OLIGHT S30 Baton(1x18650,XM-L2)Magnetic tailcap-REVIEW
26 posts / 0 new
FlashLion
FlashLion's picture
Last seen: 2 years 4 months ago
Hello
The S30 Baton is a new compact 18650 flashlight in the Olight's Baton series flashlights.
A rechargeable version of this light(S30R) was released earlier. Both versions share the same design and UI.
1000 Lm max output(on Turbo mode,which lasts about 2 minutes).A flat side switch(not protruded and easy for accidental activation as the first baton flashlights with the blue switch).Cool white Cree XM-L2 LED.Powered by one 18650 or two CR123A batteries.
Aluminum alloy body.Black matte hard anodizing.
First impression-the S30 is a really compact flashlight powered by 18650 battery.
Thanks to the use of just one side switch the flashlight is much shorter than other compact 18650 lights as the Fenix PD35 and ThruNite TN12(2014).
It's even slightly shorter than the Neutron 2C due to the shallower reflector.
Olight S30 stays well in hand. There is enough knurling/relief for a good grip.
The S30 produces a lot of heat while working on max output. 3 cooling fins help with dissipating the heat that comes from the LED.
Olight has redеsigned the blue side switch and now all new Baton models come with a new flat switch with a cap of a transparent plastic that allows mounting a red indicator light underneath.
The switch has thick metal periphery around it,which gives the advantage of hard accidental pressing,but also makes the switch hard to find by touch in the dark.
I found the switch quite convenient and not much harder to find compared to other side switches.This is a personal opinion of course and depends on different factors.
Here is a comparison with the Olight S10L2.
More close-up pictures of the switch.
The red indicator LED light warns for fully discharged battery and also when the switch is electronically locked(blinks after pressing the locked switch).
The S30 is equipped with a deep pocket clip-well attached,not easy to remove accidentally.
Not too stiff,not too loose,the clip is really made for use,not just for the look.
Specifications from the user manual.
(Read my measurements later in the review.)
The User interface is the same great UI used in the other baton flashlights.
Total 5 constant light modes + Strobe mode.
Main modes Low-Mid-High
Additional Turbo and Moonlight modes.
Briefly press for ON/OFF.
Press and hold to cycle through Low-Mid-High.
Double press to activate Turbo from Off or ON.
Press and hold for a second to activate Moonlight mode(from Off).
Triple click for Strobe.
There is a memory for the last used mode-including Low,Mid,High,as well as the Turbo and Moonlight mode.
No memory for Strobe mode.
The mode memory works flawlessly instantly,as usual for all Olight flashlights.No guessing on which mode the light will start.
There is also a switch locking function to prevent accidental activation.
Press and hold the switch(from Off state) for more than a second.The light will start on Moonlight and then will turn off.
The switch is locked.
To unlock it-press and hold again for a second.The light will start on moonlight mode.
Using only an electronic side switch,the S30 is actually in Standby mode while turned Off,consuming ~15uA current.
This is a small current,but if you don't want to lose this energy,the tail-cap allows lock-out.
Standard Olight packaging.
Spare O-rings and rubber pad to replace the tailcap magnet if you decide to remove it.
A blue sealing 0-ring with glow in the dark particles.
Ultra clear glass lens.
Smooth aluminum reflector,Cree XM-L2 LED
The tail is clean,almost flat allowing stable tail-standing.
There is no hole or loop for lanyard attaching anywhere on the flashlight (at least on my sample).
A strong magnet is mounted in the cap,providing strong enough force to keep the S30 attached horizontally or vertically to metal objects,but not as stably in horizontal position as it could be with a short flashlight as the Olight S10. The S30 is long ~12cm and this length requires way too big and strong magnet to keep it stable horizontally-the center of the weight is far from the mounting point... But I found the magnet feature quite useful,especially there are just a few 18650 size flashlights with a magnet tailcap to choose from.
The magnet can be removed with pliers and replaced with a rubber pad included in the accessories.
Overall,the Olight S30 impressed me with its compactness and practicality,but minor flaws are not missing.
As you can see from the picture below,due to the long,deep pocket clip,part of it sits too close to the tailcap and scratches will be hard to avoid after some time of use.
This part is probably designed to ensure more stability and hard accidental detachment of the clip,but at the expense of the tailcap finish.
Here you can see the size of the magnet and how it is mounted.
The machining of all parts is on top level,as the threads are really impressive.
Long thread,square cut,anodized. I really didn't expected so stable threads in a EDC flashlight.
The O-ring and the threads are well greased.
With a protected 18650 battery inserted.
There is a spring at the + end.
This is a runtime graph,illustrating the output on High and Turbo mode in the time(in minutes).
A 3400mAh battery is enough for about 2 hours on High mode.
My lumen measurements:
Turbo ~985 Lm       I=2.65A
High ~580 Lm        I=1.28A
Mid ~153 Lm          I=270mA
Low ~22 Lm           I=42mA
Moonlight ~1.1 Lm  I=5mA
The lumen numbers were measured 30sec after activation.
The current draw numbers are initial,measured immediately after activation.
The I turbo current depends highly on the battery voltage.The lower the voltage,the lower the current,the lower the brightness.
Here are the first 20 minutes from the same graph,for a better view.
As expected from a compact flashlight without enough mass to handle all the heat from the LED,the S30 steps down to about 55% of the initial output(equal to the High mode)after 2 minutes on (1000 lumen) Turbo mode,as the step is slow and gradual and takes 1 minute.
The two minutes Turbo output does not effect much the overall run time.
The light from the Cree XM-L2 LED is cool white without visible greenish or bluish tint.
The beam is good combination of hotspot and spill with a clearly defined hotspot(due to the smooth reflector).
Maybe a little more "thrower" looking than expected.
As I already mentioned in previous reviews,an orange peel reflector is a much better choice for an EDC light because of the well mixed light,more convenient for everyday use.
The fact is that almost all new flashlights come with a smooth reflector which gives a little bit better throw and probably output,but the beam is not quite well mixed.I can see a darker zone in the beam's center,not so noticeable,but it's there.
Beamshots
White wall
Olight S30 Moonlight-Low-Mid-High-Turbo
1 meter 1/20sec
1 meter
1/50sec
Here is a comparison between the lowest modes of Neutron 2C and Olight S30.
5 meters
1/6sec
5 meters
1/50sec
The front of the S30 and Neutron 2C(review here)
Very similar design.Slightly deeper reflector on the 2C.
The Olight S30 baton is another great choice for a compact 18650 flashlight.
I like the high build quality and the whole design.I like the deep pocket clip without a hole for lanyard attaching.
It is a flashlight really easy to carry and hold.
Great user interface.Good amount of modes-well spaced. Quick access to Moonlight and Turbo mode is a big plus.
A status indicating light under the switch is always a useful feature and it's great to see it in the Baton series flashlights.
Concerning the side switch operation-it is depending on different factors,one is the hand size.It is definitely not the easiest to find in the dark,but the pocket clip comes really useful here.Just remember the position of the clip and this will help you a lot to know where is the clip.This method works just great,at least for me.
A thing that I would like to change is the finish of the reflector. An orange peel reflector is always a better choice for small reflectors in EDC flashlights.
I would like a little bit better beam profile with a better mix between hotspot and spill and no dark zones in the center.
Thanks for reading!
Hope the review is helpful for you.
The Baton S30 flashlight was provided by Olight for test and review.
Edited by: FlashLion on 03/15/2015 - 14:55
Ormbett
Ormbett's picture
Last seen: 5 hours 46 min ago
Nice light, thanks for the review!
Woody
Woody's picture
Last seen: 9 hours 18 min ago
Nice review. That beam looks a little green to me – what’s the tint like in real life?
my9221
Last seen: 3 hours 55 min ago
Nice review & Pics!
DanielM
DanielM's picture
Last seen: 6 days 15 hours ago
Great review
Dat green tint tho :Sp
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
FlashLion
FlashLion's picture
Thanks for the comments!
The beam is not the same tint in the hotspot,corona and spill as there is something like a yellowish corona around the hotspot,but it’s not noticeable in normal use.
I forgot to take pictures of the Olight S10L2 ,so I made a quick comparison a moment ago.
The S30 is quite white with very good color rendering. To compare it,I illuminated different objects,including white paper.
The cool white ThruNite TN12 looks a little yellowish compared to the S30 Baton.
Quite good white light.I just wish they had used an orange peel reflector in this model,to reduce the amount of artifacts.
FlashLion
FlashLion's picture
DanielM wrote:
Great review
Thanks Daniel
The tint is not green.
My pictures really look a little greenish(especially these at 1 meter,on the lower modes),but this is mostly because of the short exposure time they were taken.
The yellowish corona that almost any XM-L2 + smooth reflector flashlight have is represented as green by the camera,because of the exposure time.
sesgum
sesgum's picture
Last seen: 2 days 4 hours ago
Nice light, great review! Thank you!
Is the GITD ring glow in blue or still green?
Beachlogger
Last seen: 1 week 1 day ago
Great photos as always, thanks for the review
blueb8llz
Last seen: 3 hours 30 min ago
wow thanks for this review. i think i will go purchase me one now. hope its not too expensive
Trevi_lux
Trevi_lux's picture
Last seen: 5 months 2 days ago
Thanks FlashLion for the review , great Work. I love the Olight Interfaces.
g_sintornillos
g_sintornillos's picture
Last seen: 1 hour 58 min ago
Great review. Thanks.
At BG, GB and HKE: $59,95
Group buy? Coupon?
Sorry for my bad English (gogole transtorla)
vyvyra
Last seen: 8 months 3 weeks ago
if it didnt have greenish tint, I will buy one.!
FlashLion
FlashLion's picture
Thanks
There are just particles that are glowing in green.But they are very dim and fade quickly.
Could be useful just to check where is the front of the flashlight.
FlashLion
FlashLion's picture
The beam has no greenish tint. Maybe some of my beamshots are little misleading this time.
The light is more white than the light from Fenix PD35 and ThruNite TN12.
Lets wait for more opinions on the beam,which will confirm my opinion. Wink
sesgum
sesgum's picture
Thanks
!https://farm8.staticflickr.com/7624/16774039542_5ca72de177_z.jpg!
Thanks for the answer. Amazing pictures!
SteveCA
Last seen: 4 years 8 months ago
I have had the S30R for over a month now and there is no greenish tint. This flashlight is great with a fantastic UI. More than bright enough for any conceivable EDC use. I have no doubt that it would work well as a automotive headlight should mine ever fail. The ability to access moonlight mode and turbo mode at anytime is extremely useful. How many times have you needed moonlight to avoid ruining your night vision (or in a crowded restaurant to read the menu) but your last used mode was high? With this light, all you have to do is press and hold (from off) and it will come on in moonlight mode. Double tap from any mode and you have turbo mode. Triple tap for flashing mode.
I love this light! it has everything I want in an EDC plus long run times. I almost bought a few more but frankly, I only really need one.
FlashLion
FlashLion's picture
Thanks for the post SteveCA and welcome to BLF.
The quick access to Moonlight mode is a big + for all Olight flashlights that have it. It’s always good to know on which mode the light will start. Olight gives us this option.
Yes,people that have the S30R should share their opinion about the tint,because the S30 is the same flashlight,without the charging option.
mizjif
mizjif's picture
Last seen: 2 days 21 hours ago
Beautiful photos and excellent review!
I have heard that some people are having troubles with their S30R’s. Does anyone know anything about that? (Sorry if off topic)
SteveCA
I’ve had a bad tail cap (s30r) that caused flickering on turbo mode. I know some folks said to clean the tail cap but mine had to be replaced. Other than that, it has been a great EDC light. I replaced my trusty 4Sevens quark AA with this light. While the quark was a great light, the interface on the S30r is better still plus it uses the 18650 which I prefer over the 14500 which has at best 1/4 the capacity of the 18650’s.
rova2014
Last seen: 1 month 5 days ago
https://www.youtube.com/watch?v=tvQZt3sCeeM I was watching this review, there reviewer says that 1000lumene is only possible when using CR123A batteries.
Can any one confirm this?
Captainvideo
Last seen: 6 hours 48 min ago
Thanks for the review. Couldn’t resist $22 price at GB, especially after reading about the tint. I do have a S15 Titanium that does have a greenish tint and the blue side button that can be problematic. Beautiful looking polished titanium though.
chuckhov
Guys,
I’m a Tint-Snob and really Hate Green!
Just received mine a couple of hours ago and there is NO Green or even Blue for that matter… Sure there is the requisite yellow in the Corona that is typical of a Cree XML size die, but all in all – A Very Nice CW.
I was afraid to order (because of the Puke Green of the S10/S15 and S20, but for $22.59 I thought what the heck… The Man said there is no green so I’ll take him at his word. – Thanks Flashlion!!!
Thanks Olight! – Thanks Gearbest!
-Chuck Smile
Jack Kellar
Jack Kellar's picture
Last seen: 1 hour 32 min ago
Thanks for giving us so much information, especially since I’m waiting to get this very piece of awesome in the mail :bigsmile:
One thing confuses me, though: if the low mode only drains 42mA, which even on a relatively low-cap battery such as a 2600mAh translates to around 60 hours of runtime… how come does Olight specify it as only lasting 26 hours? Sure, being conservative with your measurements is all well and good, but that much difference seems like a gross miscalculation for a brand as renowned as Olight to let pass. Flat Stare
FlashLion
FlashLion's picture
Thanks for reading Jack Kellar!
I don’t know how much is the difference when using two batteries for higher voltage. Olight and many other manufacturers use 2x CR123A (6V total) for testing run time.
Jack Kellar
That’s odd. Everything else matches when I did a test by dividing a certain capacity by the current you measured. Moonlight runtime match a 3400mAh’s capacity, Turbo matches a 2600mAh, while Medium runtime stays between what a 3100 and a 2600 would supply. Meanwhile, Low would theoretically run for 61.9h on a 2600, and up to 80.95h on a 3400 one.
It’s really puzzling to me that they wouldn’t match exactly on such a low-strain mode…
