Review: Hugsby XP-12
32 posts / 0 new
OrionLight
OrionLight's picture
Last seen: 2 years 11 months ago
Hugsby XP-12 Review
Reviewer’s Rating:
Special thanks to TOMTOP for providing the flashlight for review
SKU:L0028 Mini Flashlight  - (note: aid link is for tracking purposes only, no compensatory affiliation)
Price: ~$6.00
Manufacturer’s Features:
Super mini size (only 15.3cm) ,  very convenient to carry and store.
Equipped with high quality CREE XPE R3 LED, dispel darkness around you.
The maximum output brightness is up to 120 lumens.
Only one mode, easy to use.
Uses aircraft-grade aluminum alloy, with a very solid construction.
With wrist strap for easy carry.
Skid-proof, abrasion resistance and waterproof design.
Special reflector design can enhance light output efficiency.
Manufacturer’s Specifications:
Item Color: Black
Material: Aluminum alloy
LED Type: CREE XPE R3
Light Color: White
Lumen: 120LM
LED Span:50,000h
Waterproof Level: Daily life waterproof
Battery: 2 * AA battery (Not included)
Item Size: Approx. 15.3 * 1.9cm / 6.0 * 0.7in
Item Weight: Approx. 39g / 1.4oz
Package Size: Approx. 15.6 * 2.5 * 2.5cm / 6.1 * 1.0 * 1.0in
Package Weight: Approx. 48g / 1.7oz
Recently, Hugsby flashlights have started to gain a reputation as affordable yet well made alternatives to other budget lights in its class.  These days, AA flashlights are a dime a dozen and it’s easy to get lost in the shell game of guessing which budget light will deliver what they really say they can.  Long story short, there’s good reason why their reputation has been climbing.
The light isn’t much longer than the two AA batteries which power it.  It’s also not much thicker either.
From what I can tell, it has a genuine XP-E insdie.  It also has a very lightly textured orange peel reflector inside.  It’s difficult to tell from this picture, but the reflector is actually quite deep, which is why it’s able to throw its 120 lumens as far as it does.
Here’s a top view of the tail cap on the left and the head on the right.  The head features a foam right for physical reverse polarity protection.  There also seems to be no retaining ring.  Instead, under the foam, the driver seems to be soldered to the edges.  I had no way of removing the driver, emitter, or reflector from the head.
Here’s a side view of the threads.  They came a bit dry and gritty, but nothing a clean rag and some lube can’t fix.  After that, they turn with ease and the o-rings are perfectly sized to fit nice and snug.
I had a little more luck taking apart the tail cap assembly (after bending a pair of my needle nose pliers.  Boy that retaining ring was screwed on tight!) Simple switch, copper spring and a rubber cover that’s stuck inside the tail cap.  The switch is nice and solid.
Here’s a living room beam shot collage of some lights in the same class.  The XP-12 may take 2 AAs compared to the other lights, but the output is about the same on its one mode.  The pictures are taken at 1/3, f4, ISO-100.
Pros:
  • Solid build quality
  • Slim design, making it easy to carry
  • Good useful output
  • 2*AA on 120 lumens gives great runtime
  • Deep reflector for great throw
  • Unbeatable price point for similar lights in this class
  • One mode only, great gift for non-flashlight enthusiasts
  • Knurling is simple yet extremely effective and well placed
Cons:
  • Doesn’t seem to be easily moddable
  • One mode only, less versatility
Takeaway:
At a $6 price point, it’s hard not to be recommending this to everyone.  If you’re looking for a light to keep in the car, buy this.  If you’re looking for a quality gift that won’t break the bank, buy this.  If you need a simple light for every day use, buy this.  If you have spare change, buy this.
If Hugsby lights are all made to this standard and this affordable, I might just start a separate Hugsby collection.  Really.  Buy this light.
Edited by: sb56637 on 09/02/2017 - 11:48
Wrathbringer27
Wrathbringer27's picture
Last seen: 7 hours 43 sec ago
Wow it throws real well
Words can be broken,
so can bones.
OrionLight
It really does. I was messing around with it outside my 12th floor window and the throw seems to edge out my 2800mA Convoy M2 on low.
THAO916
Last seen: 3 years 6 months ago
Great review and one of my favorite lights.
vēer
vēer's picture
Last seen: 5 months 5 days ago
Mine is on the way to me.
Received XP-11 the other day, very well built, pretty good throw, consumes about 0.75A maximum with AA Eneloop.
Not sure how its with XP-12, but when I received XP-11, first thought was – they have put XP-1, an AAA model, too thin!
Eneloop Pro’s and some other NiMhs wont fit, battery tube too tight.
siata94
siata94's picture
Last seen: 1 week 10 hours ago
Just happened to use mine earlier this pm, very nice light for the price.
MountainKing
wow wow wow! Looking an awesome giveaway light! Need to find $6 sources that ship to my country Big Smile
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
MountainKing
The link you provided links to a 18650 flashlight…
Is this the link?
http://www.tomtop.com/mini-portable-led-flashlight-cree-xpe-r3-120lm-poc...
Might have to jump on this and get a couple _. Shipping costs $0.88 per item unregistered for me!
Edit: What is the runtime and is it kind of regulated? (estimated) No need some scientific testing there.
OrionLight
Is this the link?
Yeah, that’s the one. Sorry about that. I fixed it in the OP. I’m swimming in links. :bigsmile: Yeah, it’s practically a steal at this price. I’m thinking of using it as stocking stuffers for Christmas. Not entirely sure if it’s regulated, but I used a fresh set of eneloops for well over an hour for pictures and doing other stuff outside and it doesn’t seem to be dimming yet.
vēer
vēer's picture
BTW, wrist strap broke on mine during first use – its too small to fit on and off easily especially if wearing gloves.
This and not centered emitter, thats about it, nothing substantial at this price point :)!
MountainKing
Ok. Ordering 3 via aff link as gifters Smile Thanks for the review!
Pregulla
Pregulla's picture
OrionLight
Pregulla wrote:
Quote:
Please do not post your affiliate links or codes outside of the BLF User Negotiated Deals category.
I’m not even entirely sure what affiliate links do. I just put in the links I was given. Would I be able to still put in a link to the company website who provided the product and a link to that specific item just copied from the website?
Pregulla
Pregulla's picture
Then you better not to use this word Wink
Affiliate link is “your link” and if someone buy through it you get some reward for it. The first one if probably an affilate link, the second one is probaly a tracking link for the seller to know how many visits or purchases they have got from your review.
Anyway, here is a direct link, just use it to remove all doubts:
Bright_Mike
Are the Hugsbys pretty good about having cree or other high quality leds? SK68’s have kinda capped out, from what I’ve read Sad Looks nice, think I’ll get one, at least Smile
BTW the link in op still isnt working
Pregulla
Pregulla's picture
I think genuine Hugsby’s use genuine Cree. The problem is they became too popular and there are plenty of fakes out there. Topmop and LiteTeck (aliexpress seller) sell the genuine ones.
Easyrr
Last seen: 1 week 3 days ago
I couldn’t resist one, so it’s on the way Smile And thanks for the review!
phsinvent
phsinvent's picture
Last seen: 1 year 3 months ago
The xp-12 is a little gem. It also has a coated glass lense, not sure if I saw that mentioned in the review.
siata94
siata94's picture
as someone has posted elsewhere, XP-11 and XP-12 are cheaper here after shipping is calculated eventho it says free ship:
http://www.ebay.ca/itm/Mini-CREE-XPE-R3-Portable-Pocket-LED-Flashlight-Penlight-Torch-Light-120LM-Black-/271826472536?
http://www.ebay.ca/itm/CREE-XPE-R3-Portable-Pocket-LED-Flashlight-Torch-Light-120LM-Hand-Wrist-Strap-/271826474761?
vēer
vēer's picture
Take into account currency exchange rates and the difference might be the other way around ;)!
For me these appear to be more expensive than the plain .com US$ ones.
siata94
siata94's picture
for US, it’s cheaper from .ca because eventho the .com site says free ship, when you go to pay, it automatically
adds shipping, granted it’s like $.75 so not huge but that aint free :-).
vēer
vēer's picture
Thats odd, its free for me(non-US, EU state) :D!
You might want to edit your post to include this valuable piece of information because BLF aint about USA customer only ;)!
In both reviews :D!
OrionLight
In both reviews :D!
To be honest, I don’t know how the shipping calculates for each place. I’ll talk to the company rep and see how it all works so I can get it cleared up for everyone.
Summer You
Summer You's picture
Last seen: 3 years 5 months ago
**I found the ebay seller is also from Tomtop Ltd, would it cheaper including shiping cost ?
Summer You
Summer You
I checked the price $6.03 is not included the shiping cost.
If you want to know the shiping cost , you can input your delivery address, and the system will automatically calculate it for you.
Different countries will have different shiping cost . It seems more fair to customers from different places .
Summer You
MountainKing
Anyways, tomtop does not ship to Mauritius. They shipped there once and after that, they stopped shipping to Mauritius on ebay (probably costs them too much)
Shipping is on a PER ITEM basis and cost me $0.88 per flashlight I ordered without tracking. So, it costs me $2.65 in shipping fees for 3 which is kind of a ‘rip off’ :D. Anyways, the price was still very chompetitive and the ebay link do not ship to Mauritius.
siata94
siata94's picture
I think there are some confusions…
for me as a US customer, I found it was cheapest at .ca auction site. At the .com auction site, shipping is $1.99.
At tomtop site, it shows free ship but when I checked out w/ paypal, it adds $.71 for shipping. I just tried it again just now.
I’ve bought several of each all from the .ca site, have received the initial 2 orders. I can’t vouch for all locations,
only US. You just need to try all 3 sites.
siata94
siata94's picture
from .ca, the XP11 is still free ship, but the XP12 now $1.99 to ship.
vēer
vēer's picture
Got my XP-12, pulls 0.71A from two fully charged NiMh’s(Turnigy).
Build quality on par with my XP-11, which is very good for the price!
Tint is towards purplish vs warmish/greenish on XP-11.
MountainKing
How much lumens you estimate it? Any runtime test yet? Smile Got 3 stuck on the slow boaaaaaaat
vēer
vēer's picture
Forgot about the runtime Big Smile ! But given its brighter and runs off 2 batteries, it could be slightly bit longer than XP-11, just a guess.
No luxmeter, so no lumens here :D!
