Yep, you are exactly correct, the 7135’s are all directly connected to the ground ring that is as wide as possible to heat sink them directly to the flashlight body.
I also would like to solder all the pins, I tried at first but it just wasn’t happening on the small drivers and the large ones are a lot cleaner if I don’t, not even sure how I would to be honest.
Do you know off hand where in the schematic I would add in an LDO BTW? I can add it but not sure how to keep everything working optimally with it being an optional component.
I look forward to seeing narsil made compatible with triple channel drivers but after all the work on the Q8 you deserve a break. Take your time (just don’t forget us entirely lol).
Yep, I was a bit surprised just how small the whole boards look when they showed up. Gets disorientating when you build them and they are 8”+ the whole time :nerd_face: .
They are a bit oversized for the actual pad and the pads are part of the overall ground ring to maximize both current flow and mostly heat sinking.
For the LDO… 4.7 ohm, then C1, then the LDO and then C2.
LDOs are very particular regarding the output C used (C2 in our arrangement). Check the specific data sheet, but typically a good X7R, 1 uF or more, is required.
That is kinda what I was thinking, although the specifics of how to lay that out so that the LDO is an optional component is confusing.
C2 being used as both C2 and for the LDO was another issue I was not sure about. So it sounds like using C2 for both would be fine? Possibly just a larger cap?
I will try adding it to the schematic later and see what you think.
Think'n, I should combine ramping and mode sets into one -- single click for next mode, press&hold to ramp. You really want to hit full 1 7135, full 8x7135. Under pure ramping, you will not be able to find those non-PWM levels so easy. could do it another way with a pause in ramping, but that UI may not work well - hard to recognize the pause, take too long, etc.
The issue is more so how to wire the LDO into the rest of the circuit so that it will function with it in place or not. Bridging the pads of the LDO itself to bypass it is an option I was considering, the issue is seeing if a resistor is the correct size to do that or if I can adjust the pads to allow that to work.
I am thinking that since you don’t need the diode with the LDO, I might be able to use that as a bit of a “switch”. Gonna have to play with it some.
It would do it's usual thing - single click thru the modes, OFF being one of the modes. Also there's a mode "lock-in" time - when a mode is on for like 1.2 secs, the mode is locked in, then the next single click turns the light OFF -- all standard, always has been in my e-switch firmware from the beginning (2+ years), way before "Narsil". For this new support, if you are locked in a mode and press click&hold, it will ramp, so you can still easily change the brightness, and after press&hold, you want to switch back to mode set level, simply click within 1.2 secs of ramping, and you are back to toggling modes.
What I'm sacrificing is reverse mode navigation for 1 mode to the previous mode, but ramping can still accomplish that because ramping will implement the ramping rules I have now - you can change the direction of ramping as long as you click&hold within 1.2 secs of the last click&hold. Again, nothing different there - it's what I've implemented in ramping based on requests in the BLF Q8 thread.
The double-click, 3X and 4X clicks in ramping now will have to stay to allow quick access to max/turbo, battery check and soft lock-out, respectively. I'm not crazy bout this because fast single click sequences can get confused with multi-clicks, but you have fit everything in somehow.
Note: Always single click ON, single click OFF - that's the priority I don't want to sacrifice
Ohh - click to ON is always to last output level (memory), whether you got there from ramping or a pre-defined mode level. If you hold for 2 seconds or more, 1 click OFF.
This is great! I hate lights that make you hold down to turn it off. I like lights with one click off. I like lights with immediate access to low and turbo from both on or off. Sounds like your doing pretty good!!!
Very nice, I have honestly never used your firmware before as none of my e-switch lights have aftermarket drivers in them except the SRK’s. Those use a 13A though so obviously not gonna work with Narsil. Just never had a need for an e-switch firmware before besides SRK drivers and they did what I needed at the time.
With the Q8 coming out though and the 4s driver I plan to design for it (if PD doesn’t want to do it first that is), E-switch is becoming more important.
At the budget levels, most of the e-switch lights had a horrible UI. There's been lots of improvements though in the last year or so. Also some don't lend themselves to be modded with a replacement driver because of the way the switch is mounted, mostly. I much prefer the e-switch though - the switch is in the correct place for the way you would normally hold a flashlight, plus more features, more consistent means to clock and monitor the switch, easier to activate, etc. Just a lot of advantages for the UI/UX.
