Test/Review of Samsung INR18650-30Q 3000mAh (Pink)
39 posts / 0 new
HKJ
HKJ's picture
Last seen: 11 hours 35 min ago
DSC_2344
Official specifications:
  • Initial IR (1kHz):
  • Initial IR (DC):
  • Charge method: CC-CV (4.2V+/-0.05V, 100mA cut-off)
  • Standard charge current: 1.5A
  • Fast charge current: 4A
  • End voltage: 2.5V
  • Max. continuous current: 15A
  • Rated discharge capacity (0.2C): 3000mAh
  • Rated discharge capacity (10A): 2700mAh
  • Cycle life: 300 cycles to 70% (4A charge and 15A discharge)
  • Cycle life: 250 cycles to 70% (4A charge and 22A discharge, pause at 70°C, resume at 50°C)
Samsung%20INR18650-30Q%203000mAh%20(Pink)-info
Modern high current cells with lots of capacity.
DSC_2342 DSC_2343
DSC_2345 DSC_2346
DSC_2347
DSC_2348
Samsung%20INR18650-30Q%203000mAh%20(Pink)-Capacity
Very good discharge curves, capacity is nearly constant and they track perfectly. Even the 20A curve maintains a decent voltage, but as can be seen below the cell gets warm.
The tail on some curves is because I continue to record after stopping the discharge (If the cell is hot), i.e. it shows how much the voltage recovers.
Samsung%20INR18650-30Q%203000mAh%20(Pink)-Temp-10.0
The cell will heat up at a 10A load, but it is rated for it.
Samsung%20INR18650-30Q%203000mAh%20(Pink)-Temp-15.0
Samsung%20INR18650-30Q%203000mAh%20(Pink)-Temp-20.0
The cell can also handle 20A for some time, but you are supposed to stop when it gets hot (As I do here).
Remember the chart shows above ambient temperature, the actual cell temperature goes above 75°C.
Samsung%20INR18650-30Q%203000mAh%20(Pink)-CapacityTimeHours
Samsung%20INR18650-30Q%203000mAh%20(Pink)-Energy
Samsung%20INR18650-30Q%203000mAh%20(Pink)-PowerLoadTime
Samsung%20INR18650-30Q%203000mAh%20(Pink)-TripCurrent
Samsung%20INR18650-30Q%203000mAh%20(Pink)-Charge
Conclusion
This cell is very good, it can handle about 15A continuous discharge and has no problems with 20A pulses.
Notes and links
Compare to 18650 and other batteries
sesgum
sesgum's picture
Last seen: 1 month 1 week ago
Thank you!
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 hours 27 min ago
Yes, excellent review and testing ,thank you very much!
KB1428 “Live Life WOT
JPLight
Last seen: 2 years 2 months ago
What was your discharge cut off voltage ? 2,8V as shown in the Diagramms ?
HKJ
HKJ's picture
Yes, I have not changed that.
Mr.Scott
Last seen: 2 days 3 hours ago
Thanks for the review!
(I got lucky. I ordered some last night, prior to the review coming out.) Smile
DB Custom
DB Custom's picture
Nice to see, thank you!
I find this to be one of the best performing cells out there, and the capacity is just a bonus! Always good to get confirmation HKJ style, great to see the charts and get a feel for just what it’s doing.
Awesome work, as always, and again, Thank You!
vex_zg
Excellent. Now you are just missing to compare it with Sony VTC5A.
And also LG MJ1 would be nice.
akhyar
akhyar's picture
Last seen: 3 hours 58 min ago
Excellent review HKJ.
Glad I have few of these before the restrictions on shipping of Li-Ion cells from China by some of the online retailers
tarver
Last seen: 4 years 3 months ago
i used 2 of these new and in series in my ec4s. to my surprise, my opus showed that they took a very different amount of charge to refill each one. i see that as very bad. what should i do ? try it again, try 2 more new batteries, or just chop them in half with an axe ?
Henk4U2
Henk4U2's picture
Last seen: 6 hours 56 min ago
Thank you for the review HKJ.
I hope my flat-tops finally are on their way to me (yes, I was NOT on the GB and received button-tops).
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
DB Custom
DB Custom's picture
I find that the only cell that comes close to the 30Q is the Efest 35A or 3000mAh Dark Purple cell. Everything else falls short, including the Sony VTC5. I haven’t seen a VTC5A, so that one I don’t know about. The LG HE-2 falls short, as does the HE-4. What used to be the king of cells, the Samsung 20R, can’t touch it. (ok, well, the 20R does pretty high amperage but falls so fast due to it’s 2000mAh capacity)
That said, the light that I have that will draw the most current from a single cell prevails on the LG HE-2. 21.1A is the highest I’ve seen from a single cell in a flashlight, this is in a Titanium X6 Quad 219C. The 30Q and 35A are right up there, but not quite at that level. This is a rare case though, and in virtually every other light I’ve tried em in the 30Q is top dog.
SIGShooter
SIGShooter's picture
Last seen: 42 min 28 sec ago
If you’re looking at what the numbers are during charging then that’s very misleading. You have to do a discharge test in order to see what the capacities are. Even that is not extremely precise with low price chargers. My hobby charger seems to be 10% lower than my Opus, but which one is closer to being correct is impossible to say.
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
akhyar
akhyar's picture
I think what @tarver asking is why his 2 batteries take on different amount of charge after being used in his EC4S.
Running a discharge test will shows the capacities of both his batteries, which is another issue whatsoever.
But if he has not done so, it is best for him to do it first so that he can concludes that both batteried that gone into his EC4S has roughly the same capacity.
To me, if @tarver try 2 more new batteries in his EC4S and still get different amount of charge to refill, it’s more likely due to his light.
Hoop
Hoop's picture
Last seen: 2 months 5 days ago
Nice one HKJ. This cell is no joke!
1dash1
1dash1's picture
Thanks, HKJ! Smile
Rule 1-1 as it applies to life, take it as it comes.
JPLight
Thank you for your quick answer !
As I am always testing capacity of my rechargeable batteries, I was not really sure if my measurements were really accurate using my, in comparison to yours, budget equipment.
I have got 12pcs of 30Q and I am quite happy to see that my measurements pretty much match with yours (I´m just doing simple capacity testing up to 3A).
martosound
martosound's picture
Last seen: 1 year 3 weeks ago
Hi, everybody!
I need a help about INR18650-30Q battery manifacturing date code.
For the other Samsung elements refers written below:
■ Cell package : The bare cell is packed by which packaging material, PET tube.
■ Model and tube marking : there are three lines on the cell tube as follows.
Line 1 : INR18650-25R —- cell model name
Line 2 : SAMSUNG SDI —- cell manufacturer
Line 3 : 2D51 —- date code (Capacity ; “2” is over 2.0Ah, Year, Month, Week)
But 18650-30Q element have different Line 3 code. Only three letters. The principle of the code is different. I don’t know whether the item is new or 1-2 years old. Smile
DB Custom
DB Custom's picture
Since the Samsung 30Q is a relatively new offering, it simply cannot be 2 years old.
(I do have an atrocious time line memory, so 2 years could be “new” to me, sorry if that is the case. Bottom line is, it really can’t be an old enough cell to really matter. Authenticity would be far more important and there are other identifiers for that.)
tkd15
Last seen: 10 months 3 weeks ago
See the 1st line on the can under the wrapper, 3rd digit = year, 4th digit = month.
I found it here.
martosound
Thank’s tkd15 ! Wink
I understood. This is Lot marking.
■ Lot marking :
There are three lines on the cell metal can as follows.
Line 1 : J5D5 —-
1st digit: Line number ( “1” for cylindrical line No.1, “J” for cylindrical line No. 8)
2nd digit: Final number of Model Name (“5” is INR18650-25x)
3rd digit: Year ( “D” is 2013)
4th digit: Month ( “5” is May ; A is Oct., B is Nov., C is Dec)
Line 2 : 45221 —-
1st digit: Negative coater number ( “7” is No. 7 coater)
2nd ~ 4th digit: Batch number
5th digit: Serial No. of assembling
Line 3 : 62F1 —-
1st digit: Date (“6” is 6th day ; 10 is A, 11 is B…)
2nd digit: Serial No. of winding in a batch
3rd digit: Reel No ( “F” is F reel ; A is A reel, B is B reel, … F is F reel)
4th digit: Winding Machine No. ( “1” is No.1 winder)
teacher
teacher's picture
Last seen: 1 year 1 month ago
Is the flattop 30Q a raised flattop that will work in series?
vwpieces
vwpieces's picture
Last seen: 6 days 6 hours ago
No, the top of the pos is actually lower than the plastic wrap and washer. My HG2 are actually higher than the plastic.
teacher
teacher's picture
Thank you VW, I could not tell for sure from the pictures I could find and was wanting to order some.
Appreciate the info…… Smile
MRsDNF
MRsDNF's picture
Last seen: 1 day 7 hours ago
Button top 30Q are available from Gearbest if you need to use these batteries. I used this code last time (not sure where it came from) and may still be valid. a59300.
teacher
teacher's picture
Thumbs Up …. Thanks for the tip VW. Wink
wolfdog1226
wolfdog1226's picture
Last seen: 1 year 3 months ago
This definitely is a very good battery. I studied HKJ comparator for awhile. Only the relatively new VTC6 beats it in all of the voltages. Not by much.
The 30Q is ~$4 cheaper,,in that sense it would probably be the best choice. From a visual perspective and a performance perspective, I doubt if there would be any noticeable difference.
I have One of these for the last 1.5 years and it is still working well. i have a pair of VTC6,so far they are working well!
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
aL1
aL1's picture
MRsDNF wrote:
teacher wrote:
vwpieces wrote:
teacher wrote:
Is the flattop 30Q a *raised* flattop that will work in series?
Thank you VW, I could not tell for sure from the pictures I could find and was wanting to order some. Appreciate the info...... :)
It was good a week ago when I bought 4....but only works on so many pieces as far as I could tell....
a59300
teacher
teacher's picture
Thanks for that update VW, I was just about to pull the trigger on some at BangBang… with a code and points. Facepalm
Not even gonna waste my time now,,,,,,,,, Wink
I’ll just get em here in the USA & pay a bit more & have them in a couple of days.
Speed4goal
Last seen: 1 year 9 months ago
teacher wrote:
Thank you VW, I could not tell for sure from the pictures I could find and was wanting to order some. Appreciate the info…… Smile
I have no problem using any of my 30q in series. I have 4 put up I use in l6 and s70 to save weight of 26650s if imma be holding it for awhile. Got two from imr batteries and the other married pair from GB
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
teacher
teacher's picture
Good idea about the saving weight thing ‘Speed4goal’. Thumbs Up
Are your 30Q’s flattops or button tops like the ones below??
