Amazon Deal Alerts & Discussion Thread
2755 posts / 0 new
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 1 hour 25 min ago
These are for sale with Vipon code: https://www.amazon.com/LED-Flashlight-Waterproof-Rechargeable-Flashlights/dp/B07PQ1QP6J
For $6.90, it's not bad for a host.  I put a 20mm 7135*8 from MTN with guppydrv just to see how it handles heat and an SST 20 5000K. I think it can handle more than 3A as it heats up quickly.  Here's the pill:
The driver is held in place by tightening decent wall thickness body tube against the head.
BLF A6 clip fits perfectly, although the stock clip is good.
800-900 lumens with this setup. I used a black Sharpie on the MCPCB retaining ring.
Negatives are that the battery is trash and USB charging is pathetic.
I'd like to find a tail without the USB port.
EDC
FW3A, SST20 4000K || S21A, Crescendo MTNdd 20mm, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, LH351D 4000K | L2 w/6A 20mm SST40 driver, XP-L HI | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | SK Zoomie Nichia 5000k, C2 driver | EagleTac clip | Ultrafire C2 w/5A 17mm & XM-L2 | Nichia 219C 2700K with gray S6 |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3)
Pete7874
Pete7874's picture
Last seen: 2 hours 55 min ago
sbslider wrote:
Hmm, code didn’t work for me just now.
Try code 3678BX1X for the TENAVOLTS.
https://slickdeals.net/f/13371103-4-count-tenavolts-rechargeable-aa-lith...
Klotski
Klotski's picture
Last seen: 9 hours 36 min ago
I just tried the amazon link using this code 3678BX1X plus checking the 30% off box and got a set for $11.89
sbslider
sbslider's picture
Last seen: 6 days 13 hours ago
Not sure why it would not work while I was using my work computer. I tried last night on my notebook at home and it appeared to work, but I didn’t pull the trigger yet. Now for $1 less, it’s time.
Thanks!
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
Lightbringer
Lightbringer's picture
Last seen: 8 hours 32 min ago
Done… again. LOL
Almost 13 with tax Sick but still a good deal. I’ll find things that use AAs to stick these into. B’harni knows I go through enough of ‘em.
fluke
Last seen: 2 hours 12 min ago
Sux being in the UK.
bushmaster
bushmaster's picture
Last seen: 1 hour 4 min ago
I took the plunge again myself. Seems my game camera uses 8 batteries so…….ya know, I had no choice…….or something.
Keep your nose in the wind and your eyes along the skyline.
Del Gue
Lightbringer
Be very careful sticking ‘em in series, though. They’ll hold up 1.5V and then drop dead. Regular alkies would just start getting reverse-charged and leak, but pushing current the “wrong” way through one of these might be Very Bad for the critter.
Pete7874
Pete7874's picture
They require 5V to be charged, so I doubt pushing 1.5V into them will do much, but I’m not gonna be the first one to try. Smile
Lightbringer
NNNOOONnnoononono, nono. Reverse-charged.
Normally, current goes out, charging it is pushing the current back in.
Reverse-charging is when one gives up the ghost, and the other cells happily keep pushing current the wrong way through it.
Output cap, blocking diode, anything on the output of the buck regulator might end up frying unless the mfr took steps to keep that from happening.
Like you said, I’m not gonna be the one to try it. Let’s get Mikey…
Rexlion
Last seen: 20 hours 7 min ago
The Tenavolts kit came today (Prime delivery van, how slick is that?). One of the 4 cells tested 0 volts out of the box. Angry The others tested 1.54-1.55V. I thought, this one cell is probably toast, and if so I’m sending the whole thing back. But after charging fully (blue light turns off when done) I set the cell up in an old ITP C7 on high, and it’s been putting out good light for nearly an hour now, so I guess it’s going to be ok.
What’s interesting, though, is the way these cells act in a light that has step-down regulation. I put one in a Zebralight SC5W and it only put out about 200 or so lumens instead of the possible 500… and within 30 seconds it had stepped down to maybe 5-10 lumens. The flashlight didn’t know what to make of it. Not enough current, I guess.
contactcr
Last seen: 2 hours 31 min ago
Rex, from what I understand they hold 1.5V then go to 0 when the Lion is low. There is no gradual decline like a alkaline. It could mean there is some self discharge but who knows.
Pete7874
Pete7874's picture
There is a protection circuit inside. If it trips, it cuts off voltage. Putting it back on the charger resets it, I believe.
These cells were not designed to deliver lots of current – going above 1.5A will cause the internal buck converter to overheat and shut down.
decypher
https://www.vipon.com/product/4492232-Moobibear-COB-LED-Work-Modes-Portable-amazon-coupons
This coupon seems to work for both models of this “work light”. The rechargeable USB one I was able to get out the door for 6.XX tax included. The AA version is even cheaper. I’ve found these type of work lights are pretty helpful when puttering around in the basement or when the lights go out.
Passing along in case someone else finds it helpful.
weklund
weklund's picture
Last seen: 5 hours 50 min ago
Nice … I paid $5.88 delivered to my front door with Prime. Looks like a great deal.
Review:
https://youtu.be/1vAdnLGokdY
Many Thanks for the heads up.
... Happy Landings ...
Pete7874
Pete7874's picture
Nice. I ordered both for $11 total. Thanks for sharing.
Pete7874
Pete7874's picture
I hear ya. Product description states: “Integrated 3-in-1 safety chip: Extra charge, discharge and short circuit protection, no over-charge, damage to lithium core or extreme temperature,” but how that works in practice is anyone’s guess.
Pete7874
Pete7874's picture
What do you guys think is the source of power in this rechargeable one? Two 18650 cells? Three 18650 cells? Something else?
decypher
If the ad is to be believed, its 6000mah. Its likely a pouch pack. if we are lucky its 2×18650. Given the thickness, I’m inclined to think its a pouch.
moderator007
moderator007's picture
Last seen: 11 hours 49 min ago
Anyone got a code their willing to share for this COB work light?
You can PM me if you prefer. I could really use one of these, thanks.
fluke
Thanks.
I got the rechargeable version shipped to the UK delivery and taxes and import duty for $11 equivalent.
BillyBobJoe
Last seen: 1 day 11 hours ago
Its showing like $11 for me.
moderator007
You have to use the vipon code at amazon and put it in the promotional code box at checkout to get the discount.
Unfortunately the code want be available again for about 13 hours.
flightless22
flightless22's picture
Last seen: 1 day 14 hours ago
For $6.90, it’s not bad for a host.  I put a 20mm 7135*8 from MTN with guppydrv just to see how it handles heat and an SST 20 5000K. I think it can handle more than 3A as it heats up quickly.  Here’s the pill:
Thanks for the tear down and shot of the pill. the shelf looks like it wasn’t a solid piece but tacked on afterwards.
weklund
weklund's picture
Snagged one. Many Thanks … Wink
Vipon coupon code: 9DLB-6PT7EF-RRX6AE
decypher
I stand corrected. The light has a 3×18650 wrapped pack in it. It is indeed 6000mah 3.7v.
Pete7874
Pete7874's picture
You opened yours up? Smile
I’m going to run a discharge capacity test when I get mine.
Lightbringer
Wait… what?
The vipon code for the moobibear(!) is 11.27, but it’s listed on amazon at 10.99, straight-up.
What’m I missing, and how youse get ‘em for 5-6bux?
Lightbringer
Charmast uberpowerbank:
https://www.amazon.com/dp/B07SW6M1PX
vipon code brings it down to 20, 5% coupon knocks it down a bit more. Got mine for <20bux out the door.
Ah, here we are…
https://www.vipon.com/product/6635984-Portable-Charger-Power-Charmast-Hi...
Go crazy…
Pete7874
Pete7874's picture
Lightbringer wrote:
Wait… what?
Ignore the displayed pricing and apply Vipon code anyway. Smile
