ZY-T08 3up mod with XM-L2 - just another approach - It's finally done, beam shots are up!
31 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
June 8th. 2014
I still have a couple ZY T08 lights so I thought I would do another 3up using XM-L2 leds on Noctigons. Here you can see that light is dismantled and I have three aluminum reflectors with locating rings and three Noctigons. You can also see a chunk of aluminum rod stock and some copper.
zy3a
zy3b
I want to have the aluminum rod stock as part of the heat sink and I want it to fit tight, so I milled out a little of the head, so the aluminum would be press fit into it. I used an end mill bit in my drill press to do it.
zy3c
Here is the center heat sink pressed into the head
zy3d
zy3e
I used a hacksaw and files to remove the rim of the stock aluminum insert that held the led and driver. I want it to screw in tight and flush against the aluminum heat sink that I just pressed into the head.
zy3f
Since these lights have a tapered head, I want to fill around the aluminum center and I thought I would use some copper shot and some solder, to make it more permanent than the JB weld was, from the last build.
zy3g
Once that is filled, I will put a copper discs over the top.
zy3h
I used a screen to sort out the fine pieces of shot from the bigger ones.  All this copper shot is really just cut up wire, bought from am ebay seller.
zy3i
I put in a little of the big stuff in the bottom and then I put some solder in on top. This time I elected to use a large socket and wrap some solder around it and then just dropped the wrap in. I think it was better than feeding the solder in after heating.
zy3j
zy3k
My lovely assistant took a photo of this, since I was using two torches at once. I just heated the outside of the head and the center aluminum heat sink, till the solder melted and let it flow down into and over the copper shot.
zy3l
Then I did another shallow layer of big stuff and repeated the process. Finally, I used the smaller shot for the top layer, hoping it would make a smoother surface for the placement of the copper discs on top.
zy3m
zy3n
All ready to go and after placing the copper discs, I heated again and pressed them in while it cooled.
zy3o
zy3p
Looks like it worked well. I didn't have any leakage from below, so the press fit must have been a good seal and the solder did not run out the bottom, as it normally does.
That's it for now. I have to flow the leds on the Noctigons and then I will need to wait for drivers to come in. I expect to go for 4 amps per led.
 06/11/2014
I decided to order some boards from Oshpark, so I could use them as slaves. The ones that mattaus made up at my request, so I will be waiting most of the month for that to happen. Looks like it will take a lot longer than I thought.
I did manage to get the leds reflowed and they are in place, with the reflectors and glass in, so all I really have left is the drivers and the tail cap springs.
t081aa
t081ab
The leds are XM-L2 T6 3B, reflowed onto Noctigons and the wires are 22ga Teflon coated. Only reason for them is the Teflon coating is much thinner than silicone coating and I didn't want any bigger hole for the wires.
That's it till the boards come n...
 06-21-14 Loooong time waiting for those Oshpark boards, but they came in today. Let's get this thing wrapped up.
3z1a
These boards are ones that Mattaus designed. I wanted boards that just held the 7135 chips, so I could use one for each led and not use up perfectly good Qlite drivers. These are the 16mm boards and they each hold 12 chips, so 12x380mA per led.
3z1b
Soldering these with a regular soldering gun is difficult, but not impossible. 36 chips, 3 boards.
3z1c
PWM from the master driver. I took off the chips and used them on one of the other boards.
3z1e
LED- wires soldered on.
3z1f
PWM and Ground wire soldered on.
3z1g
Can't show you the rest, because I didn't want to stop. I just used the original driver as a contact plate and used 18ga wires for + & -
3z1h
Last thing is adding copper braid to the springs.
3z1j
With 2 of the 20R batteries, I got a reading of a total of 11.65 amps, so that's not all that bad. It will be a very bright T08.
3z1k
Beam shots in Post #1...
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 06/21/2014 - 23:39
Old-Lumens
3zb1
3zb2
3zb3
3zb7
A little fuzzy on that one. By the time it gets to the end of the pond, it's total flood and there isn't a bright spot any more. It's not a thrower, but I wasn't trying for that anyhow.
3zb4
LOW
3zb5
MEDIUM
3zb6
HIGH
That's all folks. It will be up for sale soon...
texas shooter
Last seen: 16 hours 6 min ago
That Copper shot idea is brilliant, more heat capacity less weight. Looks like a good mod step for thin Aluminum heat sinks on those multiple LED supper lights.
Cereal_killer
Cereal_killer's picture
Last seen: 3 months 2 days ago
Did the heat it took to add all the shot not discolor the ano?
Looks like another awesome project.
ohaya
Last seen: 1 year 11 months ago
O-L,
That is amazing work!!
Old-Lumens
Cereal_killer wrote:
Did the heat it took to add all the shot not discolor the ano? Looks like another awesome project.
No. It takes a higher temperature than the melting point of 60/40 solder, to discolor anodizing.
DBSAR
DBSAR's picture
Last seen: 1 day 16 hours ago
great idea with the copper shavings as a filler to help absorb heat. Smile
DayLighter
DayLighter's picture
Last seen: 2 years 10 months ago
Cool trick.. have to try this someday Love Beer Beer
The only way to do a great work is to love what you do.
Hi-Beam
Hi-Beam's picture
Last seen: 4 years 5 months ago
I noticed your using 60/40 solder, I have been using 63/37. I’m sure you have a good reason for using 60/40 and I’m curious to know what it is.
Old-Lumens
I noticed your using 60/40 solder, I have been using 63/37. I'm sure you have a good reason for using 60/40 and I'm curious to know what it is.
No good reason other than that's what I have always used. It started with soldering water pipes way back when and I just stuck with it, rosin core 60/40.
dentillozie
dentillozie's picture
Last seen: 8 months 1 week ago
wow that light is going to be even more front heavy! nice mod. cant wait to see the end result.
licensed HAM radio opparator
Callsign: ON3DTZ
EU based flashlight modder. If you need any modding work done, make sure to PM me!
some of my mods:
- convoy meLd 4
XHP50 Maglite Mod
UF-1405 Mod
TK35 (clone) to TK35UE
southland
southland's picture
Last seen: 2 weeks 2 days ago
Can you head east a few hundred miles, I need some help on my contest light.
MRsDNF
MRsDNF's picture
Last seen: 20 hours 59 min ago
He's booked out next week as an Australian beckons with help on his. Wink
deckart
deckart's picture
Last seen: 5 years 4 months ago
subscribed
OL you are incredible.
ImA4Wheelr
Last seen: 1 week 5 days ago
Great idea to fill in that void.  Gonna have some nice heft to it.
scottyhazzard
scottyhazzard's picture
Last seen: 10 months 19 hours ago
Ooh, boy! This is going to be good.
"Those who hammer their guns into plows will plow for those who do not."
Old-Lumens
Do you have flight information? I'm Ready!!     First class right??Tongue Out
Old-Lumens
A couple more photos in the OP
Mohl
Eagerly awaiting for more….. This is awesome!
MRsDNF
MRsDNF's picture
What reflectors are you using?
Old-Lumens
The reflectors were out of a solarstorm raging, but similar ones can be gotten from kaidomain.
gamezawy
gamezawy's picture
Last seen: 1 month 1 day ago
man every time i see your modding i learn many things, thank you for your effort to document your projects
Old-Lumens
Posted several new photos in the OP. The light is finished, beam shots later tonight.
Old-Lumens
Beam shots are in Post #1
RaceR86
RaceR86's picture
Last seen: 4 years 1 month ago
This is a really sweet mod!
Thanks for sharing OL.
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
wight
Pretty sweet looking result!
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
DayLighter
Slewflash
Slewflash's picture
Last seen: 1 year 8 months ago
Incredible work…
Slewflash
nofearek9
nofearek9's picture
Last seen: 2 weeks 10 hours ago
nice work,looks beast!
leaftye
Last seen: 3 weeks 3 hours ago
I've been thinking about trying that to improve heat transfer, and am glad to see you do well with it.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
M4D M4X
M4D M4X's picture
Last seen: 4 hours 49 min ago
great mod!
thanks for some ideas Wink
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
