C8 addicts thread
Using this one for already 2 years, its quite reliable, user friendly and not that spendy as other pro spectrometers: it could be fount at a very reasonable price, its portable and quite easy to carry
Thank you Mitko. I got 4 LG HE2 a few days ago. Maybe I will buy a few XP-L high, instead of the XM-L2.
I will strip an old driver down, make it direct driven and try an Panasonic NCR 18650B and a HE2. If it takes 4-4,5A it's ok. If not, I will order new drivers, too.
You can try this driver Astrolux S1/BLF A6 A17DD-L FET+1 2.8-4.35v 7/4 Modi Taschenlampe Treiber Sale - Banggood Deutschland-arrival notice-arrival notice
Noticed this yesterday and was a little bit confused (know it from mtnelectronics for a higher price). After this I find the BLF "driver" thread with the posts of Toykeeper and others.
Now I have to wait, because it is out of stock, but this is ok, because copperbased LEDs are ordered, too (mtnelectronics is also out of stock).
Im loving my Thorfire C8 that I won a while back. This thread makes me want to mod it. Maybe Ill just get another host to mod. Which C8 hosts have the best heat sinking abilities? or are they all the same? If they are all the same Ill just get an Ultrafire C8 for about 9 bucks on amazon just to mod.
But…
Do I really need anything brighter living in the city? lol
YES!
Just put in a XP-G2 for the first mod…
Get the dedome option if you want, but this is a great, budget upgrade.
A Qlite flashed with Guppydrv is nice too, so for less than $10 it is a much better light.
With the XP-G2, use the XML centering ring, it will work for the smaller LED.
It's all good and bad - good because of China pricing for parts/assembly/distribution, bad because of China quality (and availability apparently). For me, it's about even in cost of parts but I like my quality of build better. Anyway, this driver is obsolete the day it went up on their site - Tiny25 and Tiny85 based drivers is the way to go for TK's latest for Tiny25 power/tail switch lights (bistro), and my latest firmware for Tiny85 based drivers.
We need a review!
http://www.kaidomain.com/Search/SearchResult.c8.2
KDLITKER C8.2 Cree XHP50.2 White 6000 - 3000K depending on LED, 2600 Lumens 5-Mode LED Flashlight - Black ( 1x18650 )
Our Price: $29.93 free shipping
Brand: KDLITKER
Model: C8.2
Flashlight Material: HAIII Hard Anodization Aerospace Aluminum
Flashlight Color: Black (Matt finished)
Emitter Brand/Type: Cree
Emitter BIN: XHP50.2
Color BIN: White 3000-6000K
Total Emitters: 1
Battery Configurations: 1 x 18650 rechargeable Ii-ion battery (not included)
Voltage Input: 3V - 4.2V max
Switch Type: Clicky
Switch Location: Tail Cap
Modes: 5
Mode Memory: Yes (Stay the current mode for more than 3 secs)
Mode Arrangement: Very Lo(5) > Lo (35) > Med(65) > Hi(100)
Hidden Strobe: Double click
Circuitry: Digital Regulated 3000mA Current Output
Brightness:
Runtime: Hi Mode: 40 to 50 mins (manufacturer rated)
Med Mode: 2 to 3 Hours
Lo Mode: +10 Hours
(Tested by KDLIGHT KB3500 3500mAh 18650 battery)
Lens: Multi-Layer Coating Glass Lens
Reflector: Aluminum Textured / SMO Reflector
Carrying Clip: -
Carrying Strap: Yes
Other Features: 1. Constant Current
2. Low Voltage Warning: It will keep flashing when the voltage is below 3V.
3. Waterproof Standard IPX-6 (Underwater 2m)
Dimension: 140mm (L) x 44mm (Dia. of Head) x 26mm (Dia. of Body)
Weight: 155g (not include battery)
Package Content: 1. 1 x KDLITKER C8.2 Flashlight (with package box)
2. 1 x Lanyard
3. Spare O-ring and Tail Cap
I need that driver!
It’s hard to believe a stock light would do 2k lumens with no step down from a single 18650 - the kf8 kdiy is similar and was tested as being truthful. What’s the likely kcd on this?
There will be one , but i guess in about 20-25? days from now …
If the driver is reflashable, there may be people interested in buying the driver by itself. There aren’t many good boost drivers available.
Oh my!
Thanks for that tip, that looks like an interesting flashlight!
(and budget friendly)
Will it outthrow an xpl-hi with blf driver, or would the die be too large and be more a ‘flooder’?
Buy it then? Its the 20mm driver that KD sell.
Ive used it in a EE X7 and a S2.
I’ve put one in a Thorfire C8S with a XHP50.2 and OP reflector :
From this post
khas,
Thanks for the white wall beam shot. Nice large hotspot.
Probably not as much throw as an XPL-HI though. Do you have nighttime distance shots?
Is the driver bore in the Thorfire C8S 20mm? I thought it was a bit smaller. How did you fit the 20mm board into it?
The Thorfire C8S is a better host since it has an integral shelf for good heatsinking rather than a screw-in pill like the KDLITKER host.
The Thorfire C8S tailcap is also better because it has thumb grooves.
Thanks again.
The new model C8s I have with the updated tailcap does have a 20mm driver. My older ones all had 17mm.
It’s not a thrower the XP-L HI has a much tighter beam. Sorry no night time shots yet, this time of year in Denmark it gets dark very late :weary:
The driver size in the two I have is 19.6mm.
I actually don’t think the KDLITKER C8.2 is a bad deal for around $30 , I payed about $37 in total for my build.
The H1-A driver in question uses a PIC 12F683 microcontroller, so it should be programmable unless they locked it. We just need to reverse engineer the control scheme. I have been doing some testing on the new KD boost drivers, and they do live up to their claims.
Will be throwing one of these in a Convoy C8 I have modified soon.
How about the beam output on KDLITKER? I am looking forward to buy one but couldn't find any review.
