know how deep is it but I guess very powerful buck or boost drivers can be used. 21700 extension tubes may appeal to someone.
new batch has 22mm inner diameter ,dont worry
I can confirm that, the new tube diameter is 22mm and now a Shockli cell fits.
Also the tailcap is shorter
What about the S21A? Is there a new batch with more diameter?
The S21A from the later batch (at least the one I bought about a month ago) can accommodate the Lishen batteries now.
Simon, is there a possibility to buy just the pill with mcpcb screws and driver retaining ring for S21A?
Send him a message on AE after CNY, he will help you.
Cheers
I've been interested in seeing the SST40 driver with biscotti firmware making it to the Convoy Store for ordering
The Convoy Store on AE has message that it planned to open on or about February 10th,that's tomorrow.
I think the odds are on it getting delayed further,maybe a couple more weeks
It doesn't look good in China yet.
Hi Simon.
Any news on the Biscotti 5 amp (sst40) 17mm driver?
Thank you.
I don’t remember if it was posted before and it’s difficult to search on my phone - is it possible to get that flat-top adapter for the 4X18A by itself? Would be hugely helpful and far better than me trying to solder little copper things onto batteries.
Hope all is well over there.
+1 on that! Id like to buy a few of those plate adapters as well.
Would be super helpful for other lights like the BLF Q8
Hi Simon. Will a flat-top battery adapter be available for separate sale? [image] [image] Do you have plans to create a flashlight with 3*XHP50.2 or 4*XHP50.2? May be 3*XHP70.2 or 4*XHP70.2? but the adpater is only suitable for 4X18A, i think you can not use it on other flashlights i will design those models at next spring. currently ,i’m too busy
Cheers, was having trouble looking through
I’ll make it work on other lights!
Hi Simon.
Thank you.
it’s in stock now ,
if you need it ,you can order the 4mode version ,and note “biscotti” in the remarks
Nooner:Hi Simon.
Thank you.it’s in stock now ,
Great news! I was waiting for this! :+1:
Just curious. Will copper pills be finally made for aluminum hosts? Simon mentioned a run was to be produced long ago, but looks like the thing got frozen. :???:
There are more than enough enthusiasts around here to guarantee sales of a nice batch of copper pills for alu hosts/flashlights, in my honest opinion.
Simon Mao:it’s in stock now ,
if you need it ,you can order the 4mode version ,and note “biscotti” in the remarksDo you plan to sell 20 mm biscotti drivers?
Simon, your Attiny 13 drivers with biscotti firmware has a common know problem: when change modes rapidly (quickly), this driver spontaneously goes to programmable-mode.
Do you FIXed this problem in your new 6 Ampere biscotti drivers?P.S. Even TK was spoken about this problem in your Attiny 13 drivers.
You have a funny nickname! Welcome to BLF! And hello to you from Russia!
zaxar0580:You have a funny nickname! Welcome to BLF! And hello to you from Russia!
I don’t see anything funny in my name and surname!
I was named after my grandfather, who unfortunately died last year. He has been fighting cancer for the past 5 years. And could not win this battle …
I sincerely regret Friend, that your grandfather is not with you! And I didn’t mean to offend you! We are from different countries, although I thought you were Russian! So Google translator is to blame! :person_facepalming:
BLF is a worldwide community Pizdosina, and you must understand our names can sound very different for people of different cultures. I just used the DeepL translator and “Pizdosina” translates as “coño/pussy” from Polish (Polaco) to spanish/english. Go figure!
