Noctigon Meteor USB Rechargeable
8 posts / 0 new
CRX
CRX's picture
Last seen: 25 min 5 sec ago
Installed a TP5000 Micro USB charger board in the tail and some other stuff on the Meteor.
The brass extending piston is electrically isolated from the light and has a wire running through it to the charger.
This makes charging very convenient and can charge all four 30Q’s in about six hours.
XP-G2 S4 3D emitters
Arctic Silver5 thermal paste
2A charging current TP5000
Charging indicator
2 × 10mm x 2.5mm tritium vials
GITD bezel
Max – 7200lm
I’ve changed the switch cover a few times
Final iteration is a metal cover
Added some GITD under the optics
Edited by: CRX on 08/29/2018 - 17:33
will34
will34's picture
Last seen: 40 min 29 sec ago
Wow awesome mod! Very clever way to make +ve contact
Cula
Cula's picture
Last seen: 1 day 22 hours ago
Great mod, as always CRX, there are many things to learn from your mods.
I was wondering and maybe it is a stupid question so forgive my ignorance, when you charge the batteries does the current from the charger also goes to driver?
Or is there some kind of a lockout to prevent that?
MRsDNF
MRsDNF's picture
Last seen: 21 hours 13 min ago
SmileThumbs Up
evankouros
evankouros's picture
Very impressive mod CRX! Thumbs Up
chops728
Last seen: 1 day 1 hour ago
Awesome Job—Always thought internal charging would make this a perfect light
CRX
CRX's picture
Thanks for your comments Thumbs Up
Cula wrote:
when you charge the batteries does the current from the charger also goes to driver? Or is there some kind of a lockout to prevent that?
The light can be locked out as usual, breaking the – contact, that was part of the reason behind the brass extending spring piston.
I did make a lockout disc for the + contact too in the “prototype” version so the cells could be completely isolated but don’t think it necessary
giorgoskok
giorgoskok's picture
Last seen: 3 days 18 hours ago
Awesome work CRX !
