HaikeLite Preview for MINI Triple-XHP70 prototypes--Discussion thread
203 posts / 0 new
Tom E
Tom E's picture
Last seen: 48 min 59 sec ago
kiriba-ru wrote:
What are you going to mode in triple xhp70 light? What driver are you going to put in that will work with 2 electronic switches?
Ssshhh, don't tell him, but, resistor modding, or swapping wires, or potting, or ... smile
giorgoskok
giorgoskok's picture
Last seen: 2 weeks 1 day ago
One switch you mean
Tom E
Tom E's picture
giorgoskok wrote:
One switch you mean
Yes, this light has just one switch, but two switch's is not a problem. I'd go with Narsil/Attiny85/LDO/FET, maybe 1 7135, maybe a bank, maybe both - depending on the I/O pin availability.
HaikeLite Official
HaikeLite Official's picture
Tom E wrote:
HaikeLite Official wrote:
Q2: The contact ring under the driver has been clamped, not be screwed-in. You will need a tool to pull it out by strong force if you want to dissassemble it. Bezel is not glued.
Ouch! Is it too late to get that changed to something more moddable/serviceable friendly? This doesn’t sound good…. frown
Hi Tom
The engineer is abit concerned that non-flashoholic users will dissamble the light out of curiosity to cause some damage.
In fact the retaining ring part has not been machined. Will discuss it again with our engineers tomorrow.
HaikeLite Official--all rights reserved
www.haikelite.top
Skype: haikelite@yeah.net
giorgoskok
I vote also for retaining ring on the driver .
thanks!
hIKARInoob
hIKARInoob's picture
Last seen: 52 min 19 sec ago
thanks!
+1
Thank you too Wink
The Miller
The Miller's picture
If you use a snap ring
With very small holes Tom and the likes can still open it up but people not in the know won’t do it.
giorgoskok
The Miller wrote:
If you use a snap ring With very small holes Tom and the likes can still open it up but people not in the know won’t do it.
Not a good idea for a solid contact .
Just my thought
Tom E
Tom E's picture
Threaded ring would be preferred, but if you want, don't leave any guide holes - we can drill them, not a problem...
derpilgerer
derpilgerer's picture
looking forward for a review, but so far im interested. The price will decide if I give it a shot Wink
Budda
Budda's picture
Last seen: 1 month 1 week ago
Good looking light!
All my reviews, in italian and english, here: Lumenreviews.com
hIKARInoob
Budda wrote:
Good looking light!
Have you applied for a review? They want someone to do a video review if I’m not mistaken.
HaikeLite Official
Tom E wrote:
Threaded ring would be preferred, but if you want, don’t leave any guide holes – we can drill them, not a problem…
Solution confirmed —Threaded copper ring.
www.haikelite.top
Tom E
Tom E's picture
Nice!! smilelaughingwink
hIKARInoob
Hello Haikelite,
can you perhaps share some information about the stepdown process?
- How long can the light produce 8000 lumens before stepping down?
- Is it time based, or is it temperature based?
- Is there a fulltime thermal protection on the light?
- And do you get the full 8000 lumens with half depleted cells?
Thanks!
sorotantaz
sorotantaz's picture
Last seen: 9 months 4 weeks ago
The reflector is very shallow. Not gonna see any useful light in 200 metres range. Sometime a hotpsot is needed to spot things at distance.
Interesting to see how this compete with olight x7.
Any auto step down from turbo or high?
And why there is a gap between body tube and head?
Texas_Ace
Texas_Ace's picture
Last seen: 5 hours 37 min ago
Is there any donut hole in the beam?
HaikeLite Official
can not see any donut hole in the beam, close to wall or at distance.
www.haikelite.top
HaikeLite Official
hIKARInoob wrote:
Hello Haikelite,
Thanks!
Specific info will be public next week. Smile
www.haikelite.top
HaikeLite Official
The hotspot can only been seen in close distance.
What gap do you point to? The gap among the cooling fins? It’s designed for lanyard hole. There are two landyard holes in the head, normal camera belt can fit this light,though no much need to use a belt for soda can light. Would be good to use a belt in other two big haikelite monsters.
www.haikelite.top
will34
will34's picture
Last seen: 1 week 3 days ago
Haikelite: take a look at the Olight X7 marauder, I think it has set a pretty high standard for triple XHP70 lights.
It also only costs $199, it might be useful for you to set as reference.
sorotantaz
See picture no 3 on your first post.
Where the body tube screwed in to the head there is a small gap. Before the fins.
leaftye
That’s why I want them to push output higher. Under 10k lumens isn’t that special anymore. If this thing has thermal regulation, then crank output to 11 for turbo mode, then crank it to 19 for a super turbo mode.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
giorgoskok
9 to 10k lumens is superb.
Will , 199$ isn’t so cheap , and i think even HaikeLite has a lower target… Beer
HaikeLite Official
Even with temperature step-down and thermal regulation, Turbo really gets hot after 4-5 minutes.
10K VS 9K has almost no difference to human eyes. And Less than 1 minutes turbo runtime is not we targeted.
18K haikelite is still under internal testing. We planned to release the sample next month. It’s a totally different form factor with huge heatsink area
www.haikelite.top
HaikeLite Official
Final UI updated:
Single Click-on ; Single Click-off
Hidden Moonlight 1-5 lumens (press and hold switch in off status)
Low Low-Low-Mid -High (Long press to change modes ; with last mode memory)
Double click Turbo (Double click in any mode , Single click to previous mode or OFF)
Click+hold+flash signal to lockout the light; Repeat to unlock. Tailcap-lockout also available
Switch LED indicator:
100%~50% power: Blue LED on
50%~25% power: Blue LED flash twice every 2 seconds
Below 25% power: LED turn red and flash
Blow 20% power: The flashlight will flash fast and step-down to moonlight.
www.haikelite.top
leaftye
That 18K sounds like the light for me. I don’t need a compact 4×18650 light, so make it big with crazy output. Heat could be good for me though, especially this winter in a poorly insulated shop. I’d have the brightest handwarmer in town.
hIKARInoob
18k light. Ok, that’s light number three. Six lights you were going to release. I hope to hear about the remaining three other lights soon…
hIKARInoob
Man, can’t wait for the official specs and pictures…
Ronin42
Ronin42's picture
less concerned about instant max lumen number as max sustainable max lumen numbers.
it seems if you ask the question what is the max lumens that can be “used” there seems to be about a 3k upper limit.
or to put it anouther way i want to see a non turbo top 10 shootout.
oh can you give use more info on the tints offered, thanks
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
