I thought I'd share this, being the classic (black aluminum) ThruNite T10 AA light has been quite popular, and owners know this light can really output on a good 14500 cell. It's an XPG with an OP reflector, a driver that supports a few AA cell types, and is known for a really low moonlight.
I just got in the new XP-L CREE emitters from Calvin at IS (http://www.illumn.com/), and thought it would be perfect for the T10 - direct replacement because the XP-L fits on the same star as a XPG or XP-G2. The dye size is bigger, so I'd expect more flood, but more total output (lumens) and the ones I got in are a 2C tint, which should be a definite improvement, because the stock is a typical cool white, about a 1A level I'd guess. This is the XP-L V6 2C I ordered. After opening the light up, the star was quite small, and sized it up to a 10 mm SinkPAD, and seemed to be a perfect match, so decided to proceed with using the SinkPAD, since it should be worth it having a copper star in there with a direct thermal path.
Here's the light:
Looking with some other AA's:
As you can see, it's quite small for an AA compared to others - not the smallest out there.
Here's the XP-L reflowed onto the SinkPAD. The only mod to the SinkPAD was to sand down the back side to get the thickness reduced from 1.55 mm to 1.25 mm. The stock star is about 1 mm thick, but of course the thicker I could keep the SinkPAD the better, but had to reduce ot to get the LED alignment piece to fit right. Here it is:
Another mod that had to be done was to file down the posts of the alignment piece to get them to match up to the SinkPAD:
As you can see above, the black posts on the left and right were originally circular to fit the 2 large holes in the stock star, but I filed them to fit the notch's on the SinkPAD. Here's all the parts:
The wires on the driver are very thin - thinnest I think I've seen. I decided to leave them as-is for now. I wasn't sure what the effect may be to the driver It already runs LI-on cells at pretty high amps, so didn't want to push it any further. Here's some close-ups of the driver:
Here's the emitter after fully assembled:
It's not perfectly centered, but I can't really notice it in the beam pattern.
On a freshly charge Sanyo 14500 cell, this is what I got on the stock light:
High: | Lumens: 367 @start, 343 @30 secs |
Med: | Lumens: steady at 129 |
Low: | Lumens: maybe 0.1? It's low... |
This is what I got after the mod:
High: | Lumens: 527 @start, 513 @30 secs |
Med: | Lumens: steady at 184 |
Low: | Lumens: maybe 0.13? It's still low... |
I measured throw after the mod (not before unfortunately), but it does 2.8 kcd, 105 meters. I'm sure the throw has dropped - thinking it was about 5 kcd, not sure - may have measured that before. I knew it threw well for a small OP light, now it's a pretty big hotspot as expected.
This is a real nice bump for just swapping out the LED and star, and it pretty much came out as best as I could hope for. Over 500 lumens in a light this small without using any more amps than it did stock is great. The 30 sec drop is lower after the mod, so I think the SinkPAD is doing it's thing keeping the LED cooler. The pill is very thin and with the large driver there's no spare room to add any additional mass.
