USB Rechargeable 18350 Convoy S6 Triple
21 posts / 0 new
CRX
CRX's picture
Last seen: 29 min 59 sec ago
Another cool flashlight mod for you today, a shortened Convoy S6 with USB recharging facility Wink
I had been thinking about this one for a while but could not find a small enough suitable charging circuit until the new USB rechargeable 18650 batteries appeared on the market.
After reading HKJ’s Review of Lumintop 18650 3400mAh USB LM34C and Disassembly of USB charged batteries i decided i would buy one of these cells to check out what i could do with it.
I bought it on pre-order so got a good price for it.
I also bought a couple of spare 18350 Extension Tubes to see what lego’s with what.
Onto what i have done…
I figured i could incorporate the charging circuit into the S6 without too much difficulty, the only problem being how to charge the battery when the light is in an off state, ie the light would have to be switched on and in a low mode to make the circuit and charge the cell.
I come up with the idea that if i could disconnect the cell & charger from the driver while keeping them connected together that would mean only having to engage the clicky switch to make the charging circuit complete when the USB charging lead was connected.
This idea would serve two purposes – separating the battery and charger from the driver unit and giving me an internal charging port cover.
The light was already built as a triple with 20mm aluminium heatsink so i cut the heatsink in half to allow enough space for the charging circuit to be installed.
The charging board sits attached on top of a compressible silicone cushion to the driver, the cushion is a couple mil larger than required so when pressure is relieved it pushes away from the driver, breaking contact.
By unscrewing the head a couple of turns the USB charging port is revealed and the driver and charging board break contact while the cell and charger remain connected. All that needs to be done is plug in and hit the tail clicky to on position.
The charging light is green when the tail switch is open or the cell is full and red while charging.
I made this light with an 18350 tube as the charger has a trip protection of around 7.8A and a high discharge 18650 would most likely trip it. (untested though)
Here’s some pictures, the ones of the cell used are from HKJ’s reviews linked above.
Triple XP-G2 3C on noctigon
10509 TIR Optic
Arctic Silver 5 Thermal Paste
ARC glass
17mm FET driver
10mm aluminium heatsink
Micro USB charging port
Forward tail clicky
Magnetic Tail
2 × 1.5mm green tritium vials
Max – 1020lm
cd – 3500
Throw – 118m
Edited by: CRX on 03/09/2017 - 06:01
Bort
Bort's picture
Last seen: 1 week 1 day ago
Very impressive, how did you drill the holes in the light?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
alphazeta
alphazeta's picture
Last seen: 1 year 1 week ago
I always like modded lights from CRX but this one looks extra well done (if that is even possible.)
Such polished fit n finish on this light & it’s so practical too. This light needs to go into mass production.
CRX
CRX's picture
Thanks, i just used a battery drill with 1.5mm bit, drilled three holes and filed out the slot with mini diamond files. The charging indicator is a single hole filled with UV setting glass glue.
Thanks very much mate Thumbs Up
will34
will34's picture
Last seen: 11 hours 1 min ago
Nice mod, your hand-made work is impressive!
CRX
CRX's picture
Still practicing, but getting better Smile Thanks.
Bort
Bort's picture
I’m amazed you did not break many bits and could drill 3 holes close enough together to bridge them with a mini file
CRX
CRX's picture
Me too! LOL That was the scariest part of the build and went much better than i had anticipated.
The aluminium is really quite soft once you get through the ano. I tried a new trick and cut a small line with a junior hacksaw on this one first.
Bort
Bort's picture
Interesting, interesting, i had a thread about the soft aluminum a few years back, i’ll see if i can find it
Splott-Light
Splott-Light's picture
CRX,
Well Done, Love It.
Liked the Lateral Thinking with disconnecting the circuit to reveal the charging port.
Cheers,
S-L Smile
Ouchyfoot to a New Member: Welcome CJ. Now you have to learn about buying an inexpensive flashlight and modifying it until it either blows up, or starts small fires on the moon…………
Hugh Johnson:
I, too, once lived a tragic and empty life. Then I found [portable] light.
You forgot to mention clothes. I sold most of my clothes to fund my light collection. This is actually fine, since I only go out after dark, and most people can’t see me.
Finally, I got my priorities straight.
Lexel
Lexel's picture
Last seen: 44 min 18 sec ago
Yeah nice mod
But seriously an Eagle Eye X2R might be a simple solution
CRX
CRX's picture
Splott-Light wrote:
CRX,
Well Done, Love It.
Cheers,
S-L Smile
Thank you Beer
Lexel wrote:
Yeah nice mod
Thanks, but i fear you are missing the point Wink
I have an Eagle Eye X2R on order, should be an interesting light.
chouster
Last seen: 4 months 5 days ago
Very cool mod, CRX!
Serp
Serp's picture
Last seen: 1 week 9 min ago
Nice
LightRider
LightRider's picture
Last seen: 1 year 11 months ago
I have been planning a similar mod for a while but haven’t gotten there yet. I laid out a charginging circuit with the components of a commonly available circuit. I have the parts on hand but haven’t worked out how to order the boards.
http://budgetlightforum.com/node/48485
KawiBoy1428
KawiBoy1428's picture
Last seen: 7 hours 20 min ago
Wow well done! Wink Thumbs Up Your skilz and builds are amazing! Beer You must have been a watch maker in a previous life!! Big Smile
KB1428 “Live Life WOT
Kepling
Clever build Smile
Ingeniously done!
(The pictures are kind of dark. A bit of lighting will make the details more visible i think.)
djozz
djozz's picture
Last seen: 54 min 19 sec ago
Very nice work again, you clearly spend serious time tinkering what should be possible and have most of the build thought out before even starting.
Mike C
Mike C's picture
Last seen: 13 hours 57 min ago
Inspiring stuff! I might well make something like this myself based on this build, thanks for sharing.
CRX
CRX's picture
Thanks for the inspiring comments gentlemen Beer
Added a couple new pics to OP.
Lithium
Lithium's picture
Last seen: 1 month 2 days ago
Very nice build, I’m really impressed!
Want DC-fix? PM me!
