I'm just glad to see "our" custom firmware make it into a nice production run. Everybody is doin what they are good at - from firmware to making drivers/lights. Of course TK doesn't make any $$$ on it - can't say Eagle Eye or BangGood are making much either, but if this gets pulled off where the majority is happy, we all owe TK something. I know she's leveraged some things from BLF or BLF'ers, but the majority is on her.
At my age, sometimes it takes me sometime to realize just what it is I am looking at:-)
90sec would be great, but thinking more about it (after reading other’s posts) - No stepdown would work for me too.
If I don’t forget that the pain in my hand means that I am being burnt:-(
The way that this light is built, I would venture a guess that it is able to stand more that I/We. - Great heatsinking will make the outside of a High-Powered light heat up FAST, if the Sink is well connected to the exterior.
I should have a sample to test tomorrow. I am usually able to get moon into the range of 0.2 to 0.5 lumens though, so it’ll probably be in there somewhere. It varies for each individual unit though, and also depends on the battery voltage… so any measurements I post will be approximate.
In group 1 with 7 levels, moon is so low as to be virtually useless (IMO) I have used it in a dark house late night, and outside. Even trying to see the camera settings up close and personal moon is so ultra low as to not be much help. I know there are those that will rejoice in this, and those that will groan. But really, it’s that kind of low…. easy to forget the light is still on because you can’t see the result.
In group 2 with 4 levels it’s not this way.
To rephrase it, those cheap little coin cell keychain lights with the 3mm tubular led? When the battery is almost run out? Like that.
When I initially checked the samples to see that they worked....
I thought the first one was defective because of the moon mode. It wasn't until I looked at the LED that I realized the light was on. I too find such a low useless BUT like you said there are many here that will rejoice at such a low. Hell, if your eyes are that good...you do not need a light
