Does this type of switch exist?
32 posts / 0 new
Enderman
Enderman's picture
Last seen: 7 hours 24 min ago
A switch that is like a momentary push button, but when you press down it will disconnect and reconnect the circuit almost instantly, and when released does nothing, just remains connected.
I can't seem to find a proper name to search for this kind of switch, if it even exists.
In other words it is an NC (normally closed) push button momentary switch, that disconnects and reconnects in a single push down action.
Usually to get this result you need to use a regular push button NC momentary switch, then press and release it quickly, and that does the same thing.
Thanks in advance Smile
PS- this is to create a mode-switching button on a flashlight who's driver has no mode switch, and only switches modes by shutting off and powering on the driver quickly.
Jerommel
Jerommel's picture
Last seen: 3 days 23 hours ago
Do you mean a ‘non latching’ push button with a ‘COM’, a ‘NC’ and a ‘NO’?
I guess you only want to break the circuit when you push it down?
Sonofspectrum
Sonofspectrum's picture
Last seen: 4 days 14 hours ago
For what kind of application?
It's moments of madness that keep us sane.
kramer5150
kramer5150's picture
Last seen: 3 weeks 9 hours ago
Like a reverse momentary?… I cant think of any switch with some momentary action that does this.
Enderman
Enderman's picture
Yes, it should break the circuit, but also reconnect it immediately, all with one push down.
For rapidly switching a circuit off and on in a single press to switch modes on a LED driver.
If I use a regular momentary pushbutton switch then I need to push it down and let go quickly.
I want both the disconnect and reconnect to happen almost instantly so I only have to press the button down and not worry about releasing it quickly.
thijsco19
Last seen: 14 hours 8 min ago
I dont think that a switch like that exists. I’ve never heard of it.
kramer5150
My Fenix LD25 does that. When I push the button it turns on, as I continue to push it for a brief moment turns off, continuing to push it further turns it back on again and then it clicks permanently on.
I think its a bug in the driver and not the switch though.
Its a bezel twist UI though. Its does not use power cycles to change modes.
LightRider
LightRider's picture
You mean like the hammer on a lever action pistol? The is in contact with firing pin. You pull the trigger and the hammer disengages as it pulls back then re engages to fire the gun. Well… not exactly but kind of.
If you did find something, it would have to be able to handle the full current.
Wouldn’t it be easier to add a regular non-latching push button switch. It would be called normally closed non-latching or momentary push button. These are available but not sure if they would fit a flashlight? If you wanted to go this route, you could a regular clicky switch and file off the tabs that make it latch. You would have to dissect the switch but it’s wouldn’t be difficult.
vwpieces
vwpieces's picture
Last seen: 2 weeks 1 day ago
That sounds like the switch used in the Thorfire VG-10. But I may be wrong.
You need to half press button several times to choose mode then full click it to remain there in that mode.
Normal 1288 (most common SW) you need to full click then half click to switch modes.
VG-10 style flashlight forward switch
LightRider
!{width:50%}https://ae01.alicdn.com/kf/UT8AByFXXxXXXagOFbXl/121130677/UT8AByFXXxXXXa...!
Na, don’t think that’s what op’s looking for? Some people have a hard time with the half press of a switch without clicking it. Especially the elderly. Adding an additional switch that interrupts power without clicking allows the user more grace when changing modes.
However, the op may have a totally different objective. OP?
Jerommel
Jerommel's picture
OP is looking for a switch that works like a piano key (kind of)
But in stead of making a little hammer hit the piano string it should break the circuit for a fraction of a second.
I don’t believe that exists though.
He will probably have to settle for a momentary push button with a ‘normally closed’ contact and just push it briefly (or ‘tap’ it) to switch modes.
I.m.o. you might as well put the reverse clicky there.
Enderman
Enderman's picture
Yeah you’re right, that seems like my only option other than having some weird custom switch made or using a circuit to control a relay…
Thanks everyone!
itsme5k
Last seen: 1 year 1 month ago
Have you tried an SPDT push button with both outputs wired together (shorted)?
Never done this myself, but the time between disconnecting output one and connecting output two may be long enough to change modes.
A quick Google brings up products such as below.
Middle pin to driver, outer two shorted then to power.
- John
Watch this space...
SawMaster
That might work as the two contacts aren’t always in perfect synch, but it would be an individual switch doing this well enough selected from a batch so you might need to try dozens of switches to get the right one. Or you could disassemble one and try to rework one side to ‘click’ earlier or later. Otherwise it will take an electronically delayed switching circuit to achieve this. Or maybe running one side through a relay would give enough delay?
Phil
Phlogiston
Phlogiston's picture
Last seen: 4 days 1 hour ago
That’s what I was thinking – also known as a break-before-make single pole changeover (SPCO) switch. The break in power will be very short, though. Switch debouncing in the driver might cause it to be ignored.
Enderman
Enderman's picture
!http://au.element14.com/productimages/standard/en_GB/2435241-40.jpg!
That’s a good idea, I might buy one and test it out.
Problem is that if it is momentary, pressing it will actuate once but releasing will actuate it a second time.
If it is not momentary, then it might work the way I need Smile
Jerommel
Jerommel's picture
That will briefly disconnect on releasing the button too, unless you get a latching one.
[edit] Yes, what he said. Smile
dw911
Some small DC manually re-settable circuit breakers do just what described you needed when u push the little round reset button.
Probably too big for your application though
Cousin Elmer
Last seen: 3 months 5 days ago
In the (likely) event such a switch doesn’t exist have you considered replacing the driver? Fast off time switching is usually a desirable feature but there are drivers that have very slow mode switching. For example Armytek uses very slow off time mode switching in many of their lights. The DIY drivers I’m most familiar with all have fast off time switching but some of them could be programmed for much slower mode switching.
Enderman
Enderman's picture
Thanks, I´ll look into it Smile
Size is not an issue, this isn´t a regular sized flashlight.
The driver is new, from mtn electronics and works great, so I´m not planning to replace it.
LightRider
I ran into a similar need once. I was building an mot spotwelder and wanted a button that would engage and immediately disengage no matter how long the button was pressed.
I ended up using a two stage drill trigger and a capacitor on the relay. It kinda works;)
dw911
Enderman wrote:
dw911 wrote:
Some small DC manually re-settable circuit breakers do just what described you needed when u push the little round reset button. Probably too big for your application though
Thanks, I´ll look into it Smile Size is not an issue, this isn´t a regular sized
Will probably do what you need then, the ones I had look like these, although the body was white and they looked slightly better constructed
https://www.google.co.uk/search?q=12v+dc+circuit+breaker&client=ms-andro...ULM%252C_%253BVLSjZI9_rp_XMM%253A%252CGXq10qDG2E3VIM%252C_&usg=__Mj30BoQvg-AXya4kD7L5SqruJJ4%3D&sa=X&ved=0ahUKEwia0qCXpZLRAhUXMlAKHWwNDkwQ7AkISQ&biw=360&bih=615&dpr=3#imgrc=CwiKviwvyTJlqM%3A
The ones I had worked like you described, obviously can’t say for sure if they all do or just certain makes Smile
bulrush
Last seen: 2 years 11 months ago
Don’t you mean a latching switch? You push it once and let go and it turns on, push it once and let go and it turns back off.
dw911
I been thinking about this, if such a switch existed, how would you ever turn it off ?
Even what I linked will do what you want but won’t ever turn off, will only turn of if you short circuited it and it will pop out and wait to be reset.
Only thing that might work is one like I listed, but for a plane – you can twist to make it pop out to break the circuit/switch of the circuit – expensive though as most plane or marine stuff is.
Anyway as you got lots of space on what your building , why not just use a normal on/off switch then a N/C push button switch in series to activate the modes by momentarily pushing it as required ?
Joshk
Joshk's picture
Last seen: 4 hours 7 min ago
Flashlights only change mode like this to avoid needing to run a third wire to the tailcap. How do you plan to turn off a light like this?
Enderman
Enderman's picture
No, push down = disconnect and reconnect, release = do nothing
There would be a separate on/off switch in line with this switch. Total two switches, one simple on/off and one mode-changing switch.
Joshk
Joshk's picture
Isn’t this the functionality of any light with an e-switch?
Enderman
Enderman's picture
Yes, exactly, but for a driver that does not have an e-switch.
Joshk
Joshk's picture
So how do you change the press length? If the driver needs a short press to scroll through the different brightness levels, and a medium press to reverse into the hidden features, like strobe or battery check, how would you ever get into strobe?
Enderman
Enderman's picture
Uh, it only has 4 regular modes, nothing special.
Joshk
Joshk's picture
Maybe yours has functionality you haven’t discovered Big Smile
But mostly I was pointing out it’s not something anyone would buy. Well, maybe one person.
