Love the forum, guys. Thanks so much! This will be my first post.
Ok, as a relative newb fresh on the budget torch turbo train to hell, I have made a bunch of purchases in the last month, and am finally starting to receive some of my Manafont orders,
On highly anticipated arrival was an UltraFire C1 body with the extended “assault” bezel. I’ve already gotten my SolarForce L2 a week ago, so my expectations for the range of quality with these P60 hosts has been set and/or understood. My very first high-output torch was an UF wf-502b from Amazon, and I am assuming for $16 the drop-in that came with it is a generic version of the UF XM-L T6 5-mode. I love the 502b host - good finish, threads, etc, and the drop-in is fine except for the silly blinky modes, but as of now, it is the only drop-in I have until i get the two UH XM-L 3-modes and the UG Q5 1 mode in the mail from MF. I have just been swapping that first drop-in that came with my 502b between the different hosts (502b, L2, and now the C1) until more drop-ins show up. At this rate, I will end up with more hosts than drop-ins anyway, as I have a 501a on the way as well.
Anyway, on to the UF C1. I had read a review or three here, on CPF, and MF, and all seem to note the quality and compatibility of the C1. I really dig the design, although I know its borrowing heavily from Surefire. But my first impressions are disappointing compared to my delight with the 502b. I won’t bother to compare with the SF L2, other than maybe by weight.
My C1 came well-protected in 72 layers of bubble wrap, with the “stainless” “assault” bezel attached. I only ordered this body with that bezel because based on other reviews, I was expecting it to also come with a flat bezel as well. It did not. No biggie. This extended bezel doesn’t seem to interfere with the beam quality much, if at all.
Initially the design is pretty awesome, and the flat sides on the battery tube make more very comfortable handling - surprisingly comfy, in fact. Also a nice little unexpected plus - the thick rubber washer that hugs the tube for grip and the fairly decent non-removable belt clip, in addition to the laynard. Bang for the buck, I suppose.
The finish is crap. There are scratches and dings like it’s a used light. Not that I mind too much, but I paid for a new light, and the finish or anodizing on my other two hosts seems way more durable. The threads and o-righs were totally dry, and the threads themselves are as rough as they could be. I’m sure they will wear in with time, but I don’t like the idea of aluminum shards building up in my host. I lubed everything up, whitch seems to help. The tolerances once everything is screwed in seem tight, at least., but I don’t plan on taking a shower with this torch any time soon.
One interesting issue that will turn this semi review into a question, is with the lens. With initial disassembly of the major pieces, the lens just fell loose from the head and hit the tile floor at my feet. I didn’t like that very much, and now I have a nice little chip on the rim of my lens for my long-awaited new host. Doesn’t effect the beam, just my inner child. Anyway, no matter how I tried to put that lens back in, it would just rattle without any support from the other pieces. Tried placing it on top of the o-ring in the front, no good. Tried putting it behind the o-ring, no good. I can’t figure out where the lens on this C1 originally was or is supposed to go, or why it seems way too small in diameter to go in the front of the head. I ended up shimmying the lens through the hind end of the head, and changing the o-ring from the front to just behind the little ridge in the head so the lens has something to rest on. Once I screwed everything back together with the drop-in installed, it seemed nice and tight again, and the lens hasn’t come loose since.
So what gives? I was not expecting instructions or anything from Manafont, but those of you with UF C1s - where the heck are the lens and front inner o-ring SUPPOSED to go? Also, was your C1 thread and finish quality kinda crappy like mine?
And for the record, all of my UltraFire orders were made before I discovered Solarforce L2x, and the L2 arrived in more than half the time these MF orders came in. Otherwise I probably wouldn’t have bothered with any more UF orders, and just gotten a few more SF L2 models. Then again, that probably isn’t true either - I’m kinda addicted to this stuff now, and I actually like the UF hosts - especially that first 502b, and am still pretty amazed at the quality and materials for the price. But the C1 is the first I’ve gotten that ALMOST seems worth the $9 I paid for it. LOL. The weight is nice, and that cool rubber grippy ring is kinda awesome. But I don’t like the exposed threads between the bezel and the lens, I don’t like the tread quality in general, not happy with the finish, and I really don’t like loose lenses that fall out of my torch host and chip on my tile floor. But, I’m kinda still pretty happy.
Thanks guys. Any feedback is much appreciated.
