Good, resolved :bigsmile:
Were they this good even back then? So far I can’t find another battery like that. All the other ones except new 4.3V+ seem to drop voltage much more compared to the Sanyo 2600mAh.
HKJ: the size of the ZT 2800 you tested is with protection right? Because it does not seem big unprotected nor is anywhere said it’s bigger. The bigger length is probably due to the big button top and a protection PCB on your particular version that uses this ZT cell.
Sorry, I do not have time just now (I am leaving for a party now), but it is mostly small TrustFire and UltraFire, there is also a TrustFire 26500. In a few days I receive a pile of Efest batteries (again).
Now they advertise it as 2800mAh and the description you have on the test seems copied from the 2600mAh version. At first I thought they’ve sent you a wrong battery when you wanted to buy a 2600mAh FM. They probably updated the info and title now.
Generally, undercharging will extend the life of Li-Ion cells. Not discharging to the bottom has longevity benefits as well.
I ordered 5 packs of the Sanyo 2800ZT cells and will post my test results when I have them.
I noticed that both batteries are equally cheap at FastTech and I was about to ask the same question.
I need batteries for caving lamp. The common scenario would be that upon my return from cave the batteries will most likely not be depleted. I’d clean my gear and put batteries charging so the light is ready in case I need to go in a cave unexpectedly (cave rescue). Sometimes they would be left fully charged for weeks or a month. I believe that the 2800mAh 4,3v Sanyo would be less affected if stored charged at 4,2v and have the same capacity as the common 2600mAh 4,2v Sanyo.
The ideal storage voltage is around 3.75-3.8V. The worst case is fully charged; over time this will permanently increase internal resistance and reduce capacity.
For the ZT cells, storing at 4.2V should be better than storing at 4.3V.
Can we guess how much capacity the ZT loses when only charged to 4.2 or 4.22 V? Will it perform like a 2200 or 2400 cell? The graph above indicates that the cell is only ~90% true to it's capacity when charged at 4.3V which would already make it a ~2520 mAh Cells... minus the capacity loss due to premature charge stop due to most chargers cutting of at 4.2V. Can anyone take an educated guess?
