Hmmm... Is there any chance that we unscrew the switch unconscious when this flashlight is rifle mounted and we do de-focousing action? I think there is good chance for that... That would be annoying.
I found if the tailcap isn’t screwed down tightly then yes it is possible. The threads on the body are square cut and require less force to turn them, especially if you keep them lubed. After the first turn you have enough body tube to turn comfortably from the tube.
- So it has hard plastic retaining ring for led? (did you tried to remove it?)
- Driver from bottom side does not look soldered so it probably has bottom retaining ring for driver? If it has I don't see holes...
This flashlight has plenty of good stuff for little $... I really hope that lenses are same or better quality than on 1503 flashlight, and that switch can't be accidentally unscrewed each time while we do focusing/de focusing.
There is a hard plastic centering ring for the LED. You use a pair of tweezers to unscrew it. It is a threaded centering ring. The driver, appears press fit. There is no solder or retaining ring on the bottom side. I have not tried to remove it yet, because I had to complete the review with a working driver. But I expect to have to pry it out. I don’t feel the tailcap will be a problem. The body turns much easier than the tailcap. I always tightened the tailcap properly. It’s also best to tighten the tailcap when the flashlight is at its longest so you can hold properly on to the battery tube to screw down the tailcap all the way.
The AK47 driver seems to be on the red color LED. Archer at Brinyte said the white module uses the 105C driver. When I get in the new driver and LED I will disassemble the driver head. I can say the LEDs are both glued in the top with some thermal paste, and the driver so far has been uneasy to remove. I forsee destroying both when removing them. I had originally told them not to glue the LED, but they did. I will contact Archer at Brinyte about not gluing them. Take my 58kcd with a grain of salt, my meter isn’t calibrated, but you can see from the beamshots that the Brinyte holds it’s own at the 250 foot distance- and it is compared with known lights that my figures are relatively close to. The 250 foot area is that place precisely where I have the markings, which is a hold in the trees.
I agree! I’d like to just get blank pills with the light, and I’ve put in another email about doing that. Brinyte is a bit reluctant it seems to do so, but I’ll keep this thread updated. I will also report back when I’ve modded the light. Should take a week or two to get my driver and then find some time to sit down and get the pill stripped.
Another entertaining and informative review. Keep to your current style; it is so nice to see a well thought out and professionally done video in the midst of so many "unboxing" clips.
Like many, I don't normally look much at zoomies but this one does seem nicely built. I'm trying to stop getting hooked into the group buys but I'd be interested if this one could be had with blank pills to kit out as we see fit.
Looking forward to an update on your modded version, especially with respect to how well this host transfers the heat of a hot-rod light engine.
I hear ya on the group buys. I think I’m on all of the BLF special lights right now. Yeah I’m curious to know what it does. I feel like it should handle it ok, I’m using the BLF driver and it seems to work fine on the A6. But I’d like to compare it to the Acebeam T20, which is by far the best thrower I have. But I also have to fix the emitter on that one first too. So much to do!
I’m working on making that happen. Don’t have any idea of pricing yet, but I’m working with gearbest and brinyte to do it. Normally they wouldn’t have been.
You and Tom Bodett, I guess you both leave the light on for us. Thank you so much for the hard work because your mini films are really fun (in a who gives a dam anyway) sort of way.
Oh FYI the CH10 you sent gifted to me has been gifted to a guy in the Czech Republic for him to “swap” the emitter on before he tears up his new(working) ch10 light he just ordered (who knows he might get both lights upgraded?).
Could you consider to do drop shipping to BLF members without gearbest and other sites. How?
If you'll have lets say 50 flashlights interest you can invest your money and arrange drop shipping with Brinyte(you must deal the price with free shipping cost with Brinyte, and you could also offer faster shipping options if someone wants that).
How to start? Easy...
Each member that obliged to buy flashlight will pay you via paypal, then you contact Brinyte and give them particular BLF member address and then they will ship the item and give you tracking number. Than you can forward tracking number to certain member that bought fl from you (you can simply do it by adding tracking info in your paypal acc)
Shipper is always responsible for package. That means if item got lost on the way Brinyte could reshipp order or do refund.
I really don't get why no one here wants to try this model. You'll earn more money(why not? ) than with stupid aff links :)
Interesting, but I don’t like the shape much, and 1 x 18650 seems too small for a 50 mm. lens. How thick is the lens, or what is the focal length?
Nice that there are large high quality zoomies available now.
So Brinyte doesn’t seem keen on being a shipping service. They mentioned several times working with someone to distribute the lights, which is why I had suggested Gear Best. I do not see Brinyte at Banggood, and Fast Tech has never seemed to like the whole group buy thing. They even suggested I might be the go between for the shipping. I do not have the time to do such a thing though. I have lot of time tied up in my Youtube channel and just life and work in general.
The shape is fine, I don’t find it awkward or odd. I personally don’t like the size of 2x 18650 lights in series, although many people don’t- but I get why some lights need this size. I don’t know how you’d determine the focal length of the light, sorry! The lens thickness is listed in the video though.
34.75mm ± up to 3 mm. Sorry I don’t have an accurate method to measure distances at 2 different points at different depths inside the head. So I basically drew lines on rigid objects and measured those with calipers and added them together. My eyeballing those lines at a 45 degree angle will lead to depth perception variances. Hope this works though.
By the way the focusing is excellent. I can see the individual dots on the emitter at 15 feet away on the wall on low mode. It’s every bit as clear as a SK68s focusing ability. Perhaps a bit better.
That is about the same as I measure for the DX 50 mm. flashlight lens. I measured from the flat side near the focus. I don’t think that is exactly the measure that determines the spot size.
