Hi all,
I just got my YEZL T9 XML in. To start things off, I purchased mine from Taobao so keep in mind that my sample might be different from the ones currently being offered on the forum. The light is pretty large compared to everything else I have, and the anodizing is not as good as the custom T8X I purchased on Taobao before this one, coming out of the package with a few chips at the edges. Also, the light is very dirty on the metal ring around the emitter. Despite all this, the light construction is quite solid and seems like it will hold up quite well to use.
Moving on to the actual lighting, it's very bright out right now so I haven't yet had a chance to see how it will perform in darkness. Compared to my modified T8X, however, it has a significantly larger beam when completely retracted but this beam is ever so slightly dimmer. My T8X runs at 2.1A, and after a quick measurement it turns out this T9 driver is pulling only 2A on high. And that brings me to my biggest concern about this light, the driver just doesn't seem to be driving the XML as high as would be ideal for this light. However, the spacing between H-M-L is quite good, 2A on high, 0.6A on med, and 0.1A on low. Again, keep in mind that my driver is probably different from the one that's available on the forum. I'm not sure if the driver is replaceable though, it's plugged in pretty tight to the large metal ring pseudo reflector piece.. Any ideas on how to get it out?
Another thing I've noticed is that you absolutely must keep the sliding portion lubed up, mine came oiled quite nicely but when handling the light in the extended mode it is near impossible to not wipe off some of the lube, and once a large portion of the lube is removed it becomes rather difficult to extend or retract the head.
The optic is 39mm across.
I've taken a few pictures for you guys, I'm not a very good photographer so my sincerest apologies for that, but I hope you guys enjoy them anyways.
T9, Modified T8x, Ultrafire C3, Sipik SK-68, Generic Sipik CR123 Clone, Ultrafire C30 (aka Skyray S1)
This is my first attempt at reviewing anything and I'm sure I left a bunch of stuff out so if there's anything else you guys want to know I'll do my best to answer!
