Sleeping Beauty - Stock looking 2AA Maglite with a 3-Up Nichia 219 set-up. - Beam Shots
11 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
31a
31b
 From the outside, it's a sleeper, till you look at the lens.
I bought a couple parallel 3-up stars from Illumination Supply. They are bare stars for the Cree XP-G and of course, the Nichia 219 fit right on. I also bought some Carlco Optics from IL. I got both the clear and the frosted.
3up2
I started with the stock head and opened it up to 20mm, with a dremel tool. I made a copper heat sink as well. It's much thicker than the normal ones I do, because the stack up on the star and optic is so thin.
Here's a video on the heat sink
3upz1
I reflowed the 3 Nichias on to the star, using my normal method, with a soldering iron under the star. It worked well.
3up4
Here's how thin the stack is. It leaves a lot of room for a heat sink.
3up5
Wired up. Remember, these are in parallel.
3up6
Everything together and ready to go.
3up7
A little insurance for heat transfer to the head.
3up8
I am testing with a dummy cell that I made and a Saft cell that was given to me by scaru.
3up9
It works!
I will do some beam shots later tonight. It's not a house on fire, but it is bright. Do they make IMR 14500 cells? It would need to be a strong 14500, to really give this any amps. No I didn't check amp draw. I might do that later.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 11/24/2012 - 21:46
flashlight man
Last seen: 6 years 5 months ago
Very nice!!
BetweenRides
BetweenRides's picture
Very nice, O-L! Yes, AW makes an IMR 14500 for high draw applications. I use mine in a C-X modified Balder SE-1.
scaru
scaru's picture
Yeah, they make IMR 14500s. In my expierence the saft ones and normal 14500s can do 2-2.5 amps while IMR might be able to handle 3-4 amps.
Almost forgot to say it but, Nice work!
dannyk
Last seen: 2 years 9 months ago
2 thumbs up! Great job!
shhh
shhh's picture
Last seen: 1 month 13 hours ago
So this one gonna be the next christmas sale??? Party
MRsDNF
MRsDNF's picture
Last seen: 20 hours 11 min ago
Nice. Are you taking pictures with both lenses? I picked up a couple of AW 14500's the other day from this link from HKJ. Not cheap though.
 http://budgetlightforum.com/node/13749#comment-258239
Old-Lumens
ISO 100, Daylight WB, F:2.7, 1 Second
b1
b2
b3
I think a lot of the problem is with the battery. I don't think the Saft battery can give enough amps to the leds. I tried a second battery and the light got brighter for a minute or two.
b4
I think IMR will be needed to run this little light.
Slim Pickens
Slim Pickens's picture
Last seen: 3 days 36 min ago
Cool how-it’s-made video, O-L. Too bad those 3xAA Mini MagLED lights aren’t being made anymore. I have a feeling 3xAA NiMH would work really well in resistored/DD parallel 3-up light.
Mattaus
Mattaus's picture
Last seen: 2 years 1 month ago
So this is obviously direct drive? Adding a driver would theoretically be as easy as using the driver itself to form the base of the pill and adding a copper tower instead of a spring? Though the you couldn't fill it with copper shot for obvious reasons...
Old-Lumens
Yes, it is direct drive. I prefer direct drive for two reasons. First, I'm old school and a flashlight should turn on and off.  Second, is yes, a driver takes up room and that does mean less of, or no heat sink and I know what that brings. (LED heat stroke). Wink
