The reflector start to broken after 1h after I was using the flashlight,so I think something vapor went there with the hotā¦ the conduct paste and solder past were economical, but the solder paste have the acid icon, I think depend by acid vapor because the mirroring was clear when I reassembled the flashlight, and it become Grey when was closed, I didnāt rub itā¦
Hmmmm, must have been the acid flux getting hot from running it. I havenāt been soldering for a long time, but I use the no-clean solder and top brand solder paste as well, Kester for both, and I donāt ever clean up. Iāve heard people talk about clean-up of the flux though, so this must be why.
Did your emitter get burned? Sometimes flux will splash on the silicone dome and then it burns when in use, this can smoke up the reflector as well.
Mmm I saw same paste on top of led silicon come to think of it, maybe it burned on top of led and did an acid smokeā¦ Could be this one the problem? How can I clear the emitter good?
But the reflector is corroded, can this kind of smoke corrode the mirroring?
Oh yeah, that can do it for sure!
If I see any flux spatter on the dome I clean it with de-natured alcohol. Many use regular alcohol I think. Iāve even heard of people washing it with water, but ā¦ alcohol evaporates almost immediately. De-natured alcohol doesnāt leave a film, or thatās why I use it (could be wrong, donāt trust my memory! Get more feedbackā¦)
Edit: To be honest, Iāve flicked off the spatter with a careful fingernail before. But man, Iāve killed a lot of emitters in a few hundred mods, I donāt sweat it anymore because I have so much stache itās not a big dealā¦ used to HATE having to order a new part and wait for it to get here! Now I have boxes and boxes of pieces parts of all kinds. Stuff I forget I have.
Oh, thank you very much for help man Iāll clear the emitter tomorror and Iāll start to wait the reflector from aliexpress, yesterday I tried to clear the emitter with a fingernail, Iām lucky I didnāt broke itā¦ :person_facepalming: itās like 3 months Iām modding and waiting for parts, all the times somethings went wrong: Fet driver 17mm and flashlight 20mm, spring oring adapter too much big, burned led because not noctigon, and now corroded reflector, I hope this will be the last problemā¦ :laughing:
And THAT, my friend, is how you learn and get addicted!
Good luck!
You are in good company here friend. This forum is filled with a great variety of people from beginners with questions and lots of problems to advanced mad scientists (like Dale) who are happy to help beginners while dreaming up incredible new levels of flashlight technology and pushing boundaries.
Thank you for sharing your experience!
We all learn from each other here. That is the magic of BLF.
Cheers!
Oh yes, is very magnific forum, I found the problem 99% thank to all of youā¦ My l2 have driver Fet +1 with original 24awg, led xpl hi neutral with noctigon base,I made bypass to tailcapās spring and to driverās spring, Iām using keepower IMR 4200 mAh, do you think is enough as a mod, or maybe I can do better mod?
20 ga leads would allow more current. There are a few other cells that would probably give more power as well, although that one is fairly sufficient. I tend to use the Efest 26650 4200mAh (dark purple) and have had good luck with Basen cells from Banggood.
You want to watch and make sure the reflector is clearing the top of the leads on the mcpcb. Sometimes I file a bevel on the edge to clear the pads and Iāve taken to covering the base of the reflector with 2ā wide Kapton tape then cut the opening out with a scalpel or X-Acto knife. You still have to watch though as the Kapton tape can get torn on the soldered contact and still allow a short circuit. To counter this, I press on the lens when screwing the bezel down in an effort to keep the reflector from turning.
Using a flat edge like the blunt end of a small file or a large flat blade screwdriver to press the wire flat while soldering it onto the mcpcb can help a lot as well, keeps it as low and smooth as possible.
this is what i did to my L2:
i puted tape in reflector
the i put a oring on the driver to avoid short circuit
this is the emitter with some paste around that i tried to clear with alcool
so you think is better put some tape on the solder leads on the mcpcb as well? to isolate it from reflector? does the tap could do smoke with hot emitter or is not a problem?
Say sorry to butte in here, very interesting topic, wanted to tell JDub and Dale thanks for the suggestions and help re: my goofed up reflector, and Dales offer to sand out my reflector, thanks very much I appreciate that but I had to exhaust all avenues before taking up so much of your valuable time Dale and Simon did sell me a new reflector for the L2, cost 0.01 cents x 655, or $6.65, but that is a lot of times to push that little button on his penny link and I think he made me buy a new clear L6 also, I canāt recall I think, not really sure if that was his doing or I just loved the heck out of the looks of that light, well either way, light and reflector on itās way, ye haā¦
Sweet T18! Yeah, that clear L6 is hard to pass up onā¦
jurgo, if thatās regular black electrical tape then yeah, it may be a problem. The glues and material used for the tape itself really canāt take high heat and will melt and smoke. Kapton is a heat resistant insulator style tape, itās a golden brown transparent in color and is used for electrical insulation, usually where very thin is in. Like, they put a thin strip of Kapton tape on the side of a battery where the copper strip goes up the side from bottom to top on a protection circuit.
Hereās an L6 reflector that Iāve covered the base with the wide Kapton tape, I like the 2ā wide because it covers in one piece.
Ok i bought Kapton tape 20mm, now Iām. Waiting for simon answer and Iāll buy the reflector, thank you again for help, today I saw the led and I noticed that the silicon on top has a very very small hole in the middle, maybe when I tried to clear it with the finger, I hope this will not change flashlightās performanceā¦
There is a good chance that āvery very small holeā happened because of the above chain of events.
Do you know if is possible increase turbo mod of driver Fet, more than 30 seconds? Because my flashlight is still cold after 30 seconds of turboā¦
Yes.
But remember thereās always 2 sides to a coin. If your light is still ācoldā it may very well mean you do not have a good thermal path and the heat isnāt getting into the light efficiently to begin with.
Edit: If you are using Bistro firmware on the FET+1 driver you can change the timing on thermal step down from the configuration menu at level 7. Choose the 7th level, wait for the medium output level to shift to High then wait for the heat to climb to a level youāre comfortable with, turn it off. OR, while itās in the medium output level you can turn it off and thereby disengage the thermal step down altogether.
If itās not Bistro the program would have to be re-written and re-flashed into the MCU.
no, isnāt the Bistro FET+1ā¦ i think it dont become hot because 30 seconds are not enoughā¦ i dont like i lost turbo while iām try to find something in the nightā¦ i think next time iāll buy custom driver fet, with maybe 120 sec turbo and firt start in turbo as well!
Up above, in post #1414, you state that it has an FET+1 driver. I was going on that, without knowing what firmware it has on it.
Bistro will let you select L-H or H-L operation at will. You can also enable or disable moon at will. And last mode memory, on/off, at will. And of course, the programmable thermal step down instead of a timer. Bistro has a LOT going for it!
