BLF GT cases, soft or hard
Any ideas on a good case for the BLF GT. Here are a couple of cases linked by others.
adsum link
bwl1213 link
zortan link
southland link
adsum link
LOL, sorry I can’t help but laugh when I clicked the links. I always seem to underestimate how big it actually is…no pun intended!
Found this one, the same as in link #2 but cheaper, there is a limit of one. link for $3.64 USD
Edit: somehow the original link was wrong, changed now.
How about this one?
Tactical
Looks a lot bigger than the listed dimensions. Like the single strap.
Yes,so many bags I found that would have been otherwise fitting and about the proper shape were just exactly 32cm long and I think if thats their outside length,it may be too short.
With this one you have at least compartments for extra batteries etc…
Ordered two of the cases, this is the one from the 4th link in OP. Cheaply made, padded only on one side, way too big. The water bottle inside the case is .5 inch smaller in diameter than the GT and .5 inch shorter.
This is the case in the 1st link in OP. Not sure if the GT will fit. This water bottle is only .5 inch smaller and it’s a snug fit. It will be tight if it does fit the GT.
I´m hoping it fits inside this. Extra pockets for batteries etc…
Sling Back Pack
I have a pair of super thick winter boot socks and I think the GT will fit nicely. It will provide enough protection to avoid little dings and scratches to the lens without being too bulky.
Just brainstorming…
I don’t think adsums pack is padded, but I like the concept. WJs idea isn’t really a carry case, but put both ideas together, now I really like that! Maybe a piece of closed cell foam cut to fit the bottom to protect the lens (or will the lens be up?).
Or for the hardware store look, a piece of PVC pipe with closed cell foam inside. One end capped and glued the other with a screw on end. No doubt something could be rigged for a sling. It would be bombproof. It would also turn a 3# light into a 6# light. So maybe not so practical unless one is going into a combat zone and has transport (or is car camping).
Something like this?
I ordered that sling backpack in black and was planning to carry GT lens up.That thick top should offer enough lens protection.For extra padding in a case like this I usually use some extra gloves or some other soft stuff at the bottom of the pack.
adsum, please let us know if you think it will work when you get it. Looks nice.
thanks,
Does anyone have the dimensions for the GT? I’m after the diameter of the bezel and length, please!
I want to see if a “trumpet gig case” might work.
Condition 1 801 Medium Hard Case
I’m going to try the
SRA Cases EN-AC-FG-C401 Silver Aluminum
:smiley:
Best hard case I have seen with correct dimensions for the GT.
