PD68 Review: Thrunite TN4A HI - 4*AA Light
31 posts / 0 new
pilotdog68
pilotdog68's picture
Last seen: 2 months 17 hours ago
(Click pics for full-size)
The Packaging/Accessories
The light comes with a very nice holster, a lanyard, two extra O-rings, and an extra gasket for the switch. The light comes wrapped in a satin-like plastic bag, then in the holster, then in the pictured box which has more foam on the inside. My sample was provided by Thrunite through their Amazon store, so it was then in a separate cardboard shipping box with air shippers.
The Construction
This light is about what I expected it to be: high quality. The finish is not shiny, but also not rough under your finger. I like it alot. I could not see any flaws or machining marks poking through. The only sharp edge is on the lanyard cutout, which you can see in the top picture. The knurling on the battery tube is on the aggressive side, which is good because there isn’t any knurling on the head at all. The bezel appears to be SS with a bead-blasted finish. The lens is AR coated and both it and the lens are immaculate. No dust or smudges inside (until I opened it up myself). The switch surround is pronounced so it is pretty easy to find, but the switch itself is level with the surface so an accidental activation would be rare. The base is flat so it tailstands perfectly, even with the lanyard attached. The battery carrier is also very nice; polarity is the same on both ends. The LED is mounted on a very thick copper MCPCB, not sure if it’s DTP or not but that doesn’t really matter at these amp levels.
The dimensions are:
115.4mm long x 45.6mm wide
The reflector ID is approx 34.5mm
Here is a comparison with the Supfire M6, EagleEye X2R (same size as Convoy S2+), and an SK68.
The UI is as follows:
From off:
Click and hold: Moon
Single click: last mode memory
Double click: Turbo
From on:
Click and hold: jump to low, then ramp up through L > M > H > L > M > H etc
- So if you are in Medium and want to go to High, you will click and hold. It will first jump down to low, then ramp up from there.
Single click: off
Double click: Turbo
Double click from Turbo: Strobe
Moon, Turbo, and Strobe are not memorized. So if you start the light in Medium, then double click into turbo, then click off from there, the next time you turn it on it would go to your last used “normal” mode, which was Medium.
Input Current: This was measured with my power supply giving 5v to the stock driver, with my DMM in series to get the measurements.
Moon: 1ma
Low: 28.1ma
Med: 200ma
High: 0.92a
Turbo: 1.47a
Strobe: 0.62a
Output Current: This was measured with the power supplied by the stock battery carrier, and my DMM directly in series with the LED.
Moon: 0.68ma
Low: 32ma
Med: 250ma
High: 1.26a
Turbo: 2.49a
Strobe: 1.14a
Performance:
Overall I think it’s quite good, especially for a light running on AA’s. The properly focused reflector partnered with the XP-L HI makes for a nice focused beam. Other than the typical Cree corona, there are no artifacts to speak of. The fact that you can’t go directly from Medium to High is weird, especially for anyone who has used the Olight UI before. If this was the first UI you learned, it wouldn’t be hard to get used to. This would be a great light for someone who wouldn’t do well with Lithiums, or someone who just doesn’t want the extra investment. The tint on my sample was Cool White. It isn’t as cool as others I have had, I’d guesstimate it is closer to 2A than 1A. Props to Thrunite for also offering it in Neutral White. There is battery monitoring with an indicator in the button. Blue for ok, Red for low, Flashing Red for very low. I’m not sure how reliable it is though, at one time it was flashing red on just-charged batteries.
Mod Forecast: Sunny
Nothing on this light was glued, it all came apart easily. There is a solid shelf under the LED, and the E-switch is on it’s own PCB. An emitter swap would be easy, though I suggest using the stock MCPCB since it is thicker than normal and it looks like there is a thermistor mounted on it. An XHP35 mod with 4S 14500’s would also be interesting.
Recap of the cons:
- The switch bump is the only anti-roll portion of it, so it will roll 80% of the way around before stopping.
- The sharp point on the lanyard attachment hole
- The UI isn’t perfect, but not awful either. It’d be nice to not step down to Low before ramping up every time.
- The battery level indicator seemed finicky, but it could just be my old Energizers causing that too.
You can buy it directly from Thrunite using these links. Thrunite Direct does accept Paypal.
ThruNite Official Store: (5% OFF Coupon Code:THRUNITE , limited time!) http://www.thrunite.com/
Amazon US: http://amazon.com/thrunite
Edited by: sb56637 on 09/02/2017 - 11:48
hIKARInoob
hIKARInoob's picture
Last seen: 5 hours 26 min ago
I was bummed when this light came out some time ago. I Like Thrunite’s more expensive offerings, and this model looked budget, and well, not so exciting. But it performs so well. And everything I’ve read about this light is pretty positive. The build quality is just really good, and so is the finish. That’s the stuff you really can’t see just by looking at pictures. Solid shelf, and that thick copper MCPCB with temperature sensor; just nice. Maybe not budget price like Convoy, but personally I find the 50 bucks really well priced. It’s one of those lights that I keep checking out regularly (I don’t own one), as well as the TN36-UT (definitely not cheap) with the same design philosophy. And you know what? After its release, this light is still competitive with the latest offerings from other companies. Yeah I like Thrunite a lot. Thanks for the review sir Wink
lightx
Last seen: 3 years 1 week ago
Thanks for the review.
The build quality looks very good.
The Miller
The Miller's picture
Nice review, thanks.
Just look at all those wires coming from that driver.
Does the switch indicate cell status?
pilotdog68
pilotdog68
I feel like I owe Thrunite one free bump since I posted this on a Sunday.
T.H.Cone
T.H.Cone's picture
Last seen: 1 year 1 week ago
LOL, you owe them nothing other than the excellent and comprehensive review in the OP. It was fantastic as always, PD.
fidem, prae caeteris omnibus praeter honestatem
Don't be confused, my Username has been changed from "Cone" to "T.H.Cone".  I'm still the same clown.
lightx
Anyone knows what payment methods accepted at their official store (http://www.thrunite.com/) ?
Do they accept paypal?
pilotdog68
They do accept paypal on their website
lightx
wow, thanks man for the quick reply Smile
Remster
Last seen: 2 years 7 months ago
I have this and I like it. It’s supposed to the max output king in its class (4xAA soda can format) and it runs well with Eneloops.
hIKARInoob
What I also like about this light, is that it maintains max output really well (Selfbuilt’s review) until batteries are depleted. Moonlight mode, 15 lumens, 139 lumens…; really nice spacing as well for everyday use.
mattlward
mattlward's picture
Last seen: 52 min 47 sec ago
Dang, nice gimme! I picked up the V4A and really like it, but this looks a step above. I am not sure about that ui, would love to memorize moonlight mode. I am very interested in the V3 1A with a neutral white emitter.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Speed4goal
Last seen: 1 year 1 month ago
I’ve had this light since it came out this one and the nw version. Just traded the nw one. I won’t get rid of the cw one. This is a great and tough light. Its not very cool like 1a but thrunite is known for that. My battery indicator works flawlessly and very accurate. But my nihm are only 6 months old.
The run times are pretty accurate about 1 hour on turbo. If you try to run turbo on alkalines. 15-20 mins there toast. But in a emergency situation the lower modes will run for a long time when with alkalines. Don’t recommend them because they can leak. But just saying in a pinch, power outage or storm can’t recharge alkalines do fairly well on the low and mid level. Ever since Katrina I keep a few hundred alkalines on hand at all times and enough nihm I shouldn’t need them. But just in case I can’t recharge what I need fast enough.
But anyways if anyone is looking to gift a nice aa light for christmas for people who can’t be trusted with lithium this is a good light. The light will get hot, when the thermal stepdown kicks in its not noticable it’s very gradual. Slow enough that your eyes adjust and don’t notice. But it gets hot before that happens and will stay warm. Seems to just cut it down barely which I like. In the cold weather like hunting season its great it sheds heat well and will warm your hands
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
Threadneedle
Threadneedle's picture
Last seen: 1 day 15 hours ago
Great torch. I’ve bought way too many of these as presents.
pilotdog68
I guess I didn’t realize how long this light has been available. Normally companies send newer lights for reviews. Maybe it was a test if I could be trusted with their more expensive lights…
lightx
I believe the CW version released almost a year ago. But the NW version is newly released, probably around a month (or less).
hIKARInoob
1) The light is so good that it’s not obvious it’s been around for some time now.
2) I have noticed that companies recently sent out older flashlights for reviews as well (youtube); for example Thorfire’s divelight and several Lumintop SD75. I wondered why as well. One possible reason is that a review by a fairly popular youtuber means it’s advertisement. Anyhow, I wondered about this as well.
pilotdog68
Per Thrunite’s request, non-aff links have been added to the OP including a general-use 5% coupon.
Speed4goal
That is not correct, I’ve had the both versions for around 6 months just traded my nw version a couple weeks back
Threadneedle
I took my TN4A HI out the other night with a friend, having not used it in several months as I was indulging in lots of other torches. Its performance surprised me just like the first time I took it for a spin. It really is such a great bit of kit, and those threads just feel so damn glorious. I’ll be buying a bunch more of these as presents, however, that USD to GBP is killing me atm. Facepalm
hIKARInoob
…And I keep staring at the TN4A again… It is such a great light… Don’t know how long I can resist… It’s really my number 1 choice when it comes to 4AA lights…
ImA4Wheelr
Last seen: 1 week 3 days ago
Looks good.  Thanks for the review.
pilotdog68
I always forget to mention this, but in any of my reviews you can click the pics for full size. just fyi
D10ten
D10ten's picture
Last seen: 3 weeks 9 hours ago
I already have the old TN4A in NW XM-L2, but after reading PD68’s review I ended up getting the XP-L HI version as well. This is the best 4xAA light in my opinion.
Tangra
Last seen: 21 hours 57 min ago
Thanks for presentation.
I have just ordered one. One of big advantage of Thrunite is that they offer also NW tint.
Me personally never will buy flashlight with angry blue cool tint.
Speed4goal
I could be mistaken I don’t think the tn4a ever came with a xml2 my nw one had a xpl v6 in it.
The ea41 is also one of my favorite aa lights. I kept the tn4a hi traded to nw one. But thrunites cool isn’t very cool like some lights. Like there nw lights are more warm then neutral
Tangra
I have Nitecore EA45S. It is good light, but tint is cool white and you cannot just loosen the tailcap to cut off stand-by current.
D10ten
D10ten's picture
The TN4A was initially offered in XP-L V6 CW and XM-L2 U2 NW, but later changed to XP-L NW. I got the earlier light, it has a black button cover instead of the silver cover on my TN4A HI.
Tangra
Here is mine.
sbslider
sbslider's picture
Last seen: 1 hour 55 min ago
Hope you don’t mind me posting this question here. I recently purchased this light because of all of the positive review, but also to use next winter as a bike light. My goal is to use the light in turbo mode mostly, and recharge either daily or every other day. The first thing I learned is I need new batteries. Investigating the health of the ones I have, I found that when the light is in turbo mode it is very sensitive to the pressure between the battery pack and the electronics. No surprise, as the currents are pretty high, and a small change in voltage due to unwanted resistance results in big changes in current.
I saw at least one person comment on the low battery indicator being a bit finicky. Has anyone played around with trying to improve the pressure/connection between the battery pack and the electronics? I don’t think the current setup is ideal, something better would cause the pack to move toward the electronics without the pack rotating. sounds pretty grindy when you try and crank down the pressure to improve the connection.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
