Added comments to my order, thanks!
(changed main module and extras)
added modules and lenses to my order #24. PP payment sent.
Hey clemence I don’t know if 808Hi actually has two orders or just one but I believe order #24 is mine not his. Please move the modules to order #23 and change the username back to anonymous_user. Thank you.
Confused here. Let’s continue by whatsapp. I sent you a PM
[Clemence]
Extended GB Listing is now closed. Thanks for all the orders.
Please DOUBLE check the Gsheet and confirm everything there.
[Clemence]
I see you updated my main LED but not the extras.
done!
I don’t see my 3 x 2000K + 1 x 3000K E21a H04 on there yet.
Thanks for being around for the last minute add.
Glad I didnt miss this. Payment sent!
Done
There was a problem for the #23 and #24 listing. To avoid complication and sacrificing #25, I opened up one more slot for the first $60 because #23 bought 2 pcs while I confused if it was #23 or #24. All settled now, waiting for #23 to relist his order.
[Clemence]
Bad news: “…I am currently out of the office on holiday.
Since the outbreak of Wuhan, our holiday will extended to 2020-2-17….”
Good news: GB listing extended for another 7 days until further notice
[Clemence]
Are there any good hosts for E21A (or E17A) modules?
Pretty much anything that will take a 16mm MCPCB as I understand it.
I plan to get some E17a quadrix to file down and put in a few Tool AAs but a Convoy S2+ or similar is probably the easiest for E21a
Would an E21A module fit in a FW1A? As it’s a quadrix I assume it should be able to handle the amps, especially with a GA/35E cell?
I was thinking about doing the same thing and using the FW3A bezel with a pebbled TIR but Clemence advised against using an FET driver with E21a
The Armytek Prime series “XP-L” are pretty good and very reasonable with the BLF35 discount code.
Is there a chance to offer a short tube compatible for H03 and H04
It would be great if Skilhunt makes an 18350 tube for the H03/H04. I would get one as well.
They are really lightweight even with the 18650 tube. I would probably never use the 18350 tube . . . Although that wouldn’t stop me from buying a few.
