I lost an expensive Benchmade automatic pocketknife to a loose clip one day. Was about a decade ago, maybe 12ish years now. I even knew the clip was loose and hadn’t bothered to tighten it up. I replaced the knife and now I keep a much closer eye on my pocket clips, but I still regret losing that knife. Sorry for your loss.
I would get the aluminum again… Did you mod it at all? Surprising nice with a domed emitter as well…
What domed emitter did you use? XP-L? XM-L? I’m thinking about changing the emitter on mine. How’s the beam pattern?
I have a Nichia 219c 5000K in it currently, and tried an XPL 7A prior. The beam profile is still great with a domed emitter… Beam is slightly wider, with a good transition from hotspot to corona, I will get a wall shot comparing them up later…
Oh, hmm…just noticed the public code is still good for the aluminum Kronos X5/X6 set, although about $7 more than it was. Seems silly to order just an X5 now. But what am I going to do with the spare X6? Too bad I can’t get two X5s for that price.
Looks like Banggood has the better clips for sale now, so order one with your K5… HERE
Then get your copper fix HERE for a back up…
Comparison pic of X5 with Stock Emitter XPL-HI on left, and Nichia 219C 5000K (domed) on right
The 219C is not as intense as the XPL HI, but the hotspot is smaller with a more even primary spill around the hotspot.
Hope this helps…
Awesome, thanks for the pictures! It really does help.
I forgot to add, if you do not like the K5 clip linked above, the Skilhunt H15 clip also fits. You can get them if you email service@skilhunt.com and ask for a H15 clip. The shipping costs more than the clip, so you may want to order more… The H15 clip is very nice on regular to thin clothing.
I don’t know if the X5 is the brainchild of someone who has thought long and hard about what he was going to create or that it was a spur of the moment idea to build another X6, but smaller. The result however is one of the nicest lights I own. Combining some of the better aspects of lights that were intended well but got cought up in cutting various corners. It is a kind of light that grows on you. And it is a shame when you loose one. For that reason I never carry such a light with a “clip-on-clip”. But always with a clip that has a base ring around the tube, like some Solarforce, or a clip that has to be screwed onto the tailcap. So I carry my lighter (Alu) lights with a Ti clip from Rey. The SS X6 is even to heavy for that clip, I carry that around with a big old Ti Nitecore clip.
Henk4U2, you got any pics of the lights with those clips on?
can we carry lithium batteries on aircraft now?
Hmm…so should I be concerned that when I lose a light, I wind up buying 3 more?
Well, sure… This is BLF after all. No one here will recommend less lights… Lol
The Aluminum X5 and a Copper A01 come out together ~ the price of the Astrolux SC…
Yes, in your carry-on. You can’t have them in your checked baggage.
Sorry to hear about your loss… at least my story had a happier ending.
Last night, I dropped my flashlight somewhere along the side of the road where I had been walking. The light was my heavily-modded TrustFire F20 that has been my EDC for nearly four years now: TrustFire F20 mod with reflector bonus!. Since that thread, the light has been completely gutted. I think only the lens is original. Aftermarket reflector, XM-L2 emitter, Nanjg 101AK driver in three-mode group, and replacement switch.
It was getting dark, so I walked back to the house and got my S3 XP-G2 triple, and walked back near the area I had last used the light. Finally found it deep in the grass in the ditch.
Makes you realize how much you can get attached to a particular tool. I doubt I could buy this same light in the same quality as this original Manafont item. Even if I could replace it, I still couldn’t get back that patina; four years worth of pocket-carry wear to the anodization…
Ummm. I left a 2 cell flashlight with batteries in my check in luggage and there wasn’t any problems tho!
Pray to Saint Anthony, the patron saint of lost flashlights :innocent:
Aside, when I travel and take a flashlight, I put my name, address, and contact info on a piece of paper inside or on tape on the battery, with “reward for return if found”
Haven’t lost a light since I started doing that so don’t know if anyone would bother contacting me, but a little hope is worth encouraging. Some people are honest out there.
Thats a darn good idea. I just may re-wrap some batteries with my name and phone number underneath the clear wrap. A luggage tag for the flashlight
> It was getting dark
This is why I attach glow-in-the-dark keyfobs to all my flashlights. (andygold at CPF used to make them)
There are other kinds, but I don’t know whose are good offhand. Anything is better than nothing though.
Living near a major earthquake fault, when all the lights go out, it’s good to be able to find the flashlights.
Even more so when I lose one in the weeds. Come back with a blue-white or UV light source and the GITD material lights up nicely.
I didn’t even THINK about UV! I have several UV lights, including a filtered 365nm and a triple-emitter blaster… The lost-and-found light has a GITD o-ring at the lens and a GITD tailcap boot. A good follow-up sweep with the UV light should have made the light stand out for much easier locating…
