Guess I’ll have to re-order while USA stock is available. And figure out the other order after.
If ordering thru Amazon — It’s with batteries and there is a limit of just one.
Are there any codes for ordering on Amazon ?
I don’t have a code to try but I did try and order more than one and I got a disclaimer message stating that I could order only one.
I sent a PM through BLF a week or so ago, and I’ve just sent a message through Amazon as well.
Hopefully I’ll receive a response soon. I ordered through Amazon.ca but they’re out of stock through there, and I’ll have to pay shipping to get it through Amazon.com
My Missing LT1
I just sent a message to Sofirn through Amazon.
whopist
Hope you get similar news as me
Mine is still missing. According to 17track (after I found someone that could do a proper translation), mine was returned to the shipper due to an invalid delivery address. It’s the address that was provided by Amazon and has not changed. I’ve already received my first LT1 without issue, to the same address. This second one for whatever reason was returned without even entering the US. USPS and Amazon still show no tracking updates since Jan 3rd. The last update on 17track is Jan 31st. Amazon has updated their delivery estimate to March 3rd.
I had sent a private message through this message board to Sofirn a week ago, but have yet to get a reply. I realize that CNY was extended due to the Corona IRC’s situation, but as I understand it, businesses should be back up and running by now.
Has anyone gotten any (preferably those with missing/late/lost packages) replies from Sofirn over the past week?
My missing LT1
Well finally some info from Sofirn!
This reply from Sofirn came through Amazon:
“Hello Jerry,
Sincerely sorry for the inconvenience cuased. And yes we have noticed the issue as well. Honestly, we find around 8 packages which all the LT1s without new shipping information from 2019 12-21. And we have contact the shipping company to work with this as well. And they told me it may take times to them to fnd the package from one place to another. And ask us give time to them to solve the issue.
Sincerely sorry and please do not worry and we will definitely let you lost the money , if the shipping company getting back to me and conform the package lost we would like to refund or replace as soon as possible.
We are working on this as well , honest, we will check all the order that we shipped around 1.5month later to make sure all our customer receive the package.
Sorry again and please give the post office time to assist us check your package. I feel very upset about this as well, as i know you guys have long time waiting for the lantern.
Zoe”
I just popped 4 brand new, never used never charged cells into my 2nd Lt1 that just arrived and plugged it in to charge expecting it to take a while about after 2 minutes the switch turned green!
Batt Check is cycling through different voltages - 3.6,3.6,3.9,4.2, are those the individual cell voltages and if so I don’t know how 1 cell charged so fast, maybe its defective??
Battery check reads the cells as a group connected in parallel. The cells power the light in parallel, the cells are charged in parallel. There is no way each cell can be read individually, except for removing them from the light.
What was the voltage reading on each individual cell before they were placed in the light? Don’t assume they were the same just because they were newly acquired. I don’t know why you should get a sequence of reading like that unless it has something to do with unequal voltages between the newly inserted cells. Tossed into a light like this, cells with unequal voltages will cause current to flow from the higher voltage cells to the lower. That may cause voltage reading issues, but I can’t say for sure what we would see the Batt Check doing.
were the cells flat tops or button tops? (the voltage batt check should read only one reading. use a volt meter if you have one to check each individual cell, it seems that three of the four cells were not contacting the top positive ring, or somehow not connected in parallel as all four should be.
Also, I have a Samsung USB charger that says the output is 5.3V (2A),presumably that’s fine to use?
Thanks so much. This forum and lantern is awesome!
good point on the flat vs button top question
Batt check gives a reading and then keeps running repeatedly unless the button is clicked once. Is that what you mean by stating the voltage rreading changes. ?
Thanks they are button tops. I measured with multi meter and 3.57,3.58,3.58,3.59.
I popped them into my 3rd (got 4 in total) Lt1 and BattCheck gives consistent 3.5. Put them back into 2nd Lt1 and it now gives consistent 3.6.
Not sure why the slight discrepancy but at least it’s giving consistent reading now.
Thanks so much for the help!
I am happy if two different lights give a reading within a tenth of a volt.
My batch 2 LT1 under reports the voltage by 0.1v, it it charges perfectly to 4.2 so doesn’t really matter. Toy keeper said the voltage reading is commonly out by 0.1v on these driver chips, but as the charging chip is independent it doesn’t matter too much.
it just repeats the same reading it gets from the battery ring.
good to hear the issue is fixed, it was likely some false reading or connection, (as in the body not tightened enough to make a good continuity is one possible cause.
228 Oring - Imgur: The magic of the Internet
137 Oring - Imgur: The magic of the Internet
- fits a lot better than 228 with some positive retention, cannot come off that easily but Id want it tighter. I am thinking of trying 135 Next.
small update, O-ring size #135 Fits great, I installed one top and bottom. Imgur: The magic of the Internet
