I have 4 of the Illumination Machines LUM 5-90 95mm x 62mm Diamond Textured reflectors for sale. They had a minimum order quantity of 5 and I needed one, so I went ahead and bought all 5. These were $6.00 each and he charged me $15 shipping, with a $6.02 printed label on the box. Oh well. I’ll eat some of that shipping and sell em at $7.00 plus shipping cost.
I used this in a big Olight SR90 Intimidator with an XHP70 emitter. The beam is awesome! Easy mod, terrific result. The reflectors are a sheet aluminum, easily trimmed with good scissors.
This is the same reflector Wayne uses in his big ST90 with the Luminus SST90 emitter, which it was designed for.
I have one of these reflectors and I can say that it is one of my favorite reflectors. Best big single emitter general purpose reflector I know of. With a MT-G2, the beam pattern is fantastic. Very good at keeping the tint intact too. The purchasers will not regret their decision.
EDIT: Here is my initial report on it. To me, everything seems much more 3 dimensional with it. Maybe all the facets cause light to hit objects from multiple angles. I really need to make a light for this reflector. Can't believe I have sat on it so long.
Looks awesome. How do this compare to the stock SR90 with the dated SST90 LED? did the output go up? better tint? better throw?
I have an SR90 but its still stock.
DBSAR, there’s no comparison, I mean, really….5200 lumens? The XHP70 is, of course, a multi die emitter with essentially 4 XM-L2 dies on the single substrate. To get a smooth beam, the diamond pattern of this reflector really does the job.
If you’re happy with your stock SR90, don’t mess with it. This one had the SST-90 replaced a long time ago with an SBT70. Then it came to me for an upgrade as it was getting left behind by new lights. So I figured out how to reduce the output from the big driver and put a de-domed XM-L2 U2 1A in it for, in the end, 645Kcd. But I really have no need for such a tight long distance thrower. Hence this modification, bringing the ol girl into the modern age of MOSFET drivers, 7 modes, reversing UI, and humongous output.
Nice. if i wasn’t so strapped for cash right now i woudl buy that last reflector and an XPH70 to do the mod to mine. Was there much other mods to the light & driver needed to run this?
I don’t have a wall wart charger, only a car charger, and the original battery is getting to where it won’t charge up fully. I do have a second battery tube that came to me with the light, it had been gutted. So I modified that second tube to allow a pair of Efest Purple 26650’s to fit and this gives much better current flow. I did spring bypasses at the head, and put an A17DD S08 driver in it after removing the original driver and setting it aside. There’s so much room in there, swapping the driver is a piece of cake. I simply wrapped the driver and wires in/out with kapton tape. 18ga wires to and from the driver.
I did have to drill and tap the brass cup that holds the emitter, enabling me to bolt down the star and run the big 18ga wires through the wings of the star so the LUM 5-90 fit around it. Essentially, that’s it. The stock battery still works of course, it just won’t flow the big current. I haven’t taken a current reading but it should be somewhere North of 10A.
I’ve got these boxed up, ready to go out, but my USPS online account only allows for 2-Day Priority mail at $6.02. So I’m taking them to the Post Office in the morning to see how much cheaper they can do it from there.
If y’all want to split the difference on that shipping, I’ll cover half and you can pay $3.00 and get a tracking number, see em by Wednesday. What’dya say?
hahaha, I wonder if they do an Overnight Express to Australia? Should be pretty cheap, right? I mean, it’s not like you’re in the Outback or anything….
You haven’t seen that box with Cutter written all over it yet? That box will have some serious mileage on it!
