is the batt+ contact on the driver raised? if so, how much?
Nice, nice indeed (except packaging) any plans in taking it apart further?
Yes, it is raised. It is a bit hard to measure without my depth mic, which is in my shop, but with a caliper it is approximately .065”. I can get a precise measurement tomorrow if you would like.
Jim
no, its alright. just wondering if the pics were playing tricks. they arent
At present I don’t plan to. Physical mods I can handle, as I have the equipment in my shop for that (lathe and small milling machine), but I haven’t gotten into electrical mods and precision soldering .
I would love to up the output slightly, since this seems to be a worthy platform. Maybe I can find someone with electrical skills who wants to play with an M6 :bigsmile: .
Jim
that lathe looks like in brand new conditions, I would love to have something like that
please, put some more pics of your work
im hoping that a simple resistor mod could be done on it. hoping even more that texaspyro gets his SRK driver out soon, and that will be going in mine
did anyone checked how much amps it pulls, I would be interested to see how much it pulls from only one battery!
Mehhhhhh…. Full cycle to shut the light off is a MAJOR buzz kill for me… I always always always hate it. Dont even touch the costco light because of it.
Why would anybody want to have to click the button 5 times to get to off….Stupid |(
press and hold for 3 seconds i think will shut it off
+1 EZ as pie.
I read that but still. Cant stand it.
I feel I am going to recieve this light not use it more than a handful of times. Or wait for Texaspyros driver.
I didn’t want to get too far off topic here, so I started a thread in the OFF Topic Chatter forum titled A Few Machining Projects . https://budgetlightforum.com/t/-/20491
Jim
Are these proper seconds or just counting ‘one, two, three’ in your head?
It seems like 3 full timed seconds would be a long time, but I often read descriptions that say ‘hold for 2 or 3 seconds to turn on/off’ or switch to strobe or something, and in reality it’s more like 800ms or 1 second.
I don't know... Haven't got mine yet
Ok, hopefully both of ours will turn up soon with no smashed lenses!
I think 3 seconds is right on..(just measured it with a kitchen timer (no milliseconds)
Yep, 3 seconds is right on…
I ordered two. They came in today, un-announced. USPS still says they are in some California sort facility. The box looks like it was sat upon by a herd of overweight elephants pregnant with quadruplets. Lights survived the elephant attack intact.
Tossed one into the Sphere ’o Many Mysteries:
High: 1900 lumens, 7.4 amps @ 4.0V, 6475K
Med: 1064 lumens, 3.9 amps
Low: 257 lumens, 0.8 amps
Strobe: 10 Hz
ALL modes, including high, show 615 Hz PWM.
Parasitic drain is minimal (< 3 microamps).
Here is a plot of a run:
After around 9 minutes the light was at 1800 lumens. It then stairstepped down in intensity over a couple of minutes to around 1300 lumens. It was at 52 degrees C. I don’t know if the rampdown was due to temperature, time, or voltage (I suspect that it was time).
At around 90 minutes the intensity started dropping as the battery voltage started dropping below the regulation point. The light was at 70 degrees C (toasty!).
After 2 hours the light level started dropping off the cliff. It stopped dropping at around 24 lumens. There was apparently no low-voltage cutoff. The cells were at 2.7 volts and only one LED was lit and it was flickering. The light stopped responding to button presses and would not shut off.
Thanks texaspyro!!!
What batteries did you tested ?
