thank you all!
that GB is alive atm - but please do not public post infos - stay private if you communicate ;)
thank you all!
which GB?
Also interested, I do likey GB’s
Hi!
the great little
is available for only US$ 3.90 at banggood atm
it is a USB-powered multi-chem-Charger with Powerbank feature
on google i stumbled once over an mod by hypertonie from a german forum.
he upgraded the charger with an small voltmeter
and so did i... - now its also a cell-tester!
i bought the Voltmeterhere: http://www.banggood.com/0_28-Inch-2_5V-30V-Mini-Digital-Voltmeter-p-974258.html?p=IO0117468906201403!A
do not forget to adjust the potentiometer for accurate reading!!!
open the Lii-100, cut a rectangular hole and fit the voltmeter (2 drops of glue)
done!
Nice little mod MM.
Well done, i like that.
What a clever and delightful mod !
What amazes me about these little chargers is they don’t get warm/hot at all while charging. In contrast, my XtarWP2 is very warm all the time.
Why is that?
Sweet mod!
Added both to my shopping cart!
Great mod there.
Nice mod! the voltmeter fits perfect.
Any codes for the Nitecore SC2 charger?
Hi Martin
Any codes for a Thrunite TH20 headlamp?
Thanks
i asked
Nice and useful mod. Thanks for sharing.
new codes arrives for:
-> limited €U stock with great price!!!
af first a goodie:
astrolux | S3 (my Link) | ef5700 | $ 22.75 | PRICEDROP |
finally on stock :)
great deal – ask for details
Product name: | LUMINTOP SD4A CREE XM-L2(U2) And CREE XP-L HI LED Flashlight |
Total Emitters: | 1 |
Emitter Brand | CREE |
Emitter Type: | CREE XM-L2(U2) / CREE XP-L HI |
Max Lumens: | SD4A-XML:1000LM SD4A-XPL: 920LM |
Intensity: | SD4A-XML:20300cd SD4A-XPL: 40000cd |
Peak Beam Intensity: | SD4A-XML:285m SD4A-XPL: 400m |
Mode: | 8 Modes(Low-Mid-High-Turbo-Moonlight-Aviation Signal-SOS-Strobe) |
Max Runtime: | 51h |
Battery Configurations: | 4 X AA or 1X D Cell |
Switch Type: | Clicky |
Switch Location: | Side |
Working Voltage: | 0.9v-6.4v |
Impact Resistant | 1.5m |
Waterproof: | IPX-8 |
Weight: | 178g(without battery) |
Size: | 112mm(L)x41mm(Head)x41mm(Body) |
Nice price on the S3!
Any code for imalent DN11?
there will be :)
Is the Astrolux S3 made by Manker? If so, presumably it won’t be available for much longer?
