Zebralight SC600 = Body Diameter: 25.4mm
Length: 107mm
Emitter: CREE XML T6 0D CW / CREE XM-L T6 3C NW
Material: Aluminum Alloy hard anodised ; Stainless Steel bezel
Mode: 6 with memory (Hi>Mid>Lo>Strobe>Turbo>SOS); Twisty on/off;
UI—- Head Twist On/OFF; Pat the tail Cap to change modes; Memory High mode after 2 seconds, Always start on High mode
Brightness: Hi(500lumens)>Mid(200lumens)>Lo(100lumens)>Strobe>Turbo(680 lumens)>SOS
Battery: 1x 18650(NOT INCLUDED)
Current Regulation
Size: 98mmx 24mm (Smallest 18650 flashlight)
uuuuiiiii! this one looks indeed awesome!
98mm is extreme short, even the eagletec D25L2C, wich is the only 18650-twisty I know of, is bit longer and this one has a clicky!!!
(There is still the iTP A4 EOS, wich is a 17650-twisty that has about the same lenght as the PAlight)
Only downside could be the driver, I mean 100lm low??? I hope its a typo… If the driver really is that…“awkward” I could still imagine gettin it only for the host for that price and mod it with a lumodrv-driver from Dr. Jones.
(although it should be a bit hard to turn the head in the locked position for only 0,5 seconds, wich is what lumodrv requires to go into ramping, maybe I would have to ask him to change these times…)
It seems to have the same form/emitter as a 2100, but 20mm (approx) shorter. Warning: Incoming query may be considered stupid
Does that infer that it would become hotter at a faster rate?
I guess CNQG’s description of the UI might be accurate: “Pat the tail Cap to change modes”
Update:
Seems like it uses the same UI as the Palight Z3
There are a few negative reviews of the Z3’s UI on this CPFM thread: link
The taobao page I linked above had this description below the animated GIF (pardon the Google translation, but you get the gist):
“Z3 touch shift technology, turn on the flashlight, as shown above to provide appropriate efforts, you can easily shift gear, flashlight position set above chart, finger moderately increasing the intensity, can be much easier to get touchcontrolled shifting of fun ……. if you have DIY lock file accessories, this function also can DIY lock does not trigger”
Let’s get the size into perspective. It’s the same length as a Trustfire R5-A3 and only a couple of mm’s thicker. This is truly tiny for an 18650. And its Current Regulated.
