Missed the Yezl Y3 GB? No worries! Check this out! :) (you can buy separate extension tubes too)
154 posts / 0 new
Cereal_killer
Cereal_killer's picture
Last seen: 2 weeks 12 hours ago
Tom, dont remember if it was this thread or the original GB thread but you posted that you thought you could get around the same 250kcd as I got from an XP-G2 with an XM-L2, just wanted to say thanks for motivating me to take mine back apart and put the XM back in (a U2 1D dedomed), I just did 5 readings in a row (cause I simply couldnt believe the results) and its now doing an average reading of 268k at 1m (measured at 5m) and the max reading was 273kcd!
I’m gonna be going to my buddies poll barn in the next few weeks where I can measure at 15m in total darkness to see if it focuses any more at distance.
This is currently the farthest throwing light I’ve personally owned (tho I’ve built a few Courui’s and resistor modded an SR91 and a TK75 for customers) and its gotten me addicted to throw (use to be a flood guy).
I also went ahead and ordered several more Y3’s for lights to build for stock, I have a red PT121 I’ll stick in one for a hunting spotlight (legal in specific areas here on ‘yot’s)
Tom E
Tom E's picture
Last seen: 1 hour 23 min ago
Cool! All good. a 1A may do a little better, even. Dunno - I got my first GearBest Y3 and it's disappointing, stock. It's not as focused as the other Y3's and does lower in lumens and a little lower in throw. I think the reflector doesn't sit as low. Been checking all sorts of dimensions and that reflector dimension is the only thing I see. The lens is a bit foggy and I can't get it clear, but subbed it out with a spare Y3 lens and no difference. This one has some differences:
  • a flat matte finish where the older ones are more glossy
  • a thick green GITD o-ring in front of the reflector where the old ones had a thinner black one. Maybe they were trying to make up the gap
  • a green GITD tail switch boot instead of black
It's almost a full 100 lumens lower OTF (~730 instead of ~830), but amps is still about the same - 2.5A or so. Might simply be the LED or combo of things - maybe they used a U2 bin before, maybe the thicker o-ring is hurting output. The tint seems to match - cool white, like a 1A.
Cereal_killer
Hm, you just described my group buy Y3 exactly. Strange.
Manx
Hi guys, is the first time that a buy from Gearbest. Normally how long it takes to receive the goods? 30/40 days as usual?
www.youtube.com/channel/UCeDhMPm0L1yvr3LpygDPgMw my flashlights/knives/gear video reviews
www.absoluteblack.net my dark comics
Tom E
Tom E's picture
My Y3 was ordered Sep 3, arrived Sep 22 - 19 days. Haven't had a China package arrive in over 30 days in a long time... Been as short as 10 days, more typical is 17-20. Is your glass 1/2 full or 1/2 emtpy, or is your light bright or dim? Smile
Cereal_killer
Read threw the SingFire S1 clone thread for more info. Personally the 2 gearbest orders I’ve placed have both arrived in ~20 days but other people have had much different experiences.
Manx
Quote:
My Y3 was ordered Sep 3, arrived Sep 22 – 19 days. Haven’t had a China package arrive in over 30 days in a long time… Been as short as 10 days, more typical is 17-20. Is your glass 1/2 full or 1/2 emtpy, or is your light bright or dim?
Thank you.
10 days will be a super super fast deal. Last order from China take 46 days to arrive in Italy (with custom). 17-20 day still ok.
To know if my glass is 1/2 empty/full must wait Wink
20 days ares till a good amount of time. It’s not bad. Ok, let’s wait!! Thank you too :bigsmile:
Manx
Anybody know if is possible to change the side switch?
I really don’t like it white/plastic; grey/metal will be perfect.
And, if it’s possible, is an hard work/mod to do for a noob like me? Thank you Smile
Manx
From Nederland Post tracking: the flashlight in on his way, country of destination: Italy Big Smile
The 5 extension tubes, country of destination: Spain :~
dangerous
dangerous's picture
Last seen: 4 years 3 months ago
Are the Y3s from GB showing up with minor scratches like the ones from CQG?
BLF
Tom E
Tom E's picture
Mine was not perfect from GB (not too bad though) - I'm thinking there may be the same issues, dunno til we hear more feedback.
MRsDNF
MRsDNF's picture
Last seen: 1 day 6 hours ago
I'm not in a position where I can check my Y3's for battery length but can speak from experience that it is impossible to build a light that covers all battery scenarios in multi cell lights. Even single cell lights can be difficult with a single spring on one end of the battery. 18650 batteries start at 65mm in length and can go over 71mm in length. That's 6mm for a single cell that the light must cover, 12mm for two cells etc. As a rule flashlight manufacturers use the shorter length to make their lights which is fine if you use short batteries but not many of us do especially where we use protected cells in multi cell lights. As some have found out this light looks like it will accommodate the shorter batteries only. HKJs web site is probably a good place to start as it has measurements for most of the popular batteries.
http://www.lygte-info.dk/info/indexBatteriesAndChargers%20UK.html
Tom E
Tom E's picture
Again -- single cell, I use KK 26700's -- longer than any 26650 protected cell around. Even the MOLI 26700 I've fit in a Y3 and used. Once you plug in an extender, different story... It's the extenders, not the single cell light.
willie
willie's picture
Last seen: 1 week 4 days ago
Tom E wrote:
Again — single cell, I use KK 26700’s — longer than any 26650 protected cell around. Even the MOLI 26700 I’ve fit in a Y3 and used. Once you plug in an extender, different story… It’s the extenders, not the single cell light.
Agree
Ordered 3 extensions. Want to use three KK26700 in the Y3. Will modify/machine the last extension to allow for extra length. If the last extension ever shows up in the mail. It’s been almost 6 weeks since I ordered.
Tom E
Tom E's picture
willie wrote:
Agree Ordered 3 extensions. Want to use three KK26700 in the Y3. Will modify/machine the last extension to allow for extra length. If the last extension ever shows up in the mail. It's been almost 6 weeks since I ordered.
6 weeks is bad - close or at the PP cutoff. I'd open up a dispute within 2 days of the limit.
Manx
Quote:
6 weeks is bad – close or at the PP cutoff. I’d open up a dispute within 2 days of the limit.
For me, 6 weeks to arrive in Italy is normal, unfortunately :~
Manx
Arrived!! It took 25 days, not so bad Smile
The extension tubes where inside the same pack of the flashlight…So the second tracking only for they was not my.
I put 1xC Alkalines battery, but it is too short. Put 4xC Alkalines (2 not fresh, 2 new) the flashlight blink, unusable. Put 3×18650 and it run very well! I’m waiting 1×26650, can’t wait Wink
But, I’m asking if it does not run with 4C Alkalines, with the others 3 extension, so others 3/4 battery, it will run or it will blinkies?
freeme
freeme's picture
Last seen: 4 hours 41 min ago
My extension tube arrived... before Yezl Y3. Damn.
wight
Last seen: 6 months 3 weeks ago
First try 4x fresh.
Break’s over for now. That was a long one! wight catchup WinkWinkWink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
antiparanoico
Last seen: 6 months 7 hours ago
First try 4x fresh.
+1
Mine from GB CNQG, with 2 extension, works fine with 4xC fresh alkalines (Duracell). I guess if you add more batteries work best, not exceeding 8xC (total).
If anything can go wrong, it will.
Matter will be damaged in direct proportion to its value.
willie
willie's picture
I get the blinkies with fresh 4 NiMH C (4.8 volts). It’s the low voltage 2 battery lithium warning signal. Guess I’ll have to get a total of 5 extensions and run 8 NiMH batteries or use a dummy of some type.
Gj
Gj's picture
Last seen: 3 days 5 hours ago
willie wrote:
I get the blinkies with fresh 4 NiMH C (4.8 volts). It's the low voltage 2 battery lithium warning signal. Guess I'll have to get a total of 5 extensions and run 8 NiMH batteries or use a dummy of some type.
willie
willie's picture
Better than niteCORN.
Cereal_killer
First try 4x fresh.
+1
So to confirm, you’re running 2 extensions and fit 4 c cells?
fellfromtree
fellfromtree's picture
Last seen: 4 years 6 months ago
Yeah 4 C cells work, but you need to add in a spacer.
antiparanoico
Yes.
antiparanoico
It is not necessary.
There are about 8 mm to the edge, but spring compensates.
willie
willie's picture
!http://i.imgur.com/i5nyArgl.jpg!
I concur, button top Tenergy NiMH required no spacer but with 4.8v did have blinkies due to low voltage 2 cell lithium warning.
fellfromtree
Rattles though.. It’s better to stick in a spacer Smile
antiparanoico
Yes. But… Although we add a spacer, it will continue the rattling. We need to add spacers in diameter…
