Xiaomi style battery charger. Near disaster today – flames – when I put a battery in
107 posts / 0 new
myhken
myhken's picture
Last seen: 2 years 5 months ago
Today I got to see what destructive force 18650 batteries can have.
I got some Xiaomi style 4 × 18650 power banks from Gearbest.com today (this type).
Wanted to test one of them, and found 4 Sanyo UR18650ZY batteries, that I have tested and tested, and then used same type in different flashlights etc.
As soon as I put in first battery in the power bank, it burst in to flames. I trow the whole thing away on the floor, landed right under my pants (that was on a chair), so I quicly had to remove the device, still burning, and then trow it hard to the ground to try to get the battery out, or destroy the power banks so the fire stopped. And it did.
As you can see on the pictures under, the coil in the power banks has been so hot that it melted the plastic, that took fire. Not a pleasant experience.
I was afraid the battery whould explode, that was the reson that I just trow it away, not trying to remove the battery. Do not know what was the right thing to do in this situation?
The power banks can only fit unprotected flat tops batteries like most power banks, and the power bank should stop short circuit, over/under charge etc. Clearly the Xiaomi style power bank Gearbest.com sells, do not prevent such things.
Here is the info from their website and the power banks:
Kenneth Myhre
Edited by: myhken on 08/05/2015 - 15:27
Noki
Last seen: 3 years 7 months ago
Oh, no.
Luckily you’re ok, something even worse could happen.
I’m not sure that’s authentic Xiaomi power bank box. I have original 10400mAh Xiaomi and its looks different than from your link.
ChibiM
ChibiM's picture
Last seen: 14 min 26 sec ago
ouch! and lucky you!
it could have been way worse than that!
Glad you are okay, and your house!
myhken
myhken's picture
Noki wrote:
Oh, no. Luckily you’re ok, something even worse could happen. I’m not sure that’s authentic Xiaomi power bank box. I have original 10400mAh Xiaomi and its looks different than from your link.
No it’s not original Xiaomi, it’s Xiaomi style. Smile The real Xiaomi power banks comes with batteries and can’t be open (easily). Still, Gearbest.com claims that this has the short circuit protection etc, so this should not happen I think?
Kenneth Myhre
tempo
Last seen: 4 hours 4 min ago
my xiamoi powerbank feels like aluminum case not plastico
but of course aluminum can burn too if the flame is hot enough
DanielM
DanielM's picture
Last seen: 7 months 1 day ago
xiaomi makes powerbanks that you can load with cells? I did not know that.
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
myhken
myhken's picture
Did not know that. But I knew this was not a real Xiaomi PB, since they sell it as Xiaomi style PB. Still, did not expect bursting in flame putting in one battery, and of course, it was the right direction ( + / – )
Yes, it has aluminum case outside, this is inside there the batteries is, and of course, no metal there.
Kenneth Myhre
DanielM
DanielM's picture
Ah I see it’s “Xiaomi Style”, not Xiaomi. Just buy the real thing, not this “style” dangerous garbage.
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 6 months ago
Good to hear you weren't hurt. Most decent cells will take a dead short for a little while before they blow. I know first hand, more than once.Frown
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
kwarwick
Last seen: 2 hours 6 min ago
The problem with the listing on GearBest’s site is, although this is an Xiaomi “style” power bank shell, they’ve reused the copy from the real product. I doubt it has any of the safety features of the real one, as you have unfortunately discovered! Is it possible you inserted that battery backwards?
edit I see you are sure the battery was installed the correct way. If you have a multimeter I would try measuring the resistance between the + and – contacts to see if there is a dead short.
myhken
myhken's picture
Old-Lumens wrote:
Good to hear you weren’t hurt. Most decent cells will take a dead short for a little while before they blow. I know first hand, more than once.Frown
But the battery did never blow, still I have put in into my fireplace now, just to make sure.
No it’s was inserted the right way. The batteries has a plastic label with info, and with a + and – sign.
And here is a picture of the battery, and you can see thats the rear end that has been in the fire.
Kenneth Myhre
hank
hank's picture
Last seen: 16 hours 44 min ago
Something wrong here (besides GB apparently posting the real Xiaomi information along with their “Xiaomi style” cheap copy — which is really, really stupid.
Look at the questions on the page down at the bottom:
Quote:
Customer Questions & Answers By Farit Jun-18/2015 01:06:07 Question: This is the original case from Xiaomi? I understand that Power Bank no battery? The case can be taken apart to put the batteries? The USB cable included?
Reply: Hi, Farit ! It is not the original case from Xiaomi.The item can not be taken apart to put the batteries.The USB cable is not icnluded.
By wzran2 May-21/2015 12:05:08 Question: is this an original xiaomi mi power bank?
Reply: Hi, wzran2! It is not original xiaomi.
So —- the case you point to is not supposed to be taken apart, if that answer from GearBest is accurate (also not necessarily to be relied on).
(From the description elsewhere it’s not at all clear if they ship it with, or without, any batteries)
Why did you take it apart? Did it come with batteries in it? Did you remove all the cells first, then put a single cell in and it exploded?
The only time I’ve seen a power bank heat up like that was when TWO cells were put into it, one of them backwards, causing a dead short circuit.
myhken
myhken's picture
**edit* I see you are sure the battery was installed the correct way. If you have a multimeter I would try measuring the resistance between the + and – contacts to see if there is a dead short.*
It still has 4.20V when I use my multimeter. So the battery seems OK. But it smells burned from it still. But it’s not hot or something. But I have so many batteries, that I will never use that again, just to be sure.
Do you or any other know where (which store/seller etc) that ships to Norway, that have real Xiaomi empty power banks that I can use my own batteries on?
See several on Aliexpress, but don’t know if they just use real pictures from Xiaomi, or not. And in the Xiaomi store I can’t find DIY cases…(maybe I have overseen some?)
Kenneth Myhre
myhken
myhken's picture
Look here, this is what I got from Gearbest.com from the page that I linked to:
I just put in the one battery, then it started burning right away.
Kenneth Myhre
Noki
If you wanna consider other diy power banks have a look at HKJ reviews. I bought some of the stuff he tested including Coolook PB-2000 diy power bank and its working very good.
myhken
myhken's picture
The whole point is to get a cheap, but still quality, power bank, that I can use my own batteries on. If the price is $15 or more, with the price of 4 batteries, I will come better out buying real Xiaomi power banks (not DIY).
A 10400 Xiaomi PB costs from $17-21 on Gearbest, lower prices other places. Their 16000mAh PB cost $24. So maybe I just drop the idea making my own PB and buy real ones. It’s safer, and I can earn almost the same money on it.
Kenneth Myhre
dchomak
Last seen: 2 years 1 week ago
The cell bank that caught fire could have shorted out with the case of the cell next to it. I notice that the current only went through that one spring. I think the cell next to it had popped up so that the negative case on that cell was toughing the positive terminal. Then when that last cell was in the process of being inserted, it shorted out through the case of the cell next to it. i would like to see the contacts of the case on the positive side.
myhken
myhken's picture
There was no other batteries in the case. I had just opened the package and the PB, then I inserted the first battery, then it started to burn right away, or first it made a sound, got really red, and I throw it, in the same second it start to burn a little. As you can see from the damage, we are not talking about a huge flame or fire, but it burned, so when it landed under my pants, I had to do something really quick…
Here is the pictures from the other side, as you can see, no damage there. If I had put two batteries in, would there have been any damage on the positive side also?
Kenneth Myhre
Fox
Last seen: 5 hours 21 min ago
I dont trust cheap chinese items.
I always prefer going with genuine devices.
I was thinking to buy that 18650 power bank box… but now… obviously not
The most ugly place in the world! Surprised
dchomak
I know you swear you put the cell in the right way, but to me it looks like you put that one cell in backwards and the positive and negative of the cell shorted out on the spring. I can’t explain the picture of the negative end of the cell. Can you take a picture of the positive end of the cell?
myhken
myhken's picture
can wrote:
From your previous posts it seems like you search out Bad products to return or get a refund. I think you would be better off buying good products and just keep what you bought. I also have no trouble admitting when I put a battery in backwards.
This was not a product I thought was bad, since I new original Xiaomi 10400 PB cost $16 with batteries, I was sure $6 was not a really cheap deal for a empty box, since 4 x brand name batteries cost from $2 – $6 buying on sale, or in packages of 50 from Alibaba.
The rest of the stuff I have talked about, was stuff I ordered before joining this forum, and before I was enlightening Wink
About the battery the wrong way, you did see my picture?
As you clearly can see, it was inserted the right way. If you look at the pictures here… you can see there is no damage to the positive side, and that the negative side, was the side where I put the battery.
So you are saying that I lie? Or just want my money back or something? In this case, I will not ask for any refund or something. I have another order for 7 more on it’s way from Gearbest.com, so I will see if I try to use them or not. I have to say that I opened a second PB, inserted the same types of batteries (not the bad one) and it’s totally fine. Works 100%. So most likely there was something wrong with this one PB, or the battery, but since the battery still has 4.2V on it, and seems like it works (has not tried it in anything) there has to be the PB? Or?
Kenneth Myhre
HKJ
HKJ's picture
Last seen: 5 hours 10 min ago
It looks like a production fault with the battery voltage shorted. No protection in the power bank will help with that, except if they had put a fuse in the wire.
I doubt that it caught fire, it was probably just the wires getting red hot.
If the only damage is that spiral, you might have put the battery in the wrong way.
I will suggest you do a few tests on the battery before using it again:
If you have a analyzing charger, give it a spin.
See how much voltage it drops when laying fully charged for 24 hours.
Woodfiend
Last seen: 2 years 10 months ago
+1
myhken
myhken's picture
Here is some pictures of both sides, maybe the “crack” at the side on the top had something to do with it? Of course, that could have happened when I trow it in the ground to getting the battery out…
Kenneth Myhre
HKJ
HKJ's picture
myhken][quote=dchomak wrote:
Here is some pictures of both sides, maybe the "crack" at the side on the top had something to do with it?
That sounds like the correct explanation.
myhken
myhken's picture
You are the real expert here, when you see the pictures here… and the rest I have posted. Do it seems like I put the battery in the wrong way?
My Multimeter says the battery has 4.2V still, but why risk it. I just trow it away. I have plenty others.
But really, you can see the melted plastic on the negative side on the battery, and that the positive side is perfectly fine. If I had put it in the wrong way, how could I get melted plastic on the back of the battery (then facing the positive side on the PB) when my pictures clearly shows that there is no damage at all on the positive side of the PB, just on the negative side, there the negative side of the battery was.
Thank you, if it was to me you wrote it.
Kenneth Myhre
hank
hank's picture
Put it outside the house in a metal container (or in a bucket of water) and recycle it properly.
HKJ
HKJ's picture
myhken wrote:
You are the real expert here, when you see the pictures "here...":http://budgetlightforum.com/node/40895#comment-790650 and the rest I have posted. Do it seems like I put the battery in the wrong way?
Yes, and one of the outer turns of the spring got a connection through the crack in the isolation on the battery.
myhken
myhken's picture
Of course, having it in my fireplace is just to keep my house safe. I also have a box of batteries to I have got (like Ultrafire and the 5000mAh blue battery from Gearbest.com) that I’m going to take to the recycle center next week.
Kenneth Myhre
myhken
myhken's picture
But why is the melted plastic on the negative side of the battery? Do you see any damage to the positive side of the power bank?
And you can see the melted plastic on the negative side of the battery, and there is not any thing on the positive side of the battery?
Still, you think I put it in the wrong way? How did the melted plastic and burn marks come on the negative side of the battery then?
Kenneth Myhre
flydiver
Last seen: 13 min 42 sec ago
Woodfiend wrote:
+1
+2.
You buy cheap crap hoping for a good outcome, then seem shocked when it is indeed a crap product. Now you are playing with ‘fire’. What amazes me almost more is the support you are getting for this repeated behavior. You’ve been warned off numerous times.
Come on, a 4-battery power bank for $6? You can barely get a decent single for that. You already knew that and did it anyway.
