Thanks for doing the measurement. Did you happen to test the with-dome XPG3 in your host? Has anybody done lux measurements with the stock XPG3? From djozz’s lumen measurements and comments it seems like it should perform pretty well even with dome since its output was close to the XPL HI that was measured.
Didn’t try with the dome on, sorry. I may give it a go out of curiosity, but I can’t see it being any better than XPL, plus at ~8 Amps, the cells are going south pretty quick….
Thanks for test.
Even bad(new production process) XP-G2 seems better than new XP-G3. So is there a reason to be enthusiastic about this emitter?
I think there is no reason for that.
Even if it could driven at 8A reach performance of good old XP-G2(s42b for ex) driven 4.2 –4.5 A; same performance should not be considered as an improvement imho.
I want to say that at that current sag G3 would really have to be special and have more than 20% better performance than old good G2.
From your test guys I think that is not going to happen.
Thanks for the test mate. I like this emitter its a good mix and plus the price is great. It is just as bright as a XML2 ( the harden driven XML2 i own is only 5amps) this does use more power and it throws almost as far a XPL-HI so i would place in between these two!
I bought some on DTP copper boards for $3 compared to the $9 each i paid for the XML2 and XPLHI.
I have a XPG2 sitting here but no host for it i really want to DE-dome it and try it.
Something doesn’t add up here. Not questioning you, or what you saw. Just saying that mathematically, the results you posted here don’t add up somehow.
I must admit that I expected a better result, which is why I done it again with a second emitter.
Maybe it has something to do with the application of the phosphor & the dome as a package, & when the dome is taken out of the equation, it all goes pear shaped. :question:
Yeah, there seems to be something like that going on. I think MEM posted once that a de-domed XP-G3 has a concave surface to the phosphor. I dunno. With a total output (domed) in the range of XM-L2, and the die size similar to XP-G2 (not much different/larger), there should be no contest on throw. Here’s hoping somebody gets to the bottom of this before it drives us all crazy! (For some of us, that’s a short drive.)
Oh, by the way, thanks for doing this testing and posting results. Forgot to say that before! :innocent:
Yes, I did measure the domed XPG3. In an eagle eye X6 with bypassed springs and a fresh 30Q, I measured 58.6kcd. An XPL HI V2 3B in the same host did 71.4kcd. The XPL draws considerably less current to do it, also.
Sorry if I’ve missed this, but is a regular domed XP-L a better choice for “max lumens” versus an XP-G3? I’m looking to mod a second Nitefighter BT40S bike light (1st one modded with Nichia 219C’s - 4 LEDs @ approx. 2.0A each) and was going to try it with XP-L’s to go for more lumen output. I probably won’t boost it to 2A per LED though; think I’ll come down a little but not sure where. At 2A per LED with the 1st light my low mode really isn’t low enough and turbo is just for “WOW” factor and heats the light up too hot too quickly for normal riding.
Suggestions? (Sorry, don’t wish to derail; just trying to grasp where XP-L stands versus XP-G3.)
Well if you are only driving it at 1.5-2A per LED then you are not looking for max lumens anyways, max lumens happen around 5A+
Far as which will give you more lumens per watt, well it depends. At low drive currents he XP-G3 could actually come out slightly ahead due to the lower VF. Although in the real world just go with the XP-L if you want may lumens. The normal domed version if you want flood and the “HI” version if you want throw.
Yeah I didn’t mean I was driving the light for max lumens. What I meant was which LED when driven at say 2.0A would yield the most lumens.
Yeah I’m wondering which might work better “in the real world” where with bike lights we have to deal with battery cabling & connectors thereby making it difficult to pull high amps from an 8.4v pack. On my 1st BT40S mod I had a hard time even getting 3.82A pulled from a pack.
I was surprised when I saw in the graphs that the XP-L HI’s output was still so high (lumens). I thought the HI version was at a significant reduction of lumens vs. the standard XP-L. I think in my application the HI might be too throwy though I’m not sure how it might turn out with the stock optic (optic is pretty floody).
According to djozz graphs the XP-L has just slightly more output over an XP-G3, with the XP-G3 having a slightly lower vF. I wonder if there is a significant difference in heat between these two, anyone know? Perhaps my decision will come down to which LED is available in a nicer tint. My favorite tint is a 5B1 (which I buy in XM-L2’s). I think it renders the most realistic colors riding through the woods. I don’t really like a 3C as I don’t think it’s neutral/warm enough.
At 2 amps it is too close to call and honestly unimportant which one will give you more lumens. Worry instead about cost, tint and CRI.
I love the XP-L HI (when it is a genuine tint and bin), I use them basically exclusivly now days for me “real” lights. I much prefer the beam pattern and much less tint shift on the edges of the beam. They also appear brighter then the domed version in most cases due to the tighter hot spot.
That said I did just build an XP-G3 5700k 90+ CRI S2+ (my first XP-G3 build even though I have had the LED’s for months). I am impressed with how well the G3 is working. I can see this becoming my “cheap light” LED in a hurry. Only real issue is some tint shift on the edges of the beam but it doesn’t bother me and with the right reflector/TIR I have got rid of most of it.
It is putting out ~1150 lumens @ ~6.75 amps
I also have a high CRI XP-L with the same exact setup both using tripledown drivers. In the regulated 2.5A mode they both get hot at the same speed, now in turbo the G3 get hot faster due to pulling more amps but it also puts out more light then the XP-L (the XP-L on turbo pulls a bit over 5 amps IIRC and makes ~1050 lumens).
Honestly either will work just fine for a bike light, The XP-G3’s are a LOT cheaper though.
True on all accounts. I wouldn’t even notice the lumen difference by eye between XP-G3 & XP-L. I guess another important issue would be the beam pattern created by XP-G3 vs. XP-L.
If it helps, teardown pics of the BT40S are here and beamshots stock here modded vs. stock here.
(Sorry, at this point I should have started a new thread!)
