The Opus charges to 4.22v(DMM) and discharge to 2.80v. All the test I did with all my brand new cells (B, GA, LG HG2, LG MJ1, Eneloop Pro, etc) results with a higher capacity than the cells rating. A18650B 3400mah has a max capacity of 3350 if my memory is correct. All my results were around 3500mah.
You probably have a superspecial unit but I don’t think so. All the results I saw when I gave feedbacks on Aliexpress are around the same as mine. You have the MC3000. Take the datasheets of the cell and settle your MC3000 according to them. You will have your answer. If your results are the same with your Opus, your charger is really special.
Edit: If your results are the same with the MC3000, I will give you my mail and you could send me the photos. If you do not want to try your MC3000, do a charge test(C>D>C) with your Opus and send me a picture of your screen with the cells on your charger.
Yes, your memory is correct that the NCR3400B (which I also have and tested several times) has around 3350mah of capacity, that’s the usual ballpark figure I get too in my Opuses and iCharger when discharged to 2.8v.
I just check the ncr18650B capacity: min 3250-3350mah at 25celsius.
Lol…read my edit ….If you could prove me that your Opus BT3100 doesn’t read high, I will say in this thread that you were right.
You say that you have 3350mah when you discharge at 2.80v. The cells spec says that you have 3350mah max(I give you a chance) from 4.20 to 2.50…. just with that, you see that it is not accurate. Where is the capacity between 2.80 and 2.50? To be fair with you, there is not a lot but there is a little, around 50-100mah probably… I will check it later. We will go with 50mah…+3350 you have…3400. Your higher at this state.
If I do the test with the MC3000 from 4.22-2.80 like the opus, the results are between 3125-3200mah with brand new B cells. With the Opus with the same cells, 3540-3610mah.
Mc3000 from 4.20-2.50 with a 10 cycle B that I removed the pcb, 3252mah and 3502 with the Opus. Don’t forget the cell capacity should be between 3250-3350mah according to the specs.
Testing with 2500 volt succeeded, but 5000 volt between mains and low volt side on the power supply failed. This means this power supply is only safe for 110VAC, not for 230VAC (This is the US supply, the EU supply passed the 5000V test in the first review).
Conclusion
The charger has been improved with the updated software, but many of the problematic areas are stil present:
The user interface is fairly easy to use, but it may take a some time to learn what the different modes does.
The high current peak from the power supply is not good for the power supply and makes the charger show wrong readings.
Generally the peak charge and discharge current for LiIon are a bit high, especially on the outer slots.
The resistance measurement has limited use, not only due to contact resistance, with NiMH the precision is generally low.
I would have preferred constant current, instead of the pulsing.
The NiMH termination has changed, but it is a bit slow to terminate now (It does definitely fill the cells).
LiIon charging now works on all slots. The NiMH charging is probably not as good as in the first version, because the -dv/dt is rather slow to terminate
The analyzing function makes the charger very useful for anybody that wants to know something about the state of their LiIon cell.
The charger is not perfect, far from it, but as long as the problematic areas are know, the charger is a very useful tool
Liitokala Engineer Lii-500:
Testing the EU mains transformer with 2500 volt and 5000 volt between mains and low volt side, did not show any safety problems.
Conclusion
I like the user interface, put a couple of batteries in and select mode/current with the respective buttons. As long as the number keys are not touched the selection is for all slots (Showing all slot numbers would have been nice).
The charger is very good at charging LiIon, but stops a bit early on NiMH.
The fast test works fine on LiIon, but with NiMH it shows too much capacity (the full test looks more correct).
As usual I am not impressed with the resistance function.
The usb output has very low noise, but need multiple cells to work well with 1A load.
The final result must be that it is a good charger with a useful analyze function.
I have both & prefer the Liitokala UI & I think it charges a little faster when charging 4 x 18650 cells than The Opus, although that could just be me. (the Liitokala is also a bit cheaper in the UK than the Opus)
Although it gives a higher capacity measurement, this is a great charger. I like more my Opus than my Nitecore D4. If I would not have the MC3000, it would still be my daily charger.
For the Liitokala, I don’t have it so I cannot give my opinion.
I also have a Nitecore D4 as well as the Opus & Liitokala.
The D4 is fine as a basic charger, just a little slow when charging multiple cells which is not a problem really.
Of the 3 chargers the Liitokala is my favourite.
In my post above wherein I quoted a 2.5v cut-out voltage, it was done with the iCharger, not the Opus, and the cell used was a Panasonic NCR18650PF. as shown in the link.
With Opus you can charge up to 4.35V (but you have to open it to get to the switch). You have the refresh program for NiMh batteries, you can charge up to 2000mAh on bay 1 and 4 with only two batteries. On the negative side, you have the noisy fan.
So I have two Opus BT C3100 V2.2 and two Lii 500 chargers. If I need to test or charge in the night, I use Lii 500, on the day Opus.
go for the Opus, its voltage are spot on, on my 2 DMMs my Liitokala 500 overcharges to 4.22V
and since this question has been asked many times, (it was something i wondered myself for a long time, until I bought both), i will paste here what I already written on 12/21/2015 - 07:24 in the Lii500 review topic Test/Review of Charger LiitoKala Engineer Lii-500 - #64 by TheBo
QUOTE: 1) The Opus uses pulse charging (HKJ would prefer it didn’t) and that the LiitoKala slightly undercharges NiMHs.” (quoting like this as quote button on OP is missing since site upgrade).
I saw a link posted some time ago (by tatasal maybe?) about tests showing that pulse charging is not an issue. I couldn’t find the link though. Has this changed?
“go for the Opus, its voltage are spot on, on my 2 DMMs my Liitokala 500 overcharges to 4.22V”.
Accepted charging voltage for 4.2v cells is +/- .05v so 4.22v is absolutely fine.
Immediately off the Lii 500 my DMM (Amprobe) shows cells at 4.19v.
“3100 has a more precise Voltmeter in my opinion and chargin is always Spot on I always found batteries at about 4.17-4.19V even after 30min pulled out of the charger”
Surely for the voltage to be up to 4.19v 30 minutes after charging dosen”t that show that the Opus is also charging over 4.20v ?
Not arguing just curious ?
At the end of the day I have both chargers & they are both fine chargers IMO I just prefer the Liitokala.
I demonstrated that Opus provides a higher measure regarding the capacity because you affirmed the opposite in your first post and this is not the first time. All I ask you is not to make this statement anymore because it is false and this will induce member wrong.
If you need some help with the MC3000, you have my mail. An advice, don’t bother you with the dummy mode, go straight in advanced mode and you will learn a lot about parameters to charge batteries.
Here are the results of Discharge Capacities of my Opus BT-C3100 v2.1 and v2.2:
Cells used: Brand-new Samsung 30Q flat-top, brand-new Sanyo UR14500P 840mah and a slightly-used Panasonic NCR18650B 3400mah
Charger used to charge the Sanyo 14500 is the Opus itself.
18650 cells were charge at 1A, 14500 was charge at 700ma. Straight discharge mode was used in the two Opus chargers.
The photos below will show that the Opus does not read high as you believe it does, and is just as accurate as the MC3000, discharge-capacity wise:
The O ma pic just shows that discharging has stopped:
You said you got 3252mah on your MC3000, well I got 3254mah from my Opus v2.2 (not bad at 2mah difference huh)
I can’t seem to straighten up the pics, can somebody please do it for me? Thanks
