Review : Utorch UT01 Flashlight (XP-L V6 / AA & 14500 / e-switch)
383 posts / 0 new
perche
Last seen: 1 year 8 months ago
well i make a video and gearbest offer me a new unit, cross my fingers.
btw there is any solution for switch?
HorizontalHunter
HorizontalHunter's picture
perche wrote:
well i make a video and gearbest offer me a new unit, cross my fingers. btw there is any solution for switch?
I have one on the way so that’s good to hear.
Anyone put a magnet on the tail of this light, and if so which one did you use?
Bob
Vegetarian: vejiˈte(ə)rēən/noun: old Indian word for lousy hunter.
joechina
The UT01 arrived, nice finish but doesn’t work.
Sad
Is it normal, that the driver wiggles? I can turn it ca. 5 degrees without force only by touching.
Beside that a scratch on the PCB and dust.
Joe
giorgoskok
giorgoskok's picture
Last seen: 4 days 15 hours ago
Hello Joe .
What battery do you use ?
joechina
An Alkaline 1,5V no way it is too long and NiMH.
Also from a holder with leads to the head. It should be the head and not the tube and end cap.
joechina
Ah, by the way I measured the total length of the lamp everything tightly screwd down and its
84mm long weras the specs say 82mm.
So maybe they use now a longer tube?
joechina
Bob
I would try a 10mm x 2mm round magnet outside of the Tailcap fixed and covered with sugru.
Google: Sugru magnets
https://www.google.de/search?q=sugru+magnets+ideas&oq=sugru+magnets
HorizontalHunter
Bob
Thanks Joe.
kramer5150
kramer5150's picture
Last seen: 4 months 3 days ago
Sad
Joe
The driver should not be lose, at least neither of mine are.
Does it work if you remove the tail cap and touch -B to the end of the body tube with a wire or paper clip?… it should.
My total length is just a hair under 84mm
joechina
No, it doesn’t light if I short the tail.
I am going to mail the seller.
kramer5150
Yeah you got a bad one, that driver board needs to be in there solid I think to make electrical contact. I just tried “picking” at mine with a fingernail on the +B input button and it doesn’t budge.
Wildcat
Last seen: 10 hours 40 sec ago
I opened my DOA flashlight and test driver. Driver works Ok, button is dead. I need to replace button.
I find type of button: TL3340. And all shops with this button not ships to Russia Sad
Sanctons? Smile
joechina
Bob
Thanks Joe.
Sorry, I tried it with my magnets scotch taped on the outside. One is not enough, two stacked could work. My 10×2 were rated as N52, but I am not shure about it.
I read a Skilhunt H03 a 18650 light uses a
16 × 2 mm magnet on 0,5mm wall thickness, you should use this.
Joe
HorizontalHunter
Thanks for the update Joe.
Bob
mrheosuper
Last seen: 5 days 20 hours ago
I just received my utorch ut01 today
and my first word:WTF
the switch is broken completely(very hard to turn on, switch mode, press 10-20 times, only 1 times work)
the positive contact on driver board is DIRTY, the most dirty one i have ever seen
AND THE WORST IS
Gearbest Sent me wrong color temp( i ordered 5000K, and they sent me something much Warmer than 5000k)
i dont know what should i do now, I WAITED 20 DAYS just to recieve this light
Forgot my pen
MAD TM26
MAD TM26's picture
Last seen: 10 months 4 weeks ago
mrheosuper, have you tried cleaning the contacts?
we buy light for a brighter tomorrow
mrheosuper
No, but the problem is the switch, become sometimes it works for seconds
Forgot my pen
MAD TM26
MAD TM26's picture
As you mentioned this on your above post, “the positive contact on driver board is DIRTY, the most dirty one i have ever seen”, I’m thinking why not clean and check the contacts are good before blaming the switch?
Just a thought…
mrheosuper
Just a thought…
i will give it a try
but very likely it’s because of the switch, many people have reported same problem like
i lost the lotery Sad
Forgot my pen
mrheosuper
btw, i dont know why my light has a very warm tint, warmer than astrolux s2 3d 5000k, i guess it’s about 3500-4000k
but utorch ut01 doesnt have “warm white” option, strange
Forgot my pen
kramer5150
my Manker E11 is very warm too, much warmer than neutral. Like a yellow-ish beige. I use it late at night for its warm-candle glow. Although with a low CRI, its really nothing to get excited over, IMHO.
[EDIT] But I still think its in the “neutral” 5000K-ish range. Its still considerably more pale than my Surefire incans. I really don’t notice it until I directly compare the two on a white wall.
mrheosuper
Yeah, i think it’s not 5000k
at first i think they sent me wrong one, then i checked again
Forgot my pen
kramer5150
One thing for me personally in regards to LED tints, the temperature I see heavily depends on what color my brain happens to be pre-calibrated to. Staring at the pale-blue colors of the BLF forum for example shifts my perception to a colder nominal, so then when I look away everything looks slightly warmer. Try this… white wall hunt with your warm tint light and note its color temp. Get a yellow-orange construction paper sheet and hold it right up to your face. Shine the light at the paper with it up to your face and stare into the bright orange color for 10-15 seconds, blink a few times. Now go back and white wall hunt… what tint is the light now?
mrheosuper
Will try it, when i have time and orange paper(:P)
I know our brain is not perfect, today i use ut01 all time, and now all my flashlight’s tint are silghtly cooler
Forgot my pen
Streamer
Streamer's picture
mrheosuper wrote:
btw, i dont know why my light has a very warm tint, warmer than astrolux s2 3d 5000k, i guess it’s about 3500-4000k but utorch ut01 doesnt have “warm white” option, strange
I had the same issue with Manker U-11. I won this light and requested NW tint but tint is yellow. Closer to 5A than any other tint. Nowhere near 5000K. Shit Tint Happens… Crazy
perche
jesus what happen with switch in that flashlight Facepalm
peteybaby
peteybaby's picture
Last seen: 2 hours 40 min ago
I didn’t receive my UT01, after something like 8-10 weeks, so I submitted a ticket, and paid a little extra for GearBest to send me a 2nd one. I asked if they could test the light before sending it, given all the switch problems reported, and the person told me that all units are thoroughly tested. We’ll see…
Subterrestrial
Subterrestrial's picture
Last seen: 2 years 9 months ago
I recently got mine and I’m lucky that I haven’t had the switch issue, but I’m having a different issue. I can’t get Eneloops to work consistently. Sometimes it turns on, sometimes it doesn’t. Sometimes you put an Eneloop in and it turns on, then you set it aside for an hour and try again and it won’t power on. I have no problem using alkaleaks. Works flawlessly every time and just by eyeballing it, both cells appear to be the same length or very nearly so. I just don’t get it and it seems like some of you are using NiMH cells. Any ideas?
Also, I’m disappointed that my Orbtronic protected cell doesn’t fit (should have read this thread first). There are some good suggestions in this thread, should we compile a list of IMR cells known to fit/work?
Also, looks like I’m not the only one to get the “surprise” warm tint model. I actually prefer this tint so I have no problem with it. Thumbs Up Beer
joechina
I have a complete dead light and wait for respond from Gearbest, but I have already collected a list of short protected LiIons :
My meassured Tube UT01: 51,9mm x 14,75mm
No guarantee for the list, these are only mentions from other people
- Marsfire
- Trustfire
- AW (short maybe to long) https://www.akkuteile.de/lithium-ionen-akkus/14500/aw/aw-14500-lithium-i...
- Xstar 800mAh
http://www.xtar.cc/products_detail/productId%3D43.html
- Soshine 14500
- Nitecore 750mAh
Nitecore nl147 battery (one UT01 User said it worked other it doesn’t)
There are different infos how long LiIon can be, maybe tolerance from tube or battery
50,8mm won’t work
50,3mm yes
Q: http://www.taschenlampen-forum.de/threads/manker-e11-review-1xaa-power-e...
Quote:
My example Manker E11 will operate w/most AA’s, and 14500’s (non-protected or protected) as long as the length doesn’t exceed 51, 52mm (max) from nipple top to bottom. For example, I’ve found the Xtar 800mAh *protected 14500 Li-ion’s to work just fine seemingly giving same output as IMR’s.
The lamp is 84mm long, not 82mm as in the description.
If everything is to long I would go with two 0,5mm thick rings in the head and the tail. Lose in the tail, in the head I would use two solder points as fixation to prevent shorts.
Joechina
Subterrestrial
Thanks for that list Joe. Interesting that the Nitecore NL147 works. I wondering if others have had success with the NI14500A cell? I believe Giorgios mentioned using it as well. I think I’m more interested in using an IMR cell in this.
Hope Gearbest can straighten out your issue!
