Integrating sphere #3 (portable and overly stuffed with features)
48 posts / 0 new
djozz
djozz's picture
Last seen: 13 min 11 sec ago
This post is once again about integrating spheres, please feel free to ignore it if you like, it is barely relevant to the flashlight hobby and primarily just my own fixation forced upon you poor BLF-members Wink .
As with all mod threads, it is difficult to describe unique builds, especially in a language that is not your own, I hope that at least some folks can follow this build (if at all it has your interest).
My other spheres:
Integrating sphere #1: http://budgetlightforum.com/node/31356
Integrating sphere #2: http://budgetlightforum.com/node/36629
Integrating sphere #4: http://budgetlightforum.com/node/39409
Introduction.
I posted about the 4th integrating sphere before this 3rd one, but at that time number 3 had already seen the light of day (). The number three that this post is about was at first supposed to become simple and portable, but during the build I got carried away with adding features...  So it did became portable, but not very simple. Now that it is finished it features a 40mm entrance hole (this sphere is not for big lights), a satellite diffusing sphere, a reference light for conversion factor determination (rlcfd, in former threads I called it 'calibration factor comparison light' ->cfc, but I think rlcfd is a more proper name for it), a conversion factor adjustor (cfa), a small led outside for illuminating the luxmeter, and a lid for easy transportation. More info about the features later.
Sphere 3 is going to be made of uncoated finely sanded polystyrene, because during my tests of #2, I was not able to give definitive proof that a BaSO4/latex mix did a better job at reflecting all wavelengths equally well than plain polystyrene: the coating did make a difference but I could not proof it was for the better. And in the end flashlights of varying colour temperature measured very close to the same value with or without coating: from 3000K to 6500K the difference was only 2.2%, from neutral to cool white only 0.7%. For single colour leds the difference went as high as 10%, still not that worrying.
This is a small sphere, and I learned from sphere #1 that in a small sphere, a luxmeter with maxiumum range of 200,000 lux gets already out of range under 800 lumen, and I sure want to be able to measure more than that. In sphere #1 this was solved by placing a grey filter before the luxmeter sensor. In sphere #4 the light is measured through the wall of the sphere. During the thinking process for this sphere (thinking, as usual, took more time than the actual build) I decided on a more exotic solution: a satellite sphere (as I and others also mentioned in other threads, Labsphere has a fine lecture on the theory and the consequences of theory on building of integrating spheres). A second (smaller) sphere was attached to the exit hole of the primary sphere, the luxmeter sensor was placed in there. The (already integrated) light coming from the small surface area of the exit hole of the primary sphere is thus distributed over the larger inner surface area of the secondary sphere, so less light ends up on the sensor. The added bonus is extra integration of the light in the secondary sphere.
This sphere is going to have an inbuild reference light, to be able to calculate the correct conversion factor to convert luxvalues to lumen, compensating for different lightsources (different flashlights, bare mounted emitters) in the entrance hole that influence the total reflectivity of the sphere (e.g. large shiny flashlights cause a higher total reflectivity than small matt black flashlights). In sphere #2, I found that for the measured light value it does not matter if the position of the reference light is in the entrance hole or in a 90 degrees position of that. In the 90 degree position it is not in the way of the to be measured light source, but the inner surface of the sphere does need 2 extra baffles.
After it was finished and having done a large measurement session of different flashlights, I was a bit fed-up with doing the correction calculation for the altering reflectivity for the different flashlights, so I opened the sphere up again and solved the reflectivity variation optically by building an adjustable light absorption thing in the secondary sphere. This way I can adjust the total reflectivity of the sphere towards the same conversion factor every time, and thus avoid the extra calculation.
Parts of this sphere are made of polystyrene hobby balls, radiator alu-tape, latex wall paint, hobby glue, architect's foam board, cellotape, a blank cd, a piece of a cd-box, a black permanent marker, some black plastic cap, a satay skewer, and more cheap common household junk. But the use of cheap materials does not necessarily have much to do with the quality of the performance of a build device, as I learned from my (distant) scientific past: if everything is well thought-out and a stable and constant construction is made, any material could do the job.Smile  ..Unless you try to sell it of course, then a 'professional look' becomes important.
Now on to the build:
Here, the two spheres (20cm and 15cm outside diameter, 16cm and 11cm inner diameter) are already attached (just the halves are not closed), the surface where they touch is covered with aluminium tape before they were glued together, so that light going from the primary to secondary sphere can exclusively go through the hole and not through the walls. Btw, almost the whole thickness of 2cm polystyrene is adding to the reflectivity of the sphere: light that goes deep into the polystyrene still has a good chance to come out on the inside of the sphere again, I found. Near the hole connecting the two spheres, the greyish alu-tape in the middle of the connection shined through the polystyrene, to recover the reflectivity in that area, some white latex paint was applied locally.
There are four baffles (light blockers) in the device, of which three you can see in the primary sphere: one preventing light from the source entering directly the exit hole, one to prevent light from the reference light to shine on the entrance hole, one to prevent light from the reference light to shine on the exit hole. the fourth baffle is in the secondary sphere (not visible), preventing light from the exit hole to shine directly on the luxmeter sensor.
The hole from primary to secondary sphere has a sharp edge, so that light coming from all positions on the surface of the primary sphere is able to enter the secondary sphere.
As the reference light, a Nichia 5000K 5mm led was positioned perpendicular to both the entrance and exit hole of the primary sphere, with two extra baffles (from foam board, glued to the inner surface of the sphere) the light from this source is prevented to shine on the entrance hole and the exit hole. To use this led as a reference source, I did some testing to make it have an as constant output as possible, and ended up with this: the legs were connected to lengthy pieces of thick copper wire for heat to escape, the current was regulated at exactly 6.47mA using a 9V block battery and a LM317 voltage regulator (mounted on a strip of aluminium as a heatsink) that together with a 198Ohm resistor was used as current regulator (see for how the wiring goes for example here). The output is now near 3.3 lumen (giving a well significant enough reading on the luxmeter), and is within 0.2 % (!!) constant from the moment of switch-on SmileSmile.
(one-eyed snowman Smile) An extra led was connected (simply via a 150 Ohm resistor) to the battery to use later as an illumination for the luxmeter read-out. From the secondary sphere, a bit was sliced off to get the luxmeter sensor closer to the inside, and a blank audio-cd was glued on top to give it some rigidness for repeated attachment of the sensor. I found a black soft plastic cap somewhere that fitted snuggly around my MobiluxA luxmeter sensor, I made a hole in it for the sensor to see through and glued it on the cd.
Some more slices were cut from both spheres to make it fit into a smaller case. The halves of the spheres were fixed together with cellotape, which sticks very well to styrofoam. The case was made from thin plywood, small pine timber, screws and glue (and a small piece of brass profiling for the switches, a iron bracket for the 9V battery). I made it so that the sphere assembly could only fit in one single position. Where the spheres touch the walls, the inside of the case was painted with latex paint: because the styrofoam walls are thinner there, the reflectivity is restored this way.
After this was finished and tested well, I added a new feature: conversion factor adjustment by optically altering the resulting reflectivity of the sphere :bigsmile:
I opened the case again and drilled a 3mm hole through the plastic cd to the inside of the secondary sphere, so that a satay skewer would fit through.
A round piece was cut out of a transparant cd-cover, with a permanent marker a section was blackened, a small hole was drilled in the middle and it was slided over the wooden shaft. A slit was cut in the wall of the secondary sphere to make room for the round piece. The  surfaces inside the slit were partly covered with aluminium tape to make sure that the blackened piece, when turned out of the way from the inside of the sphere, could not possibly influence the reflectivity of the sphere.
After some initial testing of the range in reflectivity alteration that this device gave, the blackened surface was increased a bit. The round piece was glued to the wooden shaft with a blob of Araldite, and then the shaft was painted white with latex paint.
On the outside, the shaft was glued to a slice of broomstick as a turning knob.
So now the device has an extra knob:
And this is what happens inside the secondary sphere when you turn it:
The knob I can use in the following way: I measure my (known) constant output reference lightsource once (in my case my SWM D40A on high setting: claimed 550 lumen) and determine the the conversion factor luxreading->lumen for it (the conversion from klux->lumen is about a factor 24, btw that makes the maximum measurable output 4800 lumen, the minimum is about 0.01 lumen). Then I check, with the D40A off, what the reading of the inbuild reference light is, and write that down. Now with every following flashlight that I measure, before switching it on, I use the adjustor to match the reference light reading to the written down value for the D40A. If they match, the conversion factor is the same as with the D40A. From now on I have the intergrating sphere calibrated, and can use a constant conversion factor by adjusting the reference light to the same reading every time a new lightsource is used.
I reckoned that the position of the blackened piece was not critical, just somewhere in the secondary sphere was good enough: the bulk of integration is done in the first sphere anyway. I did position it perpendicular to the exit hole of the primary sphere, to make it have its biggest influence after the light has undergone at least one reflection in the second sphere, I thought that this way the integrating properties of the whole assemby were the least affected by it.
I already found out that the numbers generated by sphere #3 are reassuringly constant over a couple of months, and it has the most constant light source that I was able to make thusfar. Now with the newly build conversion factor adjustor I will again have to get used to how good it will function, but  trust it to work fine, also over time, I'm happy with it.
Some numbers to show which amount of variation the reference light plus adjustor will have to solve: The most reflective flashlight I have is the SWM D40A: it snugly fits the entrance hole and has a reflective SS bezel, with the adjustor out of the way the reference light reads 160klux on the luxmeter. On the other side of the spectrum is the narrow Thrunite Ti with matt black bezel, way more light leaks away through the entrance hole or is absorbed by the flashlight body, the reference light now reads 142.3klux. So the shape and texture of a flashlight can  cause a 8.9% difference in the reflectivity and thus the conversion factor from luxmeter-reading to lumens in this integrating sphere, that is worth correcting! Btw, reflectivity sensitivity for different flashlights is also a sign of proper integration Smile
In this sphere, the entrance hole surface area is quite large compared to the total inner surface of the (primary) sphere: 1.7% of the inner surface area. In my big sphere (#2) the entrance hole (although in itself larger: 8cm instead of 4cm diameter) is relatively smaller: just 0.75% of the inner surface area, so the influence of the lightsource's shape and texture in the entrance hole is significantly less, e.g. just 1% between the D40A (big with shiny bezel) and the Nitecore P12 (way narrower and black bezel). With the hole narrowed to 3cm (I have an insert for that), the variation becomes so insignificant that a correction with the reference light is not needed at all.
Thanks for bearing another post about integrating spheres Wink
Edited by: djozz on 08/12/2015 - 05:05
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 56 min ago
Wow that is really outstanding djozz!! 8) Excellent job! Wink
KB1428 “Live Life WOT
MRsDNF
MRsDNF's picture
Last seen: 2 days 13 hours ago
I understand what a skewer is, not a lot else. You are really clever and smart. I do understand though that what information comes from your new contraption I more than likely will understand. Smile
FmC
FmC's picture
Last seen: 10 hours 43 min ago
You didn't use a carrot for his nose! Wink
Nice work, what a cool device. Beer
Billy X
Billy X's picture
Last seen: 3 months 3 days ago
Good job you made 4 spheres,it’s taken me 4 build threads to start to understand (most)of the correction factors.I watch in awe.
djozz
djozz's picture
Billy X wrote:
Good job you made 4 spheres,it's taken me 4 build threads to start to understand (most)of the correction factors.I watch in awe.
And it took me 4 builds to understand what you can just leave most fancy stuff out without offering much accuracy to make a really simple integrating sphere.
garrybunk
garrybunk's picture
Last seen: 3 days 9 hours ago
Truly amazing build djozz! Can’t believe there aren’t more responses here.
So am I understanding the procedure of the reference light correctly? You turn on the reference light while using your SWM D40A in order to obtain your calibration “multiplier” – which means your luxmeter is reading both the reference light and D40A’s output, but your multiplier will then compute that combined lux reading to match the D40A’s “true” lumen number? So you then measure any other light you wish also keeping the reference light on during those measurements? And I understand that you adjust your readings by adjusting the reference lights output to read correctly with the “other” to-be-measured light in the opening while off.
Ok, I think this is making sense on how I would incorporate a reference light into my simple round sphere (like your #4), although instead of a knob rotating a “reflectivity changer doo-hickey” I’d just be adjusting my calibration multiplier to produce a correct lumen calculation on that reference light.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
djozz
djozz's picture
-Garry
I think you understand it almost correct, except that while measuring the reflectivity with the reference light, the D40A is not switched on, it is just kept in the entrance hole in measuring position. The reference light puts out exactly the same amount of light every time, but the overall reflectivity of the sphere’s inner surface varies, dependent on what is present in the entrance hole, resulting in a varying amount of light reaching the luxmeter. So with the reference light you determine the used multiplier for the sphere.
The procedure is as follows:
-place a flashlight with known output (your calibration light) in the entrance hole, but switched off
-switch on the reference light, write down the measured lux for the reference light (this lux value for the reference light is specific for the situation with the calibration light present in the hole).
-switch the reference light off
-switch the calibration light on and write down the measured lux for the calibration light
-calculate the sphere’s multiplier for the calibration light
-place a flashlight with unknown output in the entrance hole, but switched off
-switch on the reference light, write down the measured lux for the reference light (this reference light luxvalue is specific for the situation with the unknown output flashlight present in the hole).
-the specific multiplier for the unknown flashlight will be: calibration light multiplier, times the specific reference light luxvalue for the calibration light, divided by the specific reference light luxvalue for the unknown light.
-switch off the reference light
-switch the unknown flashlight on and write down the luxvalue
-multiply this luxvalue with the just calculated specific multiplier for the unknown light.
It sounds tedious and difficult but it is easier done than written down, and if you think it over it will make sense (I hope Smile )
(the procedure is shortened for the above sphere #3 because of the extra option of optical correction for reflectivity)
Edit: I swapped ‘times’ and ‘divided by’. Now it is correct. Innocent
garrybunk
garrybunk's picture
Gotcha! Thanks for the details. Sounds logical to me.
-Garry
1dash1
1dash1's picture
Last seen: 11 months 3 weeks ago
I was wondering why you re-callibrated for every flashlight. Wow! That’s mind-boggling.
Thanks for the detailed write-up and explanation. Glasses
Rule 1-1 as it applies to life, take it as it comes.
vestureofblood
vestureofblood's picture
Last seen: 11 hours 38 min ago
Hi djozz,
I was just wandering, is there a reason you use the lux setting on your meter over the foot candle one?
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
djozz
djozz's picture
vestureofblood wrote:
Hi djozz,
The reason is that I did not come across any practical light measurements before I started measuring flashlights. And since my original background is (or was, quite some time ago already) science, the logical unit would be the standard SI-unit which is the lux.
Isn’t the foot candle more an american than a european unit?
vestureofblood
I’m not sure. I have always used the foot candle setting for lumen measurements. I use the lux setting when I take what I called “lux” readings. IE the thing where you measure distance by firing directly into the meter and the multiply by the cube root.
I had never noticed that you and some others I see are using lux. I did a few tests just now and so far the only difference I can tell is that a slightly higher multiplier is derived. When I measure lights I seem to get roughly the same result.
Using the FC setting a light that I get 4,335 lumens with renders like 4,458 ish when I do the conversion from lux. My system is not as accurate as yours though, I can get a variance like that repeating the same test twice.
EDIT: Also I was wanting to ask you. When using the small sphere you made where the sensor just attaches to the outside of the ball do you have to recalibrate in order to measure a bare LED? When I do it in mine the recalibration is vast. Multiplier for flashlights is typically 3.4, for doing bare LEDs it its 4.3.
ToyKeeper
ToyKeeper's picture
Last seen: 18 min 51 sec ago
https://en.wikipedia.org/wiki/Lux
Lux meters measure of intensity of light at a single point or a small area. The result can be converted to/from foot-candles by using a factor of 10.764, but lux is the SI standard unit. We can also determine candelas (intensity per angle) with a lux meter, by carefully controlling the distance from the light source.
The integrating sphere is supposed to spread all the photons evenly so that a single-point measurement will be representative of the total amount of light, regardless of how that light was initially distributed. An ideal sphere won’t really care if the light source is a bulb or a laser. So, if you get massively different results for a reflector-based light versus a bare emitter, the sphere isn’t doing its job very well. At minimum, you might need to add a baffle between the entry hole and the sensor.
djozz
djozz's picture
There can be several reasons for a different multiplier:
1) integration is poor
As Toykeeper pointed out, the integration could be limited, due to the box being not spherical (I still think that a box vs a sphere should not matter that much for integration, but never measured it), or to the absence of a well positioned baffle blocking light from the source going directly to the light sensor. Like the bended pipe device that has limited integration, all works acceptably well as long as reflector flashlights are measured with similar light distribution (beam pattern) that are pointed in the same direction all the time, and if the calibration was done with such flashlights as well. But a bare led is an extremely different beam, getting accurate results for both a directed source like a flashlight and a spread-out source like a bare led, requires much better integration.
To check for integration quality of a measuring sphere/box/pipe, you can use a small zoomie (small to minimise entrance hole effects, see number 2 ) in spot modus, on low setting so that the output remains more or less the same (you can check for output variation of the zoomie before starting the next step). Then hold it in the same position in the entrance hole and write down the reading when shining it in several directions into the box (straight ahead, 30 degrees in different directions, 45 degrees in different directions. If you find a variation in your values of more than a few percent, the integration of the device is limited, different light distributions will affect the reading. If I remember well, my 46cm sphere gives variations of 3% maximum, with still only 10% difference (lower) when shining the spot directly on the baffle.
2) entrance hole effects.
the total reflectivity of your sphere, which is a measure for your multiplier, is also influenced by the reflectivity of the entrance hole. The reflectivity of the entrance hole varies with what object is in there. A flashlight with its (large or small) reflector will always cause a higher reflectivity than a bare led (or an empty hole), so your mulitplier will be lower for a flashlight than for a bare led, but how much? You can minimise this effect by using a low hole/inner surface ratio (big sphere, small hole), or you can every time correct your multiplier for ‘hole effects’ (3 of my spheres have such a correction option, it is using an build-in constant light source in the sphere). There is a very stubborn misconception on BLF btw that the sphere’s reflectivity must be maximised at all times for the most accurate results (people are using inserts that alter entrance hole size, or white disks around the flashlight), but what is really needed is that the reflectivity is kept constant, and you have no way to know (measure) how such an insert influences the reflectivity (and thus multiplier). A high reflectivity is good, is needed, but keeping it constant is way more important, that gives you the non-changing multiplier.
You can get a feeling for your entrance hole effect by fabricating an aluminium foil round around your bare led of the size of the entrance hole of the measuring device (a flat round of alu-foil, not conus shaped like a flashlight reflector), this mimics the reflectivity of a flashlight. Then measure the led at the same current with and without the aluminium round in place.
3) factory specs may differ from real world results.
I’m not sure how your calibration for bare leds was done. I assume you used the factory specs for a number of leds and figured an average multiplier out of that? It could be that how the factory measures the led (for milli-seconds is what I have read somewhere) is different and gives higher values than real world measurements with the led continuously lighted. This is not something I know a lot of btw, I just pose an assumption here.
I hope this makes a little sense to you to and I hope you will find out where the multiplier difference comes from. And if not, just use the different multipliers for different light sources and live happily everafter, being obsessive about accuracy (and never really get there Sad ) like me may not be very health anyway Smile Smile
garrybunk
garrybunk's picture
djozz wrote:
. . . There is a very stubborn misconception on BLF btw that the sphere’s reflectivity must be maximised at all times for the most accurate results (people are using inserts that alter entrance hole size, or white disks around the flashlight), but what is really needed is that the reflectivity is kept constant, and you have no way to know (measure) how such an insert influences the reflectivity (and thus multiplier). A high reflectivity is good, is needed, but keeping it constant is way more important, that gives you the non-changing multiplier.
Thumbs Up
vestureofblood
I am sure that the reason my setup has to be recalibrated is because of lack of integration. When I build that setup years ago I had a $0 budget and needed it mostly for A B comparison.
The main reason I asked is too see how much of the recaibration could be eliminated by going with a better one.
After reading a few articles (including TKs link) I don’t think that having used the FC setting really hurt me any. My results have been reasonably consistent with what others have posted anyway. Moving forward I may join the band though.
I think also what I really really need is a true constant source for calibration. I am thinking maybe something that plugs into the wall vs runs on batteries. Like maybe an MR16 LED bulb or something.
djozz
djozz's picture
If you write a PM to texaspyro, he uses MR16 bulbs as a constant source for his sphere, he will know which one will give consistent output.
As an alternative, my constant output lightsource for checking my multiplier is a Sunwayman D40A. The high (not turbo) setting has a really consistent output, even at partly drained batteries. You could scan through your high end flashlight collection (SWM, Nitecore, Zebralight) for a good one. If the light uses current control for the lower modes (not PWM), there is a good chance that the light output on a medium setting will be nicely constant.
ToyKeeper
ToyKeeper's picture
I’ve found Zebralights make a good constant output source for calibration purposes, as long as they’re only on a medium setting and have reasonably full batteries. I’m using selfbuilt’s data to choose reference lights though, since he has such nice runtime output graphs.
Here’s a Zebralight on two medium modes:
vestureofblood
TK,
That helps in ways you cant imagine. I’ve had a Zebralight sc52 since like last year. Mine is the XM-L version. I love the light because its AA and Type III HA natural. But I was never able to get anywhere near a factory rating on output with it. Worse still there was no change to the turbo mode even using a 14500. Max output was like 154 lumens. Seriously I thought it was broke until just now. When I saw that M2 thing, my hopes are what lit up. I picked mine up second had so it never occurred to me to look at the instructions. Fortunately the new version has the same UI.. Smile
djozz
djozz's picture
I keep my D40A as new, and solely for checking my multiplier, keep it in its holster so not to damage the anti-reflection coating (which would alter the OTF output), it only comes out when a reference source is needed. When using it, I keep the batteries more than half full, switch it to turbo (~900lm) for 10 seconds to warm the light up, then switch back to high (~550 lumen according to the manual) which is then very nicely constant (in my integrating sphere #II it measures the same everytime within 0.5%, which maintains my confidence in both my D40A and my integrating sphere Smile ) . My ‘djozz-lumen’ is based on this high setting of my D40A, assuming that the 550 lumen is correct. It is not really important for what I do that this is really 550 lumen or a bit off (although I want to have it really measured sometime), what is important to me that it is exactly the same output every time, so that all my light measurements can be compared to each other.
ToyKeeper
ToyKeeper's picture
I’m nowhere near that careful. ;P
I’d like to be, but I haven’t been doing much where accurate consistent measurements are very important. So, take my ideas with a grain of salt. Djozz knows what he’s doing. Smile
vestureofblood
Right now I am leaning toward djs 2 ball design. I am also considering doing a coat of barium sulfate on the inside. I noticed that pro grade sphere use this so I assume there must be some benefit. I found a place that sells it premixed in polyvinyl alcohol.
http://sphereoptics.de/en/product/white-reflectance-coating-barium-sulph...
I am hoping it can be applied directly to the foam using a sprayer. Still waiting for them to contact me back.
jhalb
jhalb's picture
Last seen: 2 years 11 months ago
Vestureofblood, you know I'm a big fan of yours. Is this a project you are going to possibly bring to life? If so I would like to know more about it. I'm assuming it will do large flashlights too?
vestureofblood
jhalb wrote:
Vestureofblood, you know I’m a big fan of yours. Is this a project you are going to possibly bring to life? If so I would like to know more about it. I’m assuming it will do large flashlights too?
Thanks jhalb. I would like to make a new setup. I have been using a pretty rough light box for years. The other day I made one of those lumen tubes just for fun, but am not all that impressed with it. I was thinking for the new sphere I will probly cut the hole for the size of a maglite head since I work with them a lot. I will keep the lumen tube for measuring larger lights as it was made from 4” pipe.
I have another question for the pros… What method are you guys using to derive your multiplier?
I have always done it like this.
1. Take know source ( in my case 875 lumen maglite measured by another member).
2. Divide lumen output by lux reading.
Example 875 lumen light produces 2550 lux. So 875 divided by 2550= 0.343
So from hence forth all measurements from other lights are multiplied by .343
However just now reading posts by others I see that Match appears to be doing the opposite.
http://budgetlightforum.com/node/2156
A quote from his post.
_but the most accurate one I tried was to simply take a light of known value, test it to get the lux reading, and then divide that reading by it’s alleged lumen rating. _
Then here I looked and found yet an even more obscure method. Something about measuring the hole??
http://budgetlightforum.com/node/1763
How are you doing it?
djozz
djozz's picture
I think that match did the same as you do but he wrote it up the wrong way around.
The ‘obscure method’ takes a careful performance to do it accurate, but a drawback is that to get the correct number, it is essential that your luxmeter is correctly calibrated, if the luxmeter is off, the multiplier will be off. Your current method does not care about the calibration of your luxmeter, the calibration comes from the reference flashlights.
I’m interested in the coating stuff from Sphereoptics, my own DIY BaSO4 coatings did not have that high reflectivivty that this stuff claims. The website does not mention a price or retailer. If you are able to obtain it, would you mind letting me know where, how and how much?
vestureofblood
Ya, I will report back once I hear from them. If I don’t get a response via email soon I will try to reach out to one of our German speaking members and see if they will give em a call..
vestureofblood
We may be out of lux on that premix even if they do contact me back. I just found this on another site $500-$1200?
http://www.labspherestore.com/SearchResults.asp?Search=6080&Search.x=8&S...
I am thinking if that is the case I may try to make some. Here is where I found out that it was made from.
http://www.ncbi.nlm.nih.gov/pubmed/20068984
PVA is not that expensive, and Bariumsulfate is not that expensive, so I guess they just tack on an extra $450 buck for adding the word “Labsphere”????
djozz
djozz's picture
Maybe, thanks for finding that abstract. I have some BaSO4 leftover and just ordered some PVA. Experiments are to come Smile
vestureofblood
Teamwork makes the dream work. Thumbs Up
sixty545
Then here I looked and found yet an even more obscure method. Something about measuring the hole?? http://budgetlightforum.com/node/1763 How are you doing it?
‘obscure’ ?? (my finger hovering over the ‘RUDE’ button Wink )
I would rather call my method ‘scientific’. It uses one fundamental formula: LUMENS = LUX x AREA[m2] and is valid for a uniform bunch of light.
Never mind, I will issue a WARNING that this method cannot be used for a styrofoam ball because light will leak through besides the hole during the procedure and offset the calibration.
The wall has to be solid (metal in my project).
For styrofoam balls I think the best way is the ‘statistical’ way (guesswork with ‘known’ lights).
