Found a Tri-Flupic Driver in my drawer, what to do with it?
5 posts / 0 new
AlexGT
AlexGT's picture
Last seen: 9 hours 36 min ago
I found an old Goldserve Tri-Flupic Driver in my moding drawer, for those of you who don’t remember or are not familiar with it, has 3 channels and lots of modes and can drive up to 3 leds at 1.2 amp each, I have a 26650 mag ready to mod but I am undecided as to what led to use. I see 2 options and want suggestions
Option 1: put the 3 channels in parallel to drive a XM-L at around 3.6 amps in a Fivemega throwmaster with a modified extra deep reflector I got from DX
Option 2: Put 3 XP-G’s in 3 smaller reflectors like the Regina that offer about 5 degrees collimation to each led.
The question is, which would be brighter and be throwier 3 XP-G’s at 1.2Amps or 1 XM-L at 3.6A?
Suggetions are welcome.
Thanks
AlexGT
MosesM
MosesM's picture
Last seen: 1 week 3 days ago
From my experience with ~50mm XM-L throwers and triple XP-G/Es, I believe Option 1 would throw further.
With that said, everyone and their uncles now have a big XM-L thrower (read: boring!) and I think you should save the driver for some XP-G2s Smile
scaru
scaru's picture
Last seen: 2 years 12 months ago
MosesM wrote:
From my experience with ~50mm XM-L throwers and triple XP-G/Es, I believe Option 1 would throw further. With that said, everyone and their uncles now have a big XM-L thrower (read: boring!) and I think you should save the driver for some XP-G2s :)
A XM-L would almost definitely throw further but the XP-G would probably win in the lumens department. I would proably just go with the XM-L even if it is fairly common they work well. Smile
DARCANGEL
DARCANGEL's picture
Last seen: 3 weeks 2 days ago
My vote is option 1,3.6amps to a xml will give you the most throw and the F.M. host should handle the heat nicely.In my projects,multi-emitter lights are lacking in throw but are great flooders even with narrow optics.Depending on efficency of the driver and other losses,you can expect just under 800 lumens.
AlexGT
AlexGT's picture
I think I will go with another XM-L Thrower since I also have a 65mm dia. by 63mm deep smooth reflector that pwns the custom throwmaster XM-L reflector that I already have.
That way the only thing I need is just some filing to make it fit. here is the pic of the Frankenthrowmaster light,I will update when I finish the project.
I might Chrome or Cerakote it when I’m finished and if it turns out ok.
