HaikeLite XHP70 Thrower Prototype Sneak Preview
319 posts / 0 new
pilotdog68
pilotdog68's picture
High CRI will gain you lots of sales to BLF people, but I must say I would consider it a poor choice to get rid of those other two tint options. 6500k and 5000k will cover most of the market for this light, as it seems the people that impulse buy because of “LUMENZZZ” just want the highest output no matter what, or some people simply like the cooler tints.
A 4000k 90cri option will get you some of the more particular buyers, and put you in the good graces of this forum. More tint options are always very welcomed.
Stereodude
Last seen: 8 months 1 week ago
This is where it starts to get quite personal. Maybe they could offer custom emitter options where a small premium is charged, but the LED can be chosen for the light and built to order. Building a bunch as a stocked option seems like a way to get stuck with a lot of unsold lights.
Texas_Ace
Texas_Ace's picture
Last seen: 6 hours 50 min ago
pilotdog68 wrote:
High CRI will gain you lots of sales to BLF people, but I must say I would consider it a poor choice to get rid of those other two tint options. 6500k and 5000k will cover most of the market for this light, as it seems the people that impulse buy because of “LUMENZZZ” just want the highest output no matter what, or some people simply like the cooler tints. A 4000k 90cri option will get you some of the more particular buyers, and put you in the good graces of this forum. More tint options are always very welcomed.
Yes, you have some very good choices for LED’s as it is, do not get rid of those. I would simply suggest adding another high CRI and slightly warmer option to the table. 3 tint options is a good range that covers 99% of peoples needs.
RollerBoySE
RollerBoySE's picture
Last seen: 2 days 9 hours ago
My personal favorite is CRI >90 and around 5000K.
I will gladly pay a premium for high CRI.
hIKARInoob
hIKARInoob's picture
Last seen: 2 weeks 1 day ago
The problem is that the remaining 1% are all present here on this forum expressing their opinions. “5050K is definitely too cold, I think 4950K is perfect. No, no, no 92 CRI is not high CRI, 93 CRI is high CRI. I want one click, two click, three click and hoooold for moonlight, click hold hold click and click three times for lock out. No I think click click hold, click click hold should be lockout. I want two click turbo, but single click for real super turbo.”
Man we’re going to drive you nuts HaikeLite! Turn around and run! Run before we drive you nuts!
Ok, but after we send you money and you send us tracking info. Thanks!
RollerBoySE
Please note that there are virtually no throwers or headlamps with high CRI on the market, so there you would have an open goal.
Texas_Ace
Texas_Ace's picture
hIKARInoob wrote:
The problem is that the remaining 1% are all present here on this forum expressing their opinions. “5050K is definitely too cold, I think 4950K is perfect. No, no, no 92 CRI is not high CRI, 93 CRI is high CRI. I want one click, two click, three click and hoooold for moonlight, click hold hold click and click three times for lock out. No I think click click hold, click click hold should be lockout. I want two click turbo, but single click for real super turbo.” Man we’re going to drive you nuts HaikeLite! Turn around and run! Run before we drive you nuts! Ok, but after we send you money and you send us tracking info. Thanks!
Yes, you have to take what this place says with the understanding that we will pick apart ANYTHING and try to make it better.
Just because someone suggests something doesn’t mean you have to use it but it would be wise to consider it.
The key is getting on here early enough in the design cycle to really be able to use the suggestions easily, to sift through all the cross talk and find those few gems that truly add value and increase the lights sellability.
It sounds like in this case they know what they are doing and have a very good base to work from for the host. I would not doubt that they have been snooping around here a lot longer then when they posted this thread Innocent
KawiBoy1428
KawiBoy1428's picture
Last seen: 12 min 31 sec ago
Heck while your at it throw a MTG-2 emitter option in there as well! Wink
KB1428 “Live Life WOT
HaikeLite Official
HaikeLite Official's picture
Update:
Roughly-made switch in this sample
And the big and deep reflector , Size: 78mmx68mm
Roughly-made battery-carrier in Testing sample (custom-made springs and contact copper rings will come back tomorrow, then i will update the OP and measure the led drain)
HaikeLite Official--all rights reserved
www.haikelite.top
Skype: haikelite@yeah.net
The Miller
The Miller's picture
The switches look great
The reflector looks impressive
But that tail looks like you need to make one hole bigger and one of the guiding rods also, this way the cap only fits one way (or make one rod and hole smaller that’ll do too)
Pok
Pok's picture
Last seen: 12 months 4 days ago
Other version for XHP35 Hi + SMO reflector ?
The Miller
Oh wait you will want to use same size rods and drill for the holes
OK now the holes are at 9 and 3 o’clock position (straight line through middle)
Do them at 3 and 6 o’clock or any position they are at angle of 90° if connected with an imaginary lone through the middle
Same drill for holes, same rods but only 1 way to close the cap.
HaikeLite Official
Hi Miller
Thank you for pointing it out. One hole bigger and one hole smaller will be a perfect solution
We planned to print “+” “-” marks to the batteries.One-way fitting makes it better. Beer
www.haikelite.top
wolfdog1226
wolfdog1226's picture
Last seen: 1 year 1 month ago
Why is TURBO HIDDEN?? Maybe Strobe,,,but Turbo should be instant access!!
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
pilotdog68
Double-click at any time is hardly hidden IMO
wolfdog1226
I did not see that! All I saw was Turbo and Strobe were in hidden mode and not the normal sequence. I did not read the whole page!
        WOLFDOG
pilotdog68
Thumbs Up
HaikeLite Official
The Cooling fins in this light can deal with the heat very well , at 6.5A turbo the host got hot very slow.
Electrical-engineer will rise the drain up to 7.5A on turbo.
Turbo date updated in the OP.
Holiday time from tomorrow here. Will keep updating the testing results next Monday when all custom-made components are back.
www.haikelite.top
Texas_Ace
Texas_Ace's picture
Or add a 3rd pin to it to make it even easier to line up visually.
leaftye
Last seen: 4 weeks 1 day ago
Please put a generous radius on those pins. I wouldn’t go for a full radius though because that would allow the tip of the fat pin to fit partially into the small hole.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
will34
will34's picture
Last seen: 15 hours 10 min ago
HaikeLite: Actually you only need 1 pin. The contact PCB will align itself when you turn the tailcap.
Also take a look at JETBEAM sra40, the pin and receiver hole are shaped so alignment is super easy.
blueb8llz
Last seen: 1 day 8 hours ago
I still don’t think turbo is in the normal sequence. Description says low, medium, high.
Turbo is double click. The ui would be so much better if turbo is in the sequence and so that it can be a mode that can be memorized.
Tom E
Tom E's picture
Last seen: 11 hours 12 min ago
I agree - turbo in the sequence is better. In Narsil, I have quick access from OFF to last mode, moon mode, and max/turbo (click, click&hold, double-click) -- what could be easier on a single e-switch? Everyone gets what they want. I normally prefer no mode memory with e-switch's, but when you have easy access to all 3 possibilities, why not?
A bunch of stock lights now have 2 of the 3 features - not sure if any do all 3.
PyTech
PyTech's picture
Last seen: 1 year 9 months ago
The light looks awesome.
Very entertaining thread. Smile
-Sean
blueb8llz
Tom E wrote:
I agree – turbo in the sequence is better. In Narsil, I have quick access from OFF to last mode, moon mode, and max/turbo (click, click&hold, double-click) — what could be easier on a single e-switch? Everyone gets what they want. I normally prefer no mode memory with e-switch’s, but when you have easy access to all 3 possibilities, why not?
A bunch of stock lights now have 2 of the 3 features – not sure if any do all 3.
couldn’t have said it any better.
thats what i was trying to tell their company….be unique and stand out from all the rest, put turbo in the sequence so that it can be memorized.
the ui they have now, is similiar to olight, nitecore, thrunite, sunwayman, etc…
this way the user has many options….
BOMBAY
Last seen: 2 hours 22 min ago
price range ?
hIKARInoob
BOMBAY wrote:
price range ?
According to HaikeLite it’s “reasonable”…
Wrathbringer27
Wrathbringer27's picture
Last seen: 10 hours 3 min ago
hIKARInoob wrote:
BOMBAY wrote:
price range ?
Highest I would go would be 75
Words can be broken,
so can bones.
HaikeLite Official
Is there anybody who is good at doing video reviews?
Pls PM me Smile
www.haikelite.top
The Miller
BLF user everydaysurvivalgear can explain thing very nice in his YouTube videos
Mhanlen makes good videos
Old Lumens has about the perfect voice to bring all pros and cons to light.
And these are just 3, your inbox is about to explode Big Smile
