Armytek Prime C2 Pro v3 Warm review (XHP35 HD, 18650)
46 posts / 0 new
clemence
clemence's picture
Last seen: 1 day 23 hours ago
Yes, there are still artifacts but still so much better than the stock one with pink circle hahaha. Also the beam transition is way better
Did you get the same increased output?
- Clemence
maukka
maukka's picture
Last seen: 23 hours 43 min ago
With the beaded Yajiamei
0 sec: 1344 lm
30 sec: 1284 lm
1 min: 1245 lm
2 min: 992 lm
Measured again with the stock optics since the original test was done with a DIY sphere
0 sec: 1135 lm (old measurement 1090 lm)
30 sec: 1082 lm (old measurement 1045 lm)
1 min: 1051 lm
So an 18% increase. Would probably get more with a clear optic, but I’m not going to use them.
clemence
clemence's picture
0 sec: 1344 lm
30 sec: 1284 lm
1 min: 1245 lm
2 min: 992 lm
1 min: 1051 lm
Correct, the plain tight TIR produces the most OTF lumens 30ish% in my case.
With Prime max angle for max OTF output is < 20°
With Wizard ax angle for max output is < 60°
The reason is the unusually deep recession in Prime’s lens. It’s not too severe in Wizard because the bezel isn’t as tall as Prime and it’s countersunk.
I use 5° because it’s my sidekick for occasional medium thrower, 90% of the time I use my Tiara Pro for hiking/EDC.
- Clemence
zak.wilson
Last seen: 44 min 19 sec ago
I’ll be trying the 5 degree and XHP35 HI for mine. I’m hoping to get 250m+ FL1 throw with nice tint and 80 CRI.
Ceilingbounce – flashlight testing and runtime graphs for Android
deathless
Last seen: 3 weeks 5 days ago
Can someone confirm that it is, in fact, brightest for city?
maukka
maukka's picture
It’s right there. In white and black. How can you argue with that?
clemence
clemence's picture
That really depends on what city we are talking about. In my city, this most probably is the brightest. But in Texas it would be just another ordinary LED flashlight. Especially if you live next to Texas_Ace and DBCustom.
- Clemence
trenters
Hi there,
Thanks for all the information on this; I’ve ordered a variety of those optics to experiment with, but I’m having real trouble getting the bezel off!
I see you have a bolt with a triangular head – did you make that yourself from a hexagonal head? I’ve tried strap wrenches, but I can’t get them to grip enough…
Any advice gratefully received!
Cheers
clemence
clemence's picture
trenters wrote:
Hi there,
Cheers
Yes, 100% DIY stuff
- Clemence
The_Driver
The_Driver's picture
Last seen: 13 hours 25 min ago
I also got some of the beaded Yajiamei optics for my Armyteks. I so far have tried some of them with my modded Prime C2 (Nichia 219B-V1 sw45 R9080). The output increase is very obvious! The 10° optic does not create as smooth of a beam profile as one would expect. The 15° is much better, but the edge of the corona is yellow. The 30° optics creates a very even tint, but I think it decreases the throw too much. I will use the 15° lens in this light.
All of the tested lenses create a pronounced, triangle-shaped corona. EDIT: This is caused by the notches in the bezel.
I will soon test some wider variants with my modded Wizard with the larger Samsung LH351D LED.
clemence
clemence's picture
5° XP Yajiamei creates nice beam profile with no artifacts. Much better and throwier than stock Prime.
- Clemence
npetike1
Last seen: 4 months 4 weeks ago
Clemence, could you use the oem glass with this 5° XP Yajiamei lens?
clemence
clemence's picture
AFAIK no, because this XP lens is a bit taller
[Clemence]
maukka
maukka's picture
Yes, the original lens fits fine at least without the gasket which I found made the beam worse.
KevinZA1988
KevinZA1988's picture
Last seen: 1 hour 7 min ago
I almost pulled the trigger on this light, and luckily I came across this review. I’m astonished by just how the efficiency of the driver lags behind the competition!
Does anyone know:
If there has been any updates to the driver after this review?
Down to what battery voltage level this light will engage turbo?
If it can still engage turbo with at 3.4Vbat then I guess it’s worth the inefficient driver. The boost driver lights I bought (and sold quickly after) all fell out of turbo at 3.7-3.8Vbat.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
