Haikelite MT07S CREE XHP70.2 Flashlight--now released
44 posts / 0 new
HaikeLite Official
HaikeLite Official's picture
Last seen: 3 days 18 hours ago
*Another new powerful flashlight from HaikeLite. *
MT07S 5000 Lumens , 750meter throw, full current regulation with a lot of nice UI function
Specifications:
Emitter: CREE XHP70.2 NW 4800K
Meterial: Aluminum Alloy , HAIII Anodising
Battery: 4×18650 (Recommend Sanyo 18650 GA 3500mah 18650)
Reflector:SMO Aluminum Reflector
Lens: Double Side AR coating Glass Lens
Bezel: Stainless Steel
Waterproof: IPX8
Max Output: 5000 Lumens
Max runtime: moonlight 1 lumens—60 days
Digital Full Current Regulation
Anti-reverse protection
Anti-discharge protection
Demension: 175mm x 66mm x50mm
Netweight: 470 gram
Accessories: landyard,O rings,Tripod Mounting Screw
Brightness Modes:
Low: 150 Lumens
Medium I: 450 Lumens
Medium II: 1000 Lumens;
High: 2200 Lumens
Hidden Turbo:5000~5500 Lumens (double click at any time)
Double click again:Strobe
Hidden Moonlight:1 ~3 Lumens (In off status A long click for 2 seconds to access moonlight. )
Thermal control Remove / Activation:MT07S comes with thermal control by default. If you want to remove thermal step-down , turn the moonlight mode on first and press the switch for 3 seconds to remove thermal control function. When you see a signal flash, it means the thermal control function has been removed, and MT07S will have no step down any more.
The thermal control function will recover when you cut off the power supply.
User Interface:
single click on; single click off
Long click to change modes ; Double click to Turbo ; Double click again to Strobe ;
With last mode memory
In off status a long click for 2 seconds to access moonlight mode ; another long click for 3 seconds to remove thermal control. Cut off the battery power to recover thermal control.
Lockout Function:
A single click followed by long click to lockout the switch. Repeat to unlock.
Power indication light: (LED indicator under the metal switch button)
100%~50% Blue led on
50%~9% Blue led flashes
Blow 9% Red led flashes
Camera setting : Shutter- 1.3S ; Aperture F4; IOS 200
MT07S XHP70.2 NW 4800K ; SMO Reflector
MT07S CREE XHP70.2 NW SMO Reflector VS MT07 Buffalo XHP70 CW 6500K OP Reflector
HaikeLite Official--all rights reserved
www.haikelite.top
Skype: haikelite@yeah.net
rizky_p
rizky_p's picture
Last seen: 9 hours 50 min ago
Nice Thumbs Up
Would love to see size comparison between MT07 and MT07s.
cccpull
cccpull's picture
Last seen: 2 months 1 day ago
So, where can you get it?
Nicolicous
Nicolicous's picture
Last seen: 2 hours 8 min ago
“750meter throw” now you got my attention Big Smile
what about the price?
hIKARInoob
hIKARInoob's picture
Last seen: 3 hours 26 min ago
I wonder if there is going to be an MT03S as well… in 4S configuration instead of the current 2S2P.
alistomasion
alistomasion's picture
The effect in dark seen close to a car headlight, how much is it ?
Lightsetc Amazon - Light up your life:  Decor Light | Flash Light | Christmas Light | Outdoor Party Light | String Light
HaikeLite Official
Double brighter than car light. MSAP is 65usd~69usd
www.haikelite.top
HaikeLite Official
MT03 is not going to make a smaller version, considering the huge heat from 10 000 lumens MT03 size is good for heat sinking
www.haikelite.top
rizky_p
rizky_p's picture
how about triple XHP35 HI?
hIKARInoob
What happened to the website? http://www.haikelite.top/
freeme
freeme's picture
Last seen: 21 min 15 sec ago
Domain expired.
hIKARInoob wrote:
What happened to the website? http://www.haikelite.top/[/quote]
SubSailorVet
SubSailorVet's picture
Last seen: 1 week 4 days ago
Really excited to see this new version. Will there be a model with cool white led?
Best regards,
Matthew
cccpull
cccpull's picture
Could someone clear up the specs on this light? Is this light 4500, 5000, or 5500 lumens and is the max throw 500 or 750 meters? Thanks.
Itsme
Last seen: 18 min 45 sec ago
looks good!
mrheosuper
Last seen: 11 hours 42 min ago
what you mean “ no step down”, the light maintains the output even it reachs 100*C ?
Forgot my pen
HaikeLite Official
CW 5000lumens; NW—4500lumens. KCD shows 550meters distance
www.haikelite.top
HaikeLite Official
If you shut down the thermal control, the output will maintains even it reachs 80 degree C.
www.haikelite.top
Narmattaru
Last seen: 18 hours 49 min ago
i like your flashlights mostly (tested 3 of them)
but idea to put XHP with SMO is strange.
i mean XHP performs best with OP.
may be you guy thought about XPL-hi or L2 there? good old decisions for throwers.
anyway, i`m glad to see that you keep on doing new stuff.
if you like my reviews and want to support me in this, here is my Paypal account: insertscarynick (at) gmail dot com
any donation will be appreciated.
Tom E
Tom E's picture
Last seen: 5 days 8 hours ago
Narmattaru wrote:
i like your flashlights mostly (tested 3 of them) but idea to put XHP with SMO is strange. i mean XHP performs best with OP. may be you guy thought about XPL-hi or L2 there? good old decisions for throwers. anyway, i`m glad to see that you keep on doing new stuff.
It's XHP70.2, not XHP70. The XHP70.2 performs well with an SMO - if focused well, cant see the black hole, and throw is definitely better. In fact if you are interested in max throw, we've been using SMO's with  the XHP70 in the past. Now pretty much we are all switching to the XHP70.2.
JasonWW
JasonWW's picture
Last seen: 1 hour 33 min ago
I’ve got some 70 vs 70.2 in an L6 with SMO comparison pictures here.
http://budgetlightforum.com/comment/1163171#comment-1163171
If you look at the darker shots you can see the improved beam pattern of the 70.2. The dark hole is much reduced. When viewed at normal brightness levels the 70.2 appears very smooth. I got 830 meters on my light and I know my numbers are a bit lower than average.
My Convoy L6 thread with XHP70.2, Texas Avenger FET driver, Narsil v1.2 ramping firmware, lighted side switch and cut down SMO reflector. Lots of amp draws on stock driver as well.
http://budgetlightforum.com/node/54477
My Supfire L5-S thread with XHP70, Texas Avenger FET driver, NarsilM v1.0 ramping firmware and lighted side switch. My mini L6! http://budgetlightforum.com/node/55746
9 NarsilM user videos including GT
http://bit.ly/narsil-vid1
mrheosuper
woah, there is a chance i can boil an egg with this light, i guess Silly
Forgot my pen
zieloczek100
Last seen: 2 weeks 1 day ago
Hi
My MT07S stopped working after one day.
Work dwo modes, in one flicker, I can not turn off the flashlight.
The flashlight (the reflector) probably I see smoke rising.
What could be damaged?
hIKARInoob
zieloczek100 wrote:
Hi
Probably driver (I mean what else?). I’d contact vendor immediately for DOA warranty.
zieloczek100
@hIKARInoob, thanks for the quick reply.
Tomorrow I can record a video that shows the damage.
Are you from HaikeLite?
In many reviews people write that this model can work with 2 * 18650 – is not that true?
hIKARInoob
Hey how are you man? No I’m not from Haikelite, hehe. From what I know, the MT07S is 4S (4 cells in series), so you do need all four cells for the light to work. This is not the case with the larger MT07 which can operate with just two cells.
Both Banggood and Gearbest have a DOA (dead on arrival) warranty. Within three days for Banggood and seven days for Gearbest (IIRC), if you report a defect, then you don’t have to pay for shipping to China. So it’s best to upload video to Youtube and report problem within this period.
hIKARInoob
Nice video and impressive beamshots from Mr. Charles Bridgtec
DENGOH
DENGOH's picture
Last seen: 1 hour 41 min ago
Got it, mine is NW, very impressive and brighter than my RC40 3500lm. 4500lumens heat up whole light fast even the batt tube. I took battery out and batteries are not as warm though.
I used small magnet to make contact. Don’t feel like to remove the +ve batt plastic yet.
cool i'll see you when you get there
Pok
Pok's picture
Last seen: 30 min 42 sec ago
DENGOH
DENGOH's picture
Interesting…360kcd
JasonWW
JasonWW's picture
Pok wrote:
HaikeLite MT07S HI Upgrade Version 3000Lumens
!https://i.imgur.com/292jFRA.png!
How is this model an upgrade if it has 2,000 less lumen? What is different about it? Did they switch to a sliced dome xhp50.2?
hIKARInoob
My guess was it’s XHP35 HI, stating it’s 3000 lumens just like Astrolux stating MF02 is 3000 lumens. I’m interested in actual throw figure, as 1200 m is probably not the case.
