XP-L HI still has the most average surface luminance per lumen out of all the LEDs shown in the image, so if you want throw that is the way to go, the simple route (no boosting).
I wonder about something as shown in the image: Does a domed XP-G2 has higher luminance (surface brightness) than a dedomed XP-L? Really?
[/quote]
Not sure about the XP-L HI (so called domeless) so far only low bins have been out via Mouser. But at any rate just calculate to see the percentage increase from 7.8 to 8.2, it is 5.128%, not a monster difference which can easily go into manufacturing tolerances of LEDs.
Remember that number is in comparison to the lumens it gives. So, overall performance is not in that number, but in the wide view of all the numbers. The apparent die size of a XPL HI is about the same as the apparent die size of the domed XP-G2, but the luminous flux is just below double that of the XP-G2. The calculation they use is cd/cm2/lm but they don’t give us the number for cd. If we work the math backward, though, we find that the cd for the domed XP-G2 would be ~5027, while the cd for the XPL HI would be ~8541. So ,the XPL HI actually wins in overall performance. That 7.8 vs 8.2 is almost meaningless in itself. It has to be taken in context.
Based on pictures and some other data,this LED uses weird 4x 1.4mm2 dies,so they are not xp-e (1mm) dies.That means this led has 5.6mm2 of total die area,which is 40% more than XP-L / XM-L2. So it wont throw better than those two.Overdriving would be also less effective because thermal pad is only 1.3mm wide, and effective die length/width is 2.36mm.
Are you guys even reading what Cree writes, or making stuff up?
Let me help ya’s:
“Leveraging the industry’s breakthrough 12-V monolithic power die”
“Delivering 50% higher performance than Cree’s previous highest-performing single-die LED”
It’s NOT 4-dies. It’s 1! This is the LED I’ve waited for, for ages. It’s like the SST-90, but made by CREE on SC5.
Where are people getting 4x 1.4mm dies from??? Maybe 4 semi-conductor chips underneath, but monolithic is one single phosphor layer that lights up white. Look at the main Cree site photos, it’s clearly the correct image. The static-diode is on the cathode side, it’s not in the middle of the package like an XPL Hi or other E2/G2/L2. The picture is right. Look at the data sheet, too. One die. Sorry, but I am jumping for joy right now. The J20-aspheric build found its ultimate partner.
I agree. The single die factor is what peeked my interest.
Has anyone seen the high intensitys for sale in the US yet? All I have found in stock are the high density. I guess I could cut the dome off myself, but I'd sure rather have one that cree did for me
