MT-G2 Thrunite T10T Ti "Micro Sunbeam"
33 posts / 0 new
ghos
ghos's picture
Hi all,
Its been some time since I’ve posted here, this is one of my latest builds in super small super bright flashlights (Smaller, brighter, better :bigsmile: )
My favourite LED emitter by far has been the 4000K MT-G2, its uniform circular appearance, nice tint and of course whopping lumens makes it an ideal light for flooding a room with flight
So I thought of making an even smaller light, just to see how small an MT-G2 light can be, I also wanted something exotic and well maintable, I’ve recently taken a liking for titanium lights, since it maintains its appearance well (it can be sanded and polished) and it just looks nice (Titanium :bigsmile: )
After some searching around, I found a nice light that I could potentially mod, the Thrunite T10T
This light has many good reviews everywhere, in sort, the one I got from the thrunite store is spec-ed as follows:
T10T Ti
- OP NW XP-G2 (I think 3c), 169 lumens with AA, 400-500 with 14500
- High, Medium, Moonlight (memory after 3 seconds)
- 1 × 1.5V AA Battery (0.9-3V range)
- Titanium (G4?), 93.5mm x 19mm, 37.4g
- Tailstand dual switch interface, reverse clicky / twisty
After playing with the light for a few days, began to start gathering parts around to mod the light, first thing to do was to find out how to open the light, I was prepared to inflict light scratches and scuffs on it, being titanium, it can be sanded and polished away, unlike anodized aluminum, which must be re-anodized
Taping both the head and the bezel with lots of painters tape, it was easily opened with 2 pilers grabbing on to them, I somehow still managed to scratch the head, but it was polished off, I didn’t see any red or green thread locker so it might just be a normal locking compound
Opening the head reveal a tiny (10mm?) led on a aluminum star, reflector removed (the LED pictured is NOT a XP-G2, but a Osram 4000k 92 cri reflowed for “testing” purposes :bigsmile: )
I wasn’t even sure if the MT-G2 could even fit into such a small space, so I sanded down the star until its essentially just the LED remaining, in the background is a comparison between a 16mm XHP-50 and a 18mm triple nichia 219a
Next up, sanding of a special reflector, the stock reflector cannot be used due to design and the wires will get pressed against the bottom, leaving a gap, for reference the reflector I used to make the MT-G2 reflector was taken from a Brass 18650 (its currently using a TIR optic, hence the spare reflector, its design allows it to be sanded down to fit and it will sit flush against the LED with space for the wires)
The next headache (and probably the most important of all) was to get a driver to run the whole thing, the space under the light was so small, I had to sand and remove 6 chips from a 105c QLITE driver and stack another 3 chips, one on an existing and another 2 via small wires for a grand total of 6 chips (2.2a), there is simply NO MORE SPACE for any additional chips
How was I able to power everything? Using 2 × 14250 battery, like these guys here, a 14250 battery is roughly half the size of a 14500, at 300mah each, about the same capacity as a 10440 battery
Last but not least, I didn’t really like reverse clicky switches, so I set out to find a way to convert the reverse clicky to a forward clicky. I managed to sand a normal forward clicky switch down to the same diameter as the original reverse clicky, attach a small wire from one of the metal plates inside to the bottom of the switch and soldered a small spring to it, put everything back together, it seems to work fine, however, due to either the design or my switch “retrofit”, there were gaps (button can’t click) and some shorting of batteries, due to the batteries touching the back of the light against the switch, pushing it backwards, after much experimentation, I put a piece of o-ring and a cut out paper with a hole for the spring at the back of the light, ensuring the battery does not touch the metal surface
And finally.. the completed light, the amount of light it produces for its size is unbelievable, it is even brighter then my triple osram, its a nearly full flood beam with a very large hotspot, which is perfect for lighting up the whole area, guestimate lumens would be about 800-1000-ish lumens on high (1500+ when 12mm 6v guppydrv FET driver comes in)
Stock clip has been replaced by a (mcgizmo?) ti clip
Light now joins the “sunbeam” family, a Download Pocket Rocket Ti (2 × 18350, 18×7135 guppydrv, 3000 lumen XHP-50) “Sunbeam” and a Sunwayman V10R Ti (1 × 16340, guppydrv 8×7135 Triple Osram 4000K 92cri) “Mini Sunbeam”
Thanks for reading!!
My MTG2 Thrunite T10T Ti “Micro Sunbeam” -> http://www.budgetlightforum.com/node/41059
My MTG2 #@!$ zoomable sk98 pocket rocket -> http://budgetlightforum.com/node/27089
My SK98 Triple Nichia 219 92cri-> http://budgetlightforum.com/node/27590
Edited by: ghos on 09/05/2015 - 13:11
djburkes
djburkes's picture
Last seen: 2 years 2 months ago
You tease…where’s the beamshots, lol?
ReManG
Now that is a beautiful build….
Bet it is surprising to those unfamiliar with your wizardry of lights…
ALL of my links are non-affiliated for your pleasure...
My Reviews
Lithium Ion Battery Safety 101
CRX
CRX's picture
Last seen: 2 hours 19 min ago
I like it! I’ve been thinking of doing something similar. Are the 14250 cells good quality?
We want beamshots! Wink
DBSAR
DBSAR's picture
Last seen: 6 hours 28 min ago
Never thought it was possible to squeeze the gargantuan MT-G2 in an AA-sized light Shocked
ghos
ghos's picture
Ok since everyone is asking, here is a beamshot, compared with my triple osram, both taken exactly the same distance I just realised, the T10T makes a VERY GOOD photography light due to its high flood
MRsDNF
MRsDNF's picture
Last seen: 18 hours 22 min ago
Simply WOW. Or should that be WOWSmile
Gunga
Gunga's picture
Last seen: 2 days 18 hours ago
Wow! Awesome job! Can you also mention what optic fits R
The brass 18650?
ghos
ghos's picture
Oh forgot to put, the cells used are IMR 14250 300mah cells, pretty much the best you can use, you can get them from MTN Electronics
ghos
ghos's picture
The brass 18650 should take any standard 20mm TIR optic, I used mine from fasttech
Gunga
Gunga's picture
Really? This is the tiny brass beauty? Does it for with lens? I think when I tried it was too short inside because the optic was too long.
ghos
ghos's picture
Emm.. I’m talking about this brass 18650..
Gunga
Gunga's picture
Yep. I have that one. Does it fit the optic and stock lens? I think the optic was too long for me but am unsure.
ghos
ghos's picture
Yeah it fits, i’m not sure which one i used as the light is not with me now.. the battery is a little tight though
xxx
xxx's picture
Last seen: 11 months 2 weeks ago
Wow. really nice modding
Billy X
Billy X's picture
Very impressive
Gunga
Gunga's picture
How do you like the tint? I love how you managed to shoe horn a Qlite circuit in there. I’ll have to try that.
Thanks for indulging my off topic questions before!
Smile
jacktheclipper
jacktheclipper's picture
Last seen: 4 hours 20 min ago
Sweet !
ghos
ghos's picture
It helped a lot that I could find images such as on this thread by rufusbduck http://budgetlightforum.com/node/31655?page=1#comment-589967
The image clearly showed where I could cut and not, and I realised I should have probably just gone with a 11mm FET driver.. much easier and more powerful
Smile
Gunga
Gunga's picture
Was it hard to get the old driver out? How big was the driver? Does it have a separate contact board? Do you have any pictures of that stage of the mod?
ghos
ghos's picture
The old driver is two stack with a contact board.. see pics.. , quite small, to get the driver out, I just poked a stainless steel tweezers from the top (after desoldering the star), with a medium press, it just popped out
Forgot to mention, I created a separate contact board by filing a partition board down to size and soldering the leads to the board
ghos
ghos's picture
djozz
djozz's picture
Last seen: 4 hours 52 sec ago
twin towers wrote:
I can't see photos
I can't either, seems like they do not show on android devices..
ghos
ghos's picture
Ok, images re-uploaded on another server, my host changed the nameserver ip itself, hence the rest of the world has not propagated yet
djozz wrote:
twin towers wrote:
I can’t see photos
I can’t eigher, seems like they do not show on android devices..
djozz
djozz's picture
Jay, pictures are there!
Great mod. And my favorite type: get small lights do amazing things!
ghos
ghos's picture
FET driver has arrived, insulating of the driver is needed as it is floating in the head, was able to wire the driver in without taking out the led
Being flashed with the guppydrv firmware, the light is able to use one of 22 mode groups, for this light, I have set it to 100 – 25 – 2 without memory
Light is now totally usable and practical is now my daily EDC Big Smile
ImA4Wheelr
Last seen: 5 days 34 min ago
I some how missed this one.  Congrats on this build.  Love it.  Very nice looking host.
ghos
ghos's picture
This is still my EDC today, it pairs really nicely with my Haiku, the T10T for wide flood and photo taking and the Haiku for throw and long distance, both are high cri (80+) as well and is carried daily..
I call them daishō, like the japanese samurai who carried 2 swords, one big one small :bigsmile:
Ronin42
Ronin42's picture
Last seen: 5 months 6 days ago
+1
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
somnambulism
Last seen: 6 months 1 day ago
I know I’m late to this thread but… Holy crap, this is amazing.
Gunga
Gunga's picture
Just curious. How did you secure the contact board? The stock circuit is press fit with some glue. I tried pressing my circuit out. Doesn’t want to budge. I didn’t want to destroy the driver modding it.
