hmmm, do you have an old electronics that you can harvest resistors from?
The "R" is a decimal when shown. So each of your R160's are .16 ohm resistors. Parallel resistors reduce resistance. So 2 R160's create .08 ohms resistance. If you added an R082 (.082 ohms resistance) on top of your existing resistors, you would get a combined resistance of .04 ohms (rounded). That would theoretically double your current. I say theoretically because other limiting factors may get in the way.
What I do is measure the tailcap amps, say for example you get 3A with the two stock R160's.
Using Ohm's Law (V=I*R), solve for V: 0.08 * 3 = 0.24v
So, add one more 0.160 ohm resistor, you get: 0.0533 ohms, solve for I:
V = I * R, 0.24 = I * 0.0533, I = 0.24/0.0533 = 4.5A
So if you desire to get 4.5A, you would need to add another R160 or equivalent (50% bump). I say equivalent, because you could add two R320's which is the same as one R160. To go more mildy, you would add a higher value resistor instead:
So, adding a 0.200 ohm resistor (R200), you get: 0.057143 ohms, solve for I:
V = I * R, 0.24 = I * 0.057143, I = 0.24/ 0.057143 = 4.2A
So, adding a R200 resistor will result in a 40% increase in amps. Pretty easy? Don't you just love when the math works? I've done this stuff before and it comes out exactly with the bump I expected....
I received an MX900 yesterday. The newest warsun model is called MX900 find6. I love the feel and look of the light. Much better feel versus convoy L4. The side button has a nice machined chrome look to it. The output is lacking with a single 18650. It looks as if it was designed for max output with 3x18650. I only got 1.15amp at the tail with a typical samsung or trustfire 18650. I got 1.5 amp at the tail with a single panasonic ncr18650pf. maybe the driver spring has high resistance? I got 1.8 amp with 2x18650. I didn’t have the third link to see what it does with 3x18650. This light is definitely underdriven. It needs a good boost for the single 18650 format because i won’t be running it in the 2x18650 or 3x18650. The black led isolator definitely blocks some light. I got a little better output without the ring. I will be in touch with the manufacture and hopefully they can make a few changes to this light.
The back button and side button both control or cycle through all the modes. The neat part about the side switch is that when the light is on. You can hold down the side switch for 3 seconds and the light goes off. Then it is in standby mode. You can instantly turn the side switch back on and take over control of the light with the side switch only. Kind of hard to explain. I will definitely see if Warsun can eliminate the sos and make the strobe hidden with a fast double click of the side switch.
This is a solid light and was designed with heat sinking in mind. Appears to have a good thermal path to the body. The green water seal that wraps around the lense is a very unique design.
@ImA4Wheeler and TomE: Ok guys, I just looked around and I have R332, R499, 5L0F, 221, 101, 5R1, 1R0... on all the junk pcbs I have stashed. Can I use any of these? If not, then maybe its time I order from digikey a resistor bundle pack.
@phsinvent I agree this light feels amazing in my hand, and quality is very good. On my Build Quality Index I give it a 98% up there with my Solarforce! What would you rate it from 0-100%?
Anyways, I already asked the manufacturer to make the following changes, we'll see what he says:
Give me a STAINLESS STEEL BEZEL, and possibly a stainless steel tailcap!
A 3.5A driver inside, if they can't do, then give me the LD34 driver in the convoy L4.
Power button to glow blue while on, and red when low battery at 3.25V
remove the black plastic piece around the LED, replaced with a low profile white insulator!
If i had to be picky. I would give it a 80-90%. I can see a few machine marks on the end bezel silver piece. And there are a few spots on the tail cap that have sharp edges that needed deburred.
1. I doubt they will want to do a stainless bezel to keep the cost down. But a stainless bezel would be nice.
2. Remove SOS and hide the strobe. It’s just too much nonsense to cycle through. Also, I don’t think I could detect any PWM like I can with solarstorm lights.
3. Boost output of the MX900 Find6 in single 18650 format. 3 amps or higher would be nice. I wonder if the CT9T has better output and a different driver. Did you try the CT9T in single 18650 format? I don’t think the CT9T driver would have the big torroid on the driver.
4. Definitely a new low profile led isolator. The current black one blocks a lot of light.
5. I agree 100%!!! A blue led light for on would be superb. And keep the red low light indicator.
6. Possibly better springs for resistance purposes.
7. Flat anodizing with less shine or gloss.
8. Maybe better XM-L2 tint, mine came as cool white. A little more neutral wouldn’t hurt.
Wow, I must have got a lot nicer batch than you. My MX-900 is almost, if not flawless, except for the glossy-ish anodizing.
The CT9T and MX-900 on single 18650 are comparable, but MX-900 seems slightly brighter. On 2x18650 in the MX-900 it's noticeably brighter than the CT9T.
The CT9T I have has a very flat finish. Mx-900 definitely glossier.
I also forgot to email him about the modes. After thinking about it, the only true culprit is the driver to me, and the black insulator piece.
Hey blf. You would need a lot of those resistors to bring up your current much. How risk adverse are you? You will be risking an emitter if you try this. Place a solder blob over one of the resisters. Will be more resistance than a copper wire, but not much more. So you will be close to max current (what ever it is) that that drive can deliver. I have hunch that driver will not deliver a ton of current at max, but I'm an amateur.
Will a driver still put out a certain current amps etc without and led being connected? I wouldnt be too afraid to run this driver at max current because i am only getting 1.2amp with a standard single 18650. 1.6amp with panasonic ncr18650pf.
I have a feeling that the stock led is xm-l2 t4 or t5. I had a slight boost in output when i switched the led to old school xml u2. I accidently ruined hazed the xm-l2 dome when i tried to clean it off with solvent (n-butyl acetate)
@ImA4Wheeler I'm going to go big and do the solder blob, and if not happy, remove all the resistors and just copper bridge, but I will swap the LED to an old XM-L that I have collecting dust, just in case.
@phsinvent Pray for me!
I will also try to do some tailcap readings of my results.
Good idea on the sacrificial (hopefully not) xml. At least if it does fry the emitter, that will mean your driver is capable of high current (or high voltage). Then it's order some resistors time. FT sells 1206 (handles more power than 0603 and 0805 sizes) resistors cheap. Get some R10 and R33's. That should cover most of the situations you will encounter.
PHS, much more knowledgeable people than me advise against running drivers without a load to drive. You got me curious now. Does anyone out there know if you can just connect the DMM to the driver (no emitter in the path) to measure how much current it will deliver? With no voltage being consumed (almost no Vf), it would seem that it could overload the driver.
Good luck demigod! Be sure to take some tail cap readings before the resistor removal. I’m guessing you will get 2.6amp after removal and solder added.
So I checked the tail amps after I installed an XML U2 led. I was using a single panasonic NCR18650PF. I now get 1.8amp. Strange. Still too low but it went up when i installed a XML U2 Versus the XM-L2 T4, T5 or T6 that came in the light.
I was thinking that something was wrong with my meter so I checked a common C8 running a Nanjg 105C 2800ma and I got 2.78amp with that light.
First, I tried the solder blob method, and the MX-900 actually looked like it lost some power compared to the CT9T. Doing a beam comparison on the wall, show the MX-900 hotspot not as bright as the CT9T.
Next, I removed both the R160 resistors, and did a soldered a copper wire bridge. Plugged the XM-L in, and put a single 18650 in. Turned it on an compared it to the CT9T, and they looked identical. Exact same brightness. So then I figured I would try the MX-900 with 2x18650's. Turned it and for a brief second, saw a glow of light! Then nothing! I looked at the emitter, and for some reason seen a really tiny dot, like in the center of one side of the LED very bright. I mean this thing looked like it was glowing almost. I power-cycled, and still nothing. I tried my DMM on the LED, and it showed no sign of life.
I did take led readings from the emitter, even though the LED seems blown, not sure if thats as accurate, or more accurate than tail-cap readings.
Anyways, my results were...
From a single 18650: 1.9-2V and 4.3A (worked perfect, but still not super-bright)!
From two 18650's: 3.8V and 8.6A (emitter blown it seems)
So I'm guessing an XM-L can't handle 3.8V at 8.6A, huh?
Yes, that's what the LED reading showed on my DMM. Maybe readings are messed up from the bad LED? I will replace the LED and see what it gives me. I need to learn how to take tail-cap readings.
I discovered something new with the mx900. I would like to call it a turbo mode but it isnt a big increase. While you are in high mode with the side switch. Double click the button very fast and the output increases 5-10%. Strange that we never found it. Nothing too special though.
Thanks for the reports blfdemigod. 8.3 amps is good news. Indicates that driver might be able to deliver more than any xml2 on copper can handle. Are you reading the current in line with one of the emitter wires?
Something must have been wrong with the blob. It shouldn't be too far off from copper bridge.
Time to order some resistors and take Tom E's suggested approach.
Nice find phsinvent, even if it is a tiny little gain. I tried this on both the CT9T and the MX900 and they both have this "hidden micro-turbo" mode, so I assume all the models have it.
@ImA4Wheeler Seems my findings on the volts and amps are a little skewed, as I took those readings after the XM-L blew, direct from the driver wire leads. But they were very steady readings, no fluctuation at all. I will try to get correct tail-cap readings when I can.
The manufacturer is also sending me the USB mobile charge adapter, and I have some 26650's on the way, so I can test the rest of the flashlights as well, and see how this phone charging adapter works.
Sounds good. This is getting interesting if that driver is able to belt out serious current. Did you notice the 2 resister packs I linked in post 25? Those have worked for me every time so far because you can combine them in parallel and series to get other levels of resistance.
