Big discount today
115 posts / 0 new
zlmlzm
zlmlzm's picture
Last seen: 3 years 6 months ago
Big discount today
Big discount today: CRELANT CH10 Cree XM-L2 460 lumens Stepless Dimming Headlamp (1 x 18650 or 2 x CR123A) is only us$29.99.
Specifications
- CREE XM-L2 LED with 50 000 hours life span.
- Maximum output: 460 lumens (ANSI FL-1 standard)
- High efficiency constant-current circuit and output-luminance
- Durable, custom-designed microcontroller drive circuit
- Switch (High, Low, Hidden Strobe and SOS, infinitely variable brightness).
- Working voltage: 2.7V--8.5V DC
- Battery Types Supported: 1 x 18650 or 2 X CR123A (Not included)
- Runtime: High output at 2A: 460 lumens for 186 minutes.
          Low output at 0.3A: 120 lumens max for 8 hours
- Mil. Spec. Type III hard anodized aircraft grade 6063-T6 aluminum alloy
- Color: Black
- High performance aluminum OP reflector for large spot
- Waterproof: IPX-8 Standard
- Lens: Toughened & ultra-clear coated and anti-abrasion glass
- Dimensions: Length 80mm, Head Diameter 26.5mm
- Weight: 66g excluding battery
- Accessories: Headband, Spare O-ring
HeadlampHeadlamp
Aptitude+Attitude=Altitude
saypat
saypat's picture
Last seen: 4 hours 8 min ago
don’t know anything about the seller, or the light, but that is an amazing price as I looked around the net.
Racer
Racer's picture
Last seen: 2 years 3 months ago
Ordered. I don’t know the seller either but it’s low risk with PayPal.
One thing though: It gave me the Chinese PayPal page and I had to change the URL to take the “CN” out of it so it would give me the PP login page in English. I saw that Chinese PP login and almost hit cancel, but this headlamp looks really nice so I’ll take a chance. For this price I’m happy to hack the URL Smile
djozz
djozz's picture
Last seen: 28 min 57 sec ago
nice headlamp! But where is the high quality headlamp in this form factor running on one AA/14500?, I have a cheapy, but wouldn't mind a Nitecore or Crelant version.
460 lumens at 2A seems a bit poor to me, my 2A mods have higher output Undecided
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
OscarM
Last seen: 1 year 1 week ago
hmm, once again i find myself “ooh, looks like a nice deal! i could probably use one of those…”
i have no previous experience with crelant, are they good?
and i’m not sure whether i need or even “need” a throwy headlamp…
Racer
Racer's picture
I have the Nitecore HC50 headlamp which is 18650 and it’s much more compact than I thought it would be, and comfortable to wear.
koyotee
koyotee's picture
I have it too, now the only new headlamp i want is hc90 Silly
Finaly, proud owner of a Powerex Maha mh c-9000 for my Eneloops:)
Suncoaster
Suncoaster's picture
Last seen: 6 days 15 hours ago
Location: Where the girls are green and the grass is pretty.
Nice deal, considering they’re $48-$50 elsewhere.
It will be my first headlamp this decade.. Silly
Have to dream up an activity to use it with.
Bicycling, spelunking, exploring crawlspaces, working on a car….
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
TexasToasted
TexasToasted's picture
Last seen: 1 hour 52 min ago
Here's some info I found at some other site Wink I would be more interested if the emitter were accessible and if it started in low mode first.
Looks fairly promising, nice job. I like the fact it has a top band. I have a few questions.
• Can you describe the UI?
• Is the brightness ramped linear or logarithmic?
• Do you have access to the emitter, in other words does the head unscrew?
• Do you have any accessories to make the beam more floody?
• What is the lowest setting (it can’t be 120 lm with .01A)?
• What is the beam profile (20/80, 70/120)?
• Can you run unprotected batteries?
• Does it have reverse polarity protection?
• Is there a pocket clip option?
Thank you in advance for answering the questions.
Hi Knight_Light,
Many thanks for your questions, good questions!
1. Press the switch to turn the flashlight on (High mode comes on first). *** With the flashlight on, click the switch once to access the low mode, double click the switch to access Strobe mode, double click again to access SOS mode, click once to turn off. *** With the flashlight on, press and hold the switch to ramp through the infinitely variable brightness system.
2. The brightness ramped linear.
3. The head screwed and unable to get to the emitter.
4. The headlamp itself is the orange peel reflector with large spot, and currently don't have accessories to make it more floody.
5. Yes, you're right, it is 120 lm at 0.3A
6. The largest angle of the orange peel reflector is 100°.
7. Yes, it could run with unprotected batteries, but protected batteries are more recommended.
8. Yes, it has reverse polarity protection.
9. Only have the headband.
Enjoy your time, thank you again!
Crelant
Sirius9
Sirius9's picture
Last seen: 44 min 47 sec ago
good thing i have no cash, otherwise I would get one of this…
Racer
Racer's picture
The slider on that HC90 looks a little dicey. I’m curious how it stands up to real world use. This Crelant head lamp just uses the main button to get variable brightness. This only my second head lamp so I’m excited to see how it does. Someone told me not to buy the “unicorn” style head lamps but this Crelant just looks cool.
unknown00101
Last seen: 2 weeks 6 days ago
That was a huge turn off for me. The hc50 looks like a beautiful piece of functional art, but the hc90 looks.. ‘Meh’ with that peculiar slider.
If I had money to spend I would get this crelant.
saypat
saypat's picture
I also have this one, and it is a beauty in all respects! My favorite light in my meager collection.
pipifax
Last seen: 1 year 2 days ago
Is it 29.99$ shipped?
And is Crelant a budget light company or a premium brand?
jmpaul320
jmpaul320's picture
Last seen: 6 days 13 hours ago
yes its 29.99 shipped
31.99 if you want registered tracking
IMO crelant is a high end budget brand or low end premium brand… way better than anything trustfire/ultrafire, but not fenix
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
Racer
Racer's picture
It’s a superb design and implementation. Nitecore really hit it out of the ballpark with the HC50. I think I will hold off on the HC90 until somebody confirms whether the slider is any good. Seems like maybe they outsmarted themselves with that one.
Racer
Racer's picture
It sure looks like it’s worth $29.99! Anyone have experience with this seller? I hope they don’t screw me.
atbglenn
atbglenn's picture
Last seen: 2 hours 19 min ago
Looks nice, but I don't trust unknown sellers....sorry
FMcamaroZ28
FMcamaroZ28's picture
Picked one up. I really like Crelant lights, and paypal has our risk.
Racer
Racer's picture
Yeah. Let PayPal take that risk. As far as I’m concerned, every one of these sellers is shady, even the better known ones. So I look at it as risk management.
atbglenn
atbglenn's picture
You're right. I think I'll order one myself. Paypal will stand behind us if there's a problem.
jmpaul320
jmpaul320's picture
atbglenn wrote:
You’re right. I think I’ll order one myself. Paypal will stand behind us if there’s a problem.
that was my reasoning as well – i was hesitant at first – but then remembered paypal will stand behind the buyer 100%
paid the extra $2 for tracking since i ordered 2
Best wish, May
Tmart service team
atbglenn
atbglenn's picture
Something weird is happening when I try logging into paypal via lastpass on this sellers site. It's telling me my password has changed and to confirm the change which it didn't because I logged in to my paypal account separately with my lastpass login. Anyone else??? This has never happened before. That said, I didn't end up buying anything..
jmpaul320
jmpaul320's picture
atbglenn wrote:
Something weird is happening when I try logging into paypal via lastpass on this sellers site. It’s telling me my password has changed and to confirm the change which it didn’t because I logged in to my paypal account separately with my lastpass login. Anyone else??? This has never happened before. That said, I didn’t end up buying anything..
I dont use last pass – but when i logged in- it logged me in to paypal.com/cn (chinese)
I was still able to check out since all i had to do was hit the big orange button that says pay now
might be causing problems with last pass because its redirecting to the chinese site.
Best wish, May
Tmart service team
Racer
Racer's picture
All I did was hack the URL to take out the /CN right after the domain name and viola, it gave me the English version of PayPal’s site.
FMcamaroZ28
i just took out the CN/ in the address bar as racer said above
atbglenn
atbglenn's picture
jmpaul320 wrote:
I dont use last pass - but when i logged in- it logged me in to paypal.com/cn (chinese) I was still able to check out since all i had to do was hit the big orange button that says pay now might be causing problems with last pass because its redirecting to the chinese site.
I tried it again and this time it worked with no problems. It's ordered!
atbglenn
atbglenn's picture
I went against my better judgment and ordered this headlamp. Like I need another one! You guys are a really bad influence on me. lol! Smile BTW, I've spent over $400 in the last couple of months on this hobby thanks to you shitheads! I say that in a loving way of course!
southland
southland's picture
Last seen: 12 hours 54 min ago
Unable to complete transaction through paypal. Switched to English and still not working.
arn357
arn357's picture
Last seen: 6 months 2 days ago
You cracked me up Glen! LOL!
Sirius9
Sirius9's picture
atbglenn wrote:
I went against my better judgment and ordered this headlamp. Like I need another one! You guys are a really bad influence on me. lol! Smile BTW, I’ve spent over $400 in the last couple of months on this hobby thanks you shitheads! I say that in a loving way of course!
I would really change name of this forum to something like “Borg Light Forum collective”, you end up assimilated and you don’t even notice when that happens. Silly
